#957562 - 01/05/13 05:16 AM which bigger brakes inside Monte SS aluminum wheel
novaderrik Offline
novaderrik  Offline
Ashby, MN
i'm running Monte SS aluminum wheels on my 86 Camaro, and looking to upgrade the brakes. looking at the factory 12" setups to keep it cheap and easy to get parts for down the road.
i know from past experience with my 71 Nova that the light duty C4 Vette brakes will fit inside older steel 15X7 Z/28 wheels with lots of room to spare, but how about the aluminum Monte wheels?
do LS1 Camaro brakes fit?
how about a hybrid that uses 70's Corvette rotors and either LS1 F body or HD C4 Vette calipers?
74 Monte Carlo cruiser
#957618 - 01/05/13 10:16 PM Re: which bigger brakes inside Monte SS aluminum wheel [Re: novaderrik]
Have you thought about just doing the factory 1LE front brake upgrade, here's a Spohn kit,
http://www.spohn.net/shop/1982-1992-GM-F-Body/Brakes-Accessories/1LE-Front-Brakes-Components/
Or you could part it out yourself with new, less expensive rotors, rebuilt calipers, along with new caliper brackets/hoses/ pads for less than $500.
#957669 - 01/06/13 09:09 AM Re: which bigger brakes inside Monte SS aluminum wheel [Re: novaderrik]
novaderrik Offline
novaderrik  Offline
Ashby, MN
thought about it, but i'm looking for a slip on rotor instead of the factory integrated hub, and would prefer a thicker rotor such as the LS1 or C3 Vette rotors.
besides, i don't think the 1LE will fit under the MCSS aluminum wheel..
i've got 16" GTA's that i know will clear the light duty 12" C4 brakes and maybe the LS1 brakes, but the C4 brakes use the thinner rotor and i don't know if either setup clears the SS wheels. figured someone on here would have tried some of these combos and could relay their experience..
#957689 - 01/06/13 03:26 PM Re: which bigger brakes inside Monte SS aluminum wheel [Re: novaderrik]
Monte_ExpreSS Offline
Oshawa, Ont. Canada
The LS1 brakes won't fit with a 15" rim, but they will clear the 16" GTA's with a spacer added due to the extra mounting pad depth needed so the caliper doesn't hit.
#957701 - 01/06/13 06:24 PM Re: which bigger brakes inside Monte SS aluminum wheel [Re: novaderrik]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
I believe there is a member with ls1 rear brakes under stock aluminum wheels. I know the rears fit on mine when I had to move my car.
2015 GMC Sierra Denali
#957710 - 01/06/13 08:21 PM Re: which bigger brakes inside Monte SS aluminum wheel [Re: novaderrik]
Oshawa, Ont. Canada
Sorry, I should of been clearer, The fronts won't fit. I've never tried the rears but Jameson is correct, AxisG has LS1 rears with the stock SS wheel.
852/thumbs/1981_mont_carlo.jpg
by PoorBoysRacing
500/thumbs/Monte2_mid.JPG
by woolf
500/thumbs/06-08-07_1245.jpg
by ETHIOSLS
500/thumbs/parts2.jpg
by go3and8
500/thumbs/RR.jpg
by Greg Talbott
