#1002190 - 05/10/14 04:44 AM
T-56 flywheel question
zmans84ss
miami,fla
Hello everyone. Recently got my car out of storage and working on it again after a long layoff. Before I put it in storage I swapped in a t-56 out of a 95 tran am ( lt-1) engine is 350 Crate motor with one piece rear main seal. T-56 was rebuilt and I used new clutch and flywheel vehicle specific to the trans am. It has a very noticeable vibration and it just doesn't run correctly. Should I have had the flywheel balanced? I can feel the vibration on the floor directly in front of the drivers seat. Most of what I have read is about mating the t-56 is to a two piece rear main seal so I'm unsure how to pursue this issue. Any ideas would be greatly appreciated.
#1002248 - 05/11/14 09:50 AM
Re: T-56 flywheel question
[Re: zmans84ss]
zmans84ss
miami,fla
I remember the flywheel had no weights at all. The flexplate is long gone and I don't remember if it had any weights. I think I should have balanced the flywheel and flexplate together but hind sight is always 20/20. Guess i am up the creek with out a paddle now!! Have no idea if the engine was externally or internally balanced. It's been in the car for about seven years now.
#1002271 - 05/11/14 03:23 PM
[Re: zmans84ss]
zmans84ss
miami,fla
I thought since it had no weights that it was neutrally balanced. The engine is one piece rear main seal so it's 86 up block but not an lt-1. The thought of taking the transmission out all over again is not pleasant but I'm getting this right whatever it takes. Thanks everyone....
#1002280 - 05/11/14 05:15 PM
[Re: zmans84ss]
zmans84ss
miami,fla
I thought this was a simple bolt in as well since the expensive 2 piece rear main seal flywheel wasn't going to be needed. I'm thinking that I should have had the flywheel balanced so I suppose I could remove the flywheel and have it balanced but I want to solve the problem correctly. I would prefer a bolt in solution specific to this application but at this point I'm still debating how to pursue this issue. I accept that modifying the car will create these problems.
#1002307 - 05/12/14 12:24 AM
[Re: zmans84ss]
zmans84ss
miami,fla
So then the lt-1 flywheel I used that had no weights on it was not neutral balance as I thought? After countless hours in this the consensus is that most 1 piece rear main seal if not all are internally balanced but I have to continue the investigation. My next step to contact a few aftermarket flywheel dealers and get their information on this. I hope my situation alerts others as to avoid my mistakes.
Good luck all
#1002314 - 05/12/14 01:15 AM
[Re: zmans84ss]
zmans84ss
miami,fla
340 h.p. 350 crate engine from eBay vendor Phoenix musclecar. Crank is one piece rear main seal so I know the block is 86 up.
#1002422 - 05/13/14 10:42 AM
[Re: zmans84ss]
zmans84ss
miami,fla
I'm contacting the company to get that information. Depending on what they tell me I will decide what course of action I'm gonna take. Maybe replace the flywheel with aftermarket or simply balancing the flywheel I have now. Need more information before moving forward though.
Thanks again
#1002568 - 05/15/14 04:36 PM
[Re: zmans84ss]
zmans84ss
miami,fla
As per the engine company my crate motor was internally balanced. I'm gonna have the the factory flywheel neutral balanced.
by GearHeadDrew
by BaerMonteSS83
by troublesnc
by kpetry
by PoorBoysRacing
