#1036879 - 03/26/16 09:31 PM 700R4 Swap
skh4194 Offline
skh4194  Offline
Madison, WI
Installing a 700R4 in my 1984 Monte Carlo SS in place of the factory turbo 350 and I am having trouble getting it to shift through the gears correctly. What is everyone else doing for a shift cable and bracket for this swap.
Thanks for the help
#1036911 - 03/27/16 06:54 AM Re: 700R4 Swap [Re: skh4194]
You need a cable and bracket for the 700r4. I'd suggest one from a camaro with that trans and it should work out.
#1036916 - 03/27/16 12:22 PM Re: 700R4 Swap [Re: skh4194]
skh4194 Offline
skh4194  Offline
Madison, WI
Thank you very much! Do you know of a source for a new cable to trans bracket for that setup? I did some searching online and couldn't fine much.
Thanks Again!
#1036919 - 03/27/16 12:43 PM Re: 700R4 Swap [Re: skh4194]
mannblk Offline
mannblk  Offline
NC
I would just do a simple ebay search "Camaro 700r4 tv cable and bracket" and they will pop up. HTH
I swapped an 84 out to a 200r4 and had an 86 Monte donor to snag all of the parts/pieces off. Also wired in a simple toggle switch to activate the converter lockup at speeds over 50. This will save you another 200 RPM. You will love having the OD with the 3.42's! Good luck.
#1036941 - 03/28/16 01:01 AM Re: 700R4 Swap [Re: skh4194]
skh4194 Offline
skh4194  Offline
Madison, WI
I will give that a try! Thank you very much! I'm looking forward to the first test drive.
#1037090 - 03/30/16 08:58 PM Re: 700R4 Swap [Re: skh4194]
NYmonteSS Offline
NYmonteSS  Offline
Elkton MD
you had a th350?, you will also need a shifter to run the 2004r.
#1037446 - 04/08/16 06:30 PM Re: 700R4 Swap [Re: skh4194]
skh4194 Offline
skh4194  Offline
Madison, WI
Yes I had a 350th. I got a cable and bracket from an 89 camaro with a 700R4 but it will not work with the floor shift bracket in my car. Any advice on what I will need to swap in for a floor shifter that will work with my new 700r4.
Thanks in advance!
500/thumbs/Picture_065a.jpg
by Tim3927
500/thumbs/UpdatedEnginebay2.JPG
by 1NJIMID8TOR
500/thumbs/rims_002.JPG
by bootlegger
by chocolatethunder41
560/thumbs/MM_05_19.jpg
by NYmonteSS
