#1030148 - 09/30/15 09:16 PM Frame Notching question
Keithss Offline
Keithss  Offline
Jackson,mi
Does notching the rear of the frame for larger tire size weaken the frame? To me, even with a 1/4 inch plate wielded in, it seem like it would still want to twist.
I am thinking about doing it, but concerned about strength.
#1030194 - 10/02/15 02:26 AM Re: Frame Notching question [Re: Keithss]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
did a few gbodies, this was my last one. click on link below it will take you to some pics. there should be about 10 there, just hit the right arrow on the pic to continue. this notch went all the way to the center of the frame. then re-welded the factory piece back on, i did use 1/4" plate at the notch backs at the front and rear. not shown, lost pics. i hole sawed 3 1 1/2" holes and put tubing thru the frame and welded them in. really strong result.
http://s213.photobucket.com/user/pazzo19...sort=3&o=36
#1030195 - 10/02/15 02:27 AM Re: Frame Notching question [Re: Keithss]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
Its reinforced when it is done... And most also add bracing as well. But honestly all the torsion of the frame is located in the middle, not behind the tires. Frankly the back end of the chassis is not doing much as the control arm pick up points are forward of the axle. Its not like a leaf spring car that the rear frame rails support the vehicle.
2015 GMC Sierra Denali
#1030202 - 10/02/15 03:46 AM Re: Frame Notching question [Re: Keithss]
RenoReno2 Offline
RenoReno2  Offline
Chicago, IL
My only concern with doing this on a car that's driven on the road is getting rear ended the frame has been severely compromised in this situation
88 Monte SS
#1030546 - 10/10/15 08:52 AM Re: Frame Notching question [Re: Keithss]
TerMonteNatorSS1986 Offline
Edmonton, Alberta
I don't know the exact setup, but usually in metal fabrication, you want to avoid sharp angles as much as you can in order to avoid stress lines concentrating in one area, and causing a fracture.
854/thumbs/100_7995.JPG
by FuzzyDnkn
500/thumbs/monte56.jpg
by tovann
by O.G.
500/thumbs/monte_7.JPG
by Monte83
500/thumbs/IMG_1450.jpg
by Billdo38
