#1033060 - 12/12/15 06:49 PM camshaft sensor ???
edward Offline
edward  Offline
phila pa
Hi guys Today I scanned my car for trouble codes came back as code 41 CAM sensor failure. Do we have a cam sensor in our engines???? If not why would it give me this code?? Is this due to something else that maybe failing. I have a haynes, chilton, and an original gm shop manual. In the haynes manual I find the code 41 that says No distributor reference pulses to ECM with engine running/ it says the problem could be poor electrical connection, open or short in circuit, defective distributor pick up coil: fault in the MAP or VAC sensor circuit. In the GM Service manual it states No distributor reference signal. I did a real time data scan monitored MAP sensor the sensor volts charged during acceleration so I am guessing MAP sensor is ok? Thank you for your help ED
#1033062 - 12/12/15 08:52 PM Re: camshaft sensor ??? [Re: edward]
Go by what you first stated.
No there is no cam sensor, it's directing you to the distributor.
#1033087 - 12/13/15 09:38 PM Re: camshaft sensor ??? [Re: edward]
Usually it has to do with the plug wires to close to the big wire harness from the distributor to the ecm.
500/thumbs/IMG_1453.jpg
by Billdo38
500/thumbs/Carbon_fibre_004.jpg
by 94ONLYSS
523/thumbs/P6240078-small.JPG
by ProTourAero
500/thumbs/Engine3.JPG
by Ted88SS
500/thumbs/IMGA0007.jpg
by CT88
