#1035794 - 03/02/16 11:41 PM Rough idle/driving ...need help!
Frank52387 Offline
Frank52387  Offline
Philadelphia, Pa
So for the last few weeks after about 10-15 minutes of driving my check engine light comes on but no change in performance just a little smell of gas. so I thought it was possibly a bad O2 sensor or EGR valve. i replaced the o2 sensor and my car was running really rough and the check engine light was coming on dry quickly. I thought maybe I Knocked a spark plug wire loose getting to the o2 because of how rough it was running. The next day I wiggled and pressed down the spark plug wires and any plugs in the area and I started it up and it has been running great. In the process, I knocked off the temperature guage sending wire. I toyed around and plugged it back in and now my car is back to running rough and vibrating a lot. The motor is very shaky and not getting the good power or idle. I pressed down all the plugs and wires in the area and no luck. I can't figure out what is causing this. Any ideas?
The distributor, spark plugs and plug wires are about 2 years old from a tune up.
#1035802 - 03/03/16 01:17 AM Re: Rough idle/driving ...need help! [Re: Frank52387]
If your check engine light is coming on you need to read the codes. That will help you trouble shoot it.
#1035808 - 03/03/16 03:50 AM Re: Rough idle/driving ...need help! [Re: Frank52387]
meanLS86 Offline
meanLS86  Offline
republic, mo
X2 on codes but I suspect canister purge valve, the charcoal canister being plugged up can cause gas smell, also causing excessive vacuum buildup in fuel tank causing pump to work erracticlly in turn causing your symptoms. Have seen it before but mine got so bad caused vapor lock in the fuel system. Very bad. Bad gas cap could cause the buildup as well. I would open the gas cap when it's acting up to see if it sounded like a sucking noice or pressure was released.
#1035814 - 03/03/16 12:34 PM Re: Rough idle/driving ...need help! [Re: Frank52387]
LXXXIV SS Offline
LXXXIV SS  Offline
Lower Peninsula, Michigan
The only first step that makes any kind of sense is to pull those trouble codes out of the computer. Even if the Check Engine Light isn't on presently, the codes are still stored inside the computer for (I think) 50 starts. Don't quote me on the 50 starts, but I do know it's up there somewhere.
You can pull them yourself with a paperclip, and there's instructions here on the forum somewhere for exactly how to do it, and what the codes mean.
#1035822 - 03/03/16 07:07 PM Re: Rough idle/driving ...need help! [Re: Frank52387]
Frank52387 Offline
Frank52387  Offline
Philadelphia, Pa
I actually took it to the mechanic this morning, they've been good with my car, I wouldn't mind tinkering and figuring it out but the vacuum lines are a little over my head and it's my daily driver. Within the next year or 2 I'll retire it to my weekend car.
#1035824 - 03/03/16 07:22 PM Re: Rough idle/driving ...need help! [Re: Frank52387]
Bitflipper Offline
Bitflipper  Offline
Las Vegas, NV
Yep, 50 starts without a code being thrown and they are cleared from the ECM memory.
3188: 32 FCB $32; 50 STARTS TO CODE RESET
That's at least for the '87/'88 SS stock PROM or ZZ4 PROM.
Of course, pulling the battery or ECM cables will immediately clear them.
#1035832 - 03/03/16 10:12 PM Re: Rough idle/driving ...need help! [Re: Frank52387]
There is only 5 to 6 vacuum ports, the vacuum hoses are really simple.
#1035878 - 03/04/16 06:05 PM Re: Rough idle/driving ...need help! [Re: Frank52387]
Frank52387 Offline
Frank52387  Offline
Philadelphia, Pa
Mechanic had a hard time finding it but he said I had a bad "Map Sensor". The wire was frayed and shorting out not sending the right fuel/air mixtures.
500/thumbs/monte_n_bruno.jpg
by BahamaSS
500/thumbs/DSC00199.JPG
by nighttech
500/thumbs/mymonte1.jpg
by red/white04
500/thumbs/carlo5.jpg
by rj
618/thumbs/front7.JPG
by Wisconsin
