#1036251 - 03/12/16 05:33 PM Changing rims
monte_man_2020 Offline
Lisle, IL
I had bought last year the 14" checkerboard rims and going to be putting them on soon. I need to do a brake job also and was wondering if I can upgrade my OEM calipers with better ones. Either way the ones on there now are going and have plans to putting in a stroker 383 engine.
#1036261 - 03/12/16 08:29 PM Re: Changing rims [Re: monte_man_2020]
Upgrade to a good set of pads because the 14 inch wheels will limit the size of brakes
#1036281 - 03/13/16 03:43 PM Re: Changing rims [Re: cj84ss]
Lisle, IL
Would you recommend thermo quiet or jump onto jc Whitney or one of those aftermarket sites? I put Raybestos (don't know if I spelled right) on my charger in the rear.
#1036289 - 03/13/16 07:19 PM Re: Changing rims [Re: monte_man_2020]
tomh115 Offline
tomh115  Offline
Russellville, AR
I have Wagner thermostat quiet pads on the SS and I love them. A friend with a 66 GTO recommended them to me. They are cheaper if you order them from rock auto than buying them at your local store (or they were last year)
1987 Monte Carlo SS Aerocoupe
Objects in mirror are losing
#1036779 - 03/24/16 05:46 PM Re: Changing rims [Re: monte_man_2020]
Lisle, IL
I had ordered them through eBay for $30 cheaper anywhere else. Thanks for the recommendation!
#1036785 - 03/24/16 08:35 PM Re: Changing rims [Re: monte_man_2020]
Besides limited brake upgrades you will also have limited performance tire choices with 14" wheels. Brake cooling could be blocked a bit more by smaller wheels.
While I admire Checkerboard wheels for stock restorations, they may not be the best choice for your 383 stroker plans.
#1036790 - 03/24/16 11:32 PM Re: Changing rims [Re: monte_man_2020]
I'm running 14's on mine, don't know if I have had much issue with brake performance since I've only had 14's since I got it so I can't make a good comparison.
As for tires, 245/60 was the biggest size I could get for 14's, in BF Goodrich Radial TA. It keeps about the same diameter vs the stock non-SS tires while getting significantly more tread under it. I had a hard time getting two of them about 5 years ago though. Don't know if they dropped them or just didn't have many at the time.
#1036802 - 03/25/16 03:43 AM Re: Changing rims [Re: monte_man_2020]
RenoReno2 Offline
RenoReno2  Offline
Chicago, IL
Ive been using those Wagners for like 15 years now on all of my cars and they are great pads. Take a look at US Brake, they sell an oversized piston caliper for our gbodies. I bought them for mine but as you know I've yet to drive the car
88 Monte SS
#1036907 - 03/27/16 03:25 AM Re: Changing rims [Re: monte_man_2020]
Lisle, IL
@hunter79764 do you have pics of your ride? If im reading your footer on your posts but you have a 5.3L with those 14" rims?
#1036909 - 03/27/16 04:06 AM Re: Changing rims [Re: monte_man_2020]
Yeah, it's a stock 5.3, so around 300 HP. I've got the V6 rear and a 3 speed, so it basically acts like a "normal" car that's missing 1st gear. 1st gear runs to 75+, 2nd is probably around 115 mph, I'm running about 2100 rpm on the highway.
I got rid of the stock steelies and installed some Chevelle SS rims (yes, they were offered in 14x6). Even with the tall rear gear, I have to feather it off the line for a good start.
I don't have enough pictures, but there's a couple here
http://www.montecarloss.com/community/ub...2934#Post902934
523/thumbs/DSC_0616.jpg
500/thumbs/InTheGarage.JPG
by 1NJIMID8TOR
708/thumbs/Bushing_Tool_1.jpg
by 87ChooChoo
776/thumbs/montewheels_xrpipe_002resize1.JPG
by mikeasis
500/thumbs/th_ss008-1.jpg
by sstwotimer
