Page 5 of 6 1 2 3 4 5 6
#1059279 - 10/03/18 02:50 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Thats cool I took a long time fitting so I didn't have to un-do anything. Your pic looks real good is that a new rocker?
I'm still plugging away, started stripping the fenders and doors to get epoxy on them, kinda been looking for a rotisserie.
#1059286 - 10/03/18 11:03 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
84ss355*4spd Offline
Edmonton,AB,Canada
Thanks ya its nerve racking making sure its right. Better than factory gaps im hoping.the rockers inner and outter are new, .new doors,new quarters ,new complete trunk,new fenders amd new floor,wheelhouses ,3" cowl glass good mark hood. Its alot of work but starting to pay off. A rotisserie woupd be helpfull.
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1059844 - 11/15/18 12:42 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
So making good progress lately.the entire driver side has been assembled to check and make things fit right .sheet metal screws in key areas so things go back together the exact same way after welding . So far wheelhouse is welded in ,inner and outter rockers ,part of the trunk up to spare tire well .quarter is in the process of going back on .first i need to coat the inside of the quarter with some undercoating and spray the inner quarter structure and wheelhouse trunk drop off areas. Hopefully the pics work and u can see the driver side progress
https://ibb.co/iE5aUf
https://ibb.co/d68jN0
https://ibb.co/j24DFL
86 ss gone
85 ss new
85 z28 tpi
#1059845 - 11/15/18 12:47 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
86 ss gone
85 ss new
85 z28 tpi
#1060528 - 01/23/19 10:58 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
You have any pics of the car done? Those aftermarket parts seem to line up very well.
#1060670 - 02/07/19 02:07 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
They line up very well.it took some minor tweaks .car is still in the process .im working on the passenger side next. Just finished a tpi install in my 86 c10.so now im back on the 84 .thanks for the reply.havent had one in a while .thanks for noticing the fitment
86 ss gone
85 ss new
85 z28 tpi
#1063387 - 08/30/19 09:43 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Number1 Offline
Number1  Offline
OK
Any updates?
#1063394 - 08/31/19 04:02 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Beem working on the frame lately .front suspensi9n installed With 2in drop springs https://ibb.co/zQkQ95Z
86 ss gone
85 ss new
85 z28 tpi
#1063397 - 08/31/19 07:18 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Here is a shot of the driver door open .heres a tip if u get wheel houses get the complete assemblies.they fit to the rocker properly .passenger side i got seperate pieces and the arent even close at the bottom front where it meets rocker flange.there is a little extensi9n off the outter rocker that is a welded spot when together and they dont even come close to meeting up amd the shape is way off .the complete one on driver side fit like a glove once positi9ned and looks like factory in the wheel area
https://ibb.co/Jk7nx84
Below is the pic of the 2 pc wheelhouse installed the ends are not even close to what they should be and u can see the outter rocker tab!
https://ibb.co/ggF9Dzb
86 ss gone
85 ss new
85 z28 tpi
#1063398 - 08/31/19 07:31 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Here is the driver side in comparison .ignore the dust lol.so sometimes aftermarket fits good and sometimes it doesmt .u have to go all in sometimes to have a good fit.i think i might ditch the passenger halve wheel houses and get a complete one . The difference is huge
https://ibb.co/7KrdB8T
86 ss gone
85 ss new
85 z28 tpi
#1063399 - 08/31/19 07:38 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
More progress pics.new hinges hanging ,rocker,wheelhose and quarter panel fitting .the wonky wheelhouse i am going to replace with a complete one. The roof seam is always a nervous part just take your time and dont cut to much off at a time.quarter will go up a little more and it will be perfect seam.
https://ibb.co/jHVRnVK
https://ibb.co/5WSF0rB
https://ibb.co/C1JYP7q
86 ss gone
85 ss new
85 z28 tpi
#1063464 - 09/06/19 06:07 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Number1 Offline
Number1  Offline
OK
I think itโ€™s so awesome that your basically replacing all metal on a gbody to make it solid again. We rarely rarely see that or at least for me itโ€™s rare. Keep up the good work.
#1063518 - 09/12/19 12:47 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Appreciate the kind words.that was my thoughts exactly.car wasnt a beater by any means it had some rust in places that i didnt want to patch .
86 ss gone
85 ss new
85 z28 tpi
#1063691 - 10/01/19 11:36 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Been working on the passenger side lately.working on the spot where the quarter overlaps the rocker .working on getting the flange to suck in tight to the outter rocker on the bottom . If this isnt tight amd fitting just right good luck having a nice fit in the end with the door on .at least driver side is all done ex3pt final welding of the quarter .i can reference it as i go .thats is key only do one side at a time if u do this .is less work and fitting in the end
86 ss gone
85 ss new
85 z28 tpi
#1063742 - 10/10/19 04:42 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Passenger side coming along still fitting to do
https://ibb.co/vvBQLm4
https://ibb.co/YbTQPff
86 ss gone
85 ss new
85 z28 tpi
#1064012 - 11/04/19 12:30 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Final trunk piece installed .fits like a glove .looks factory pretty happy with these aftermarket parts .
https://ibb.co/fvNtFVX
86 ss gone
85 ss new
85 z28 tpi
#1064024 - 11/04/19 06:42 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Looks good, you are building a new car!
#1064028 - 11/05/19 01:39 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Thats right ! Lol thanks appreciate the response .doing lots of work on the car lately .will keep updates coming
86 ss gone
85 ss new
85 z28 tpi
#1065443 - 03/15/20 02:50 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Hey dude, i kinda fell off the boards but it looks like yours is.coming along. Thats great to see๐Ÿ‘๐Ÿ‘
#1066182 - 04/25/20 10:24 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Ya it takes time .im very close to welding the final parts on . Keep checking in
86 ss gone
85 ss new
85 z28 tpi
#1066183 - 04/25/20 10:25 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
86 ss gone
85 ss new
85 z28 tpi
#1067194 - 07/07/20 03:51 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Update full trunk welded in ,rocker panels,working on wheelhiuse now and trunk drop off.then last quarter goes on for good! Then weld em both in place excuse the stuff under the car lol .hopefully be coming off the frame before winter
https://ibb.co/Rb2s2Td
https://ibb.co/wCWf4Xs
https://ibb.co/QfNHJ1k
https://ibb.co/w6jnkC5
86 ss gone
85 ss new
85 z28 tpi
#1067395 - 07/23/20 01:02 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
Body back together . Working on lifting it off the old frame
86 ss gone
85 ss new
85 z28 tpi
#1067407 - 07/25/20 10:29 PM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
Edmonton,AB,Canada
https://ibb.co/myzt22S
https://ibb.co/zFLY4fc
https://ibb.co/FHcRcLH
Body is officially off. Now to clean up the underside where the frame was . At least I know my welds are strong
86 ss gone
85 ss new
85 z28 tpi
#1067543 - 08/07/20 01:36 AM Re: My 84 monte ss resto , floor pan and more [Re: 84ss355*4spd]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Looking great, im diggin that side shot with the qtr, door, fender, an rocker all black really looks like its comin together. If theres one thing someone could say about us is we are persistent for damn sure.๐Ÿ˜†
1025/thumbs/2011-07-17_18-59-41_848.jpg
by Martinez
961/thumbs/shifter_boot.jpg
by jrz126
681/thumbs/speedo.jpg
500/thumbs/DSCF0022.JPG
by Gruvin
527/thumbs/88SS_355TPI_1.jpg
