#1031902 - 11/10/15 11:47 PM Looking for metal strips for pull straps - doors
QuikZilver Offline
QuikZilver  Offline
Delray Beach,FL
I am looking for the metal strips (generally not painted) that attach to the door shell that the pull straps are screwed into. I need both sides. If you have and are willing to part with, hit me up. Shipping would be to 33445. Thanks in advance!!
1986 Monte Carlo SS - lots done to it! And more to come!!
2007 GMC Yukon XL
#1031905 - 11/11/15 01:23 AM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
Your local parts store most likely has them. Usually in the help section. Been a
While since I even looked but they always used to have them.
#1031915 - 11/11/15 02:00 PM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
Mick Offline
Mick  Offline
O'Fallon, MO USA
I think I have a pair will check tonight
#1031916 - 11/11/15 02:24 PM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
LXXXIV SS Offline
LXXXIV SS  Offline
Lower Peninsula, Michigan
My 84SS pull strap metal pieces attach to the door panel itself, not the door shell. Maybe your car is different, though?
#1031931 - 11/11/15 11:33 PM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
They do pop rivet to the door panel or at least mine did.
#1031943 - 11/12/15 05:26 AM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
78-80 Monte door strap pulls screw threw the ends of the metal strips and into the door shells-not sure exactly what year GM began to rivet the strips to the upper door panel but it was a better idea. The 78-80 cars had no such extra support behind the panels like that.
gbodyparts1234@yahoo.com
HARNESSWORX
#1031959 - 11/12/15 05:57 PM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
the screws still go thru the strips and hold the pull straps better to the door. IIRC
#1031960 - 11/12/15 07:30 PM Re: Looking for metal strips for pull straps - doors [Re: 86ttop]
LXXXIV SS Offline
LXXXIV SS  Offline
Yep, you're right.
#1031970 - 11/12/15 10:48 PM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
QuikZilver Offline
QuikZilver  Offline
Delray Beach,FL
Just found a set from member: Derrick. Thanks again Derrick!!!
2007 GMC Yukon XL
#1032167 - 11/18/15 02:09 PM Re: Looking for metal strips for pull straps - doors [Re: QuikZilver]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
On my 80 Monte, I decided to use a riv-nut gun to press 8mm nuts into my door hardware-so instead of using a big ole coarse machine screw I can use an actual machine bolt. I hate when them damn pull straps get loose-pits for sure....lol
HARNESSWORX
633/thumbs/IMAGE_00003.jpg
by sside25
1129/thumbs/downsized_0806130651.jpg
by GBODY88
500/thumbs/monte101.jpg
by johnnybravo21
510/thumbs/100_0325.JPG
by 85_SS
500/thumbs/ssexy_wash_012.JPG
by Monster
