#1033627 - 12/27/15 11:39 PM Your MCSS MPG
ILoveMyMonteCarloSS Offline
Dothan, AL
Hey Montes,
I just calculated my MCSS' MPG, it's 12.5mpg. Seems a bit low, maybe 3 miles or so to me. Especially those of you who still have the stock 305 and stock carburetor, what MPG is your MCSS getting?
#1033628 - 12/28/15 01:11 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
tomh115 Offline
tomh115  Offline
Russellville, AR
15 to 20. Sometimes less when I drive it like I stole it
1987 Monte Carlo SS Aerocoupe
Objects in mirror are losing
#1033629 - 12/28/15 01:25 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Dothan, AL
15 to 20 is what I'm finding all other places, I think She's burning rich. Thoughts?
#1033638 - 12/28/15 02:43 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
mannblk Offline
mannblk  Offline
NC
Is your computer and all the engine/transmission still in stock form? The ccc 305 and 200R4 should easily get 17 city and 24 highway mpg. If the computer, distributor and carb have been changed and the proper lock-up installed for the torque converter, you should still be in that same range. HTH
#1033639 - 12/28/15 02:46 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
WPV Offline
WPV  Offline
Key West, FL
I get 22mpg on the highway going between 75-77mph, now around key west, i get 12, but its ALWAYS stop and go traffic
Monte's I own
Monte's Ive sold
#1033640 - 12/28/15 03:16 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
tomh115 Offline
tomh115  Offline
Russellville, AR
Wouldn't the 85 have the TH350C transmission (or whatever the 3 speed auto was that time)? So it would be lower than the 86-88s that had the 200 4R Transmission.
#1033641 - 12/28/15 03:57 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
WPV Offline
WPV  Offline
Key West, FL
no the 85 was the first year of 3.73 gears standard and the 200-4r trans, so if its original it should have OD
Monte's I own
Monte's Ive sold
#1033651 - 12/28/15 07:23 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Very well could be a vacuum leak making the computer go rich. Have you checked the fuel mixture control solenoid dwell?
#1033656 - 12/28/15 10:01 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Originally Posted By: ILoveMyMonteCarloSS
Hey Montes,
How did you calculate mpg?
Since you just got the car, you may be suffering from skinny pedal right foot syndrome.
Drive the car for a month and check it again.
FWIW, I got about 18 on the highway.
#1033664 - 12/29/15 02:06 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Dothan, AL
upflying, I filled up the tank then took a photo of the odometer, once I needed more gas I filled up again and had the exact amount of gas I used, then I divided the the miles driven by the gas I used.
BuickRunner, forgive my ignorance, but, there is a computer controlling the fuel mixture on the carb? I thought that was all mechanical.
#1033667 - 12/29/15 02:33 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
You should be getting about 17 in town and up to 25 on the highway. Maybe you had some old gas in it. Check for some of the issues stated. I get the 15 in town and don't always drive it nice. Still have factory computer and running a 355 now.
#1033686 - 12/29/15 04:36 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Yes, there is a mixture control solenoid in the Quadrajet. You can hear it clicking when you turn the key. It is controlled by the computer behind the right kick panel.
#1033703 - 12/30/15 12:31 AM Re: Your MCSS MPG [Re: upflying]
That is how it should be if your car is stock. The computer controls the fuel mixture on the primary side of the carb, timing advance, knock retard, torque converter lockup, etc. These cars are prone to having their various systems hacked up by their former owners who didn't know what they were doing.
#1033705 - 12/30/15 12:57 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
86ttop Online grandpa
86ttop  Online Grandpa
I never really checked, but I could drive for 4 hours at highway speeds before I needed to get gas.
#1033707 - 12/30/15 01:11 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Dothan, AL
I talked to some guys at my O'reilly's(the ones who know there stuff), I told them about how she idols high sometimes, they said that could be causing high MPG. I guess I might just need to turn her on and off until she idols correctly until I can look into it properly(under the hood), I'll see if that make a difference.
#1033720 - 12/30/15 04:18 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
The car has 3 idle speed adjustments, there is the fast idle where the engine idles faster when it is still cold. Then there is curb idle where the idle speed kicks down to a lower speed after warm up. Then there is the A/C kicker solenoid which raises the idle speed when the A/C is turned on. The fast idle should be set at 2,000 RPM while the curb idle should be 650 RPM, you check both with the transmission in Drive.
#1033737 - 12/31/15 12:14 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
DO NOT CHECK THE CHOKE ON IDLE IN DRIVE only the curb idle after the engine is up to operating temperature!!!!!!!!!!!
#1033773 - 01/01/16 12:59 AM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
I have done it, but with a helper holding the brakes with wheel blocks.
#1033792 - 01/01/16 08:03 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Not the correct way,it's a no load setting.
#1033868 - 01/02/16 11:08 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
Well I won't argure with safety, still a good idea to have a helper when making these adjustments.
#1034291 - 01/15/16 05:34 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
NYmonteSS Offline
NYmonteSS  Offline
Elkton MD
8 mpg! but its fun !!! hehe
#1034713 - 01/30/16 09:45 PM Re: Your MCSS MPG [Re: ILoveMyMonteCarloSS]
jmireles Offline
jmireles  Offline
El Paso, Tx
So what's happened, have you made any progress?
in '08. 3K
614/thumbs/2008_Trunk_Enclosure_Pictures_014.jpg
by StripedSS
500/thumbs/IMG_1007s.jpg
by Turbo5
1104/thumbs/375368_10200235155830020_977019592_n.jpg
500/thumbs/20200422_222519.jpg
by Rodney
500/thumbs/db_Latham_Greens_8-13_0261.jpg
by nymonte
