#542452 - 03/08/08 08:25 PM Tube grille build
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
I have been wanting to do this for a while and I finally found a junk nose to experiment with(thanks John!!) so today I went to the local parts store and bought a bunch of 5/16" brake/trans lines and got started. I needed some strap metal to drill some holes in to hold the lines and got lucky at the local Farm and Home store and found just what I needed, anyhow 2.5 hours and $30 later I have a pretty good looking grille for my SS.
Here is the original nose before cutting:
Here is the nose after I cut out the stock grille, the nose becomes pretty flimsy without it. I know I didn't smooth the nose out like I should have but this nose is just a throwaway nose used for practice on this project.
Here is a picture of the strap steel I found that already had the holes in it, the holes were 3/8" but work just fine for this project.
I cut a third section the same length and cut it in half lengthwise to give me a center section.
Here is a shot of the tubes set in place so I could mark them at the center and start bending the tubes to match the profile of the nose.
Here is a shot of how I set up the grille to get it welded up, I put a couple of spare pieces of the strap metal to space the tubes evenly, I welded up one end and slid the spacers over then welded up the center section then removed the spacers and welded up the last end piece then I removed the entire grille and finished welding the pieces up.
Here is the grille welded up and ready for a test fit:
Here is the grille set in the nose, the grille is just held in from the back with a pair of needle nose vice grips.
I still need to modify the center support so I can support the center of the nose as it is pretty flimsy without the factory grille installed, I will probably add a few more braces between the middle of the grille and the end so I can support the nose a little better.
There is a lot of work that went into this as well as knowing how to gas weld and bending the tubes to match the contour of the nose. I would not suggest just anyone doing this unless you have the proper tools and are willing to take the chance of ruining your nose.
#813638 - 07/30/10 04:48 AM Re: Tube grille build [Re: ss4ever]
gbodydude496ci Offline
scranton,pa
how did it every come out looking?
85'monte ss race car with a cage and notch frame.soon to have my bbc and t400 trany wih a 9inch rear.86'monte ss sbc,200r4 plan for it.
#1024775 - 05/23/15 01:51 PM Re: Tube grille build [Re: gbodydude496ci]
Mitch1212 Offline
Mitch1212  Offline
Brantford, ON
Nice work! What would you put on the lines to finish them? Paint, or powder coat of some sort? Well done.
#1038393 - 04/26/16 11:49 PM Re: Tube grille build [Re: ss4ever]
the nitro man Offline
greeneville, tn
that does look pretty sweet.
85 ss monte carlo
new 406 on the drawing board
350 turbo 3500 stall
GN 8.5" 3.42 posi
500/thumbs/MVC-012S.JPG
by hot rust
500/thumbs/carlo5.jpg
by rj
500/thumbs/hot2_2_.jpg
by blkcharlotteman
by MikePEI
500/thumbs/rims_003.JPG
by bootlegger
