Page 2 of 2 1 2
#971061 - 05/08/13 02:25 PM Re: Head light warning buzzer [Re: Richie Cat]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
More than likely the buzzer is going bad, but reach up underneath the dash on the left side and make sure it is in tight. Also possible, but unlikely, that the connectors on the buzzer could need cleaned of and scuffed up to get a good connection. When you do this procedure, I would have a replacement buzzer on hand ready to install.
#971062 - 05/08/13 02:34 PM Re: Head light warning buzzer [Re: Richie Cat]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
Sounds like the buzzer is going bad. They are hard to get to, so try to reach there and give itt a couple of light taps then test it. if no improvement, take the buzzer out and clean the connections then reinstall it and test it. If no improvement it is more than likely the buzzer. Have a replacement on hand when testing.
#971155 - 05/09/13 04:18 AM Re: Head light warning buzzer [Re: Richie Cat]
dw329 Offline
dw329  Offline
Beersheba Springs, Tn.
Thanks, I'll check first for loose fit.
#1016803 - 12/05/14 09:59 PM Re: Head light warning buzzer [Re: Richie Cat]
WaSSted Offline
WaSSted  Offline
Kennewick
I know the buzzer is supposed to be annoying so you will turn off the lights, but has anyone replaced their buzzer with something a little more up to date sounding?
Kirk Herres
#1016954 - 12/08/14 07:24 PM Re: Head light warning buzzer [Re: Richie Cat]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I've thought about that too. I know RS has universal buzzer or chimes but I haven't heard them-so not sure if they're cheesy sounding or not. I built a auto-on/delay off headlight/courtesy lighting harness for my Shortbox pickup project and thought about adding a chime but I don't know how practical it would really be other than the coolness of it.
I would look in the yards for newer vehicles for chimes tho-european may be the best....?
gbodyparts1234@yahoo.com
HARNESSWORX
Page 2 of 2 1 2
500/thumbs/monte_carlo_0700.jpg
by 85lolo
500/thumbs/Z65_Paul-17.jpg
564/thumbs/oscars_LS_MONTE_CARLO_003.jpg
by Big Reazon
1189/thumbs/DS_Door.jpg
by Joe87monteSS
564/thumbs/oscars_LS_MONTE_CARLO_010.jpg
by Big Reazon
