#1033911 - 01/03/16 08:44 PM
Re: I have a 350 chevy crate motor
[Re: ray6914]
SSLance
Is the dipstick in the block of the crate engine or in the oil pan itself?
#1033933 - 01/04/16 01:25 AM
[Re: ray6914]
SSLance
I'm still confused... lol... Which engine block do you want to use? What provision does it have for a dipstick?
Once we know that we just have to find a pan that fits that block.
#1033941 - 01/04/16 04:39 AM
[Re: ray6914]
rons87mcss
PA
I'm sorry, I'm just not sure what you are trying to figure out  Everything about your crate engine has already been mentioned several times in this thread. Since your crate engine was manufactured to be a direct replacement engine for various models of cars/trucks, it seems it has the provisions on BOTH the block AND the oil pan to allow for either a passenger side OR driver side oil dipstick. Whatever side you want to install the dipstick on, then the other side needs to have the plug installed in either/or/both the block and/or oil pan. Since the motor has a 2 piece rear main seal, then it would be similar to(but not exactly as) the 85 & older generation 1 small block Chevy engine. It isn't an engine that would have came from the factory installed in a production vehicle so it seems it is it's own 'breed'. I'm not trying to sound rude, but I seriously don't know exactly what you are trying to figure out. Do you want to know what year the engine is? It would be considered an 85 & older engine if it has the 2 piece rear main seal(which it sounds like it does/should) BUT that doesn't mean it will share the same oil pan that came on an engine factory installed in a production vehicle that is a 1985 or older vehicle. It is it's own design to allow for either/or oil dipstick location. Can't you just use the original(to the crate engine) oil pan(with both provisions for either/or side dipstick) and move the plug in the block to the opposite side of where you want the dipstick to be? Or don't you have the oil pan that came originally on the crate engine(with the provisions for the dipstick on BOTH sides)?
#1033945 - 01/04/16 01:05 PM
[Re: rons87mcss]
SSLance
Or don't you have the oil pan that came originally on the crate engine(with the provisions for the dipstick on BOTH sides)? I'm thinking that's it...but still not sure either. Sounds like the pan on it currently doesn't bump out on the driver side and there is a leak there? Doesn't sound like it is a dip stick issue as much as a pan seal issue.
#1033961 - 01/05/16 01:00 AM
[Re: ray6914]
johnz138
Sterling Heights, Mi
You got the car with this engine already in it u stated, why don't you just use the oil pan that it had? Do you still have the oil pan that came on the crate motor?
I think some people are confused on what your actual question is. Are you asking what oil pan you can use?
1987 Monte Carlo SS, Lightning Rod equipped, engineless/2004-R,Holley carb, edelbrock intake, heddman headers, moog,Iceman crossmember, energy suspension, eibach springs,so much more,no computer/emissions. http://www.cardomain.com/ride/2167110
#1033963 - 01/05/16 01:10 AM
[Re: ray6914]
johnz138
#1033966 - 01/05/16 01:19 AM
[Re: ray6914]
johnz138
As you know, that chrome one aint going to work. You're going to have to use the oil pan that has the 2 bumps. Clean it up real good, and it'll still look nice under there.
#1033973 - 01/05/16 05:52 AM
[Re: ray6914]
Fred SS
Glassboro, NJ
Just did a search on Summit Racing. Nothing came up showing a chrome oil pan with provisions for both DS and PS dip sticks. Maybe you can take the pan that came with the motor and have it power coated faux chrome.
87 SS, Harwood cowl induction hood, UMI trailing arms. Hooker 2050 TES Headers (Jet Hot Coated). Goodwrench 350, Ported TPI, Trick Flow 56cc alum heads, SLP runners, Comp Cams 260AH-12 cam, Trick Flow 1.5 roller rockers, Bilsteins, TCI 2400 stall converter, Ramcharger fans, Denny's 3.5" Driveshaft, GBodyParts GNX Wheels 18x8 & 18x9.
#1033976 - 01/05/16 01:13 PM
[Re: Fred SS]
ray6914
pittsburgh pa
thanks for all the info
#1033980 - 01/05/16 01:49 PM
[Re: ray6914]
SSLance
That would have been a great way to ask your question in your very first post! Good luck, I suggest painting or coating your current pan as well.
by ronjohn221
by tonys57chevy
by kpetry
by tovann
