#944600 - 09/06/12 07:36 PM LT1
305hoSS Offline
305hoSS  Offline
Millstone, NJ
anyone know off hand what changes are necessary for installing an LT1 from a 1992 Vette?
87 ss- Almost sold my SS then changed my mind...Now working on an LS swap
#944607 - 09/06/12 08:55 PM Re: LT1 [Re: 305hoSS]
daveSS1987 Offline
daveSS1987  Offline
Enfield, CT
You would need the LT1, complete wiring harness and computer, a FI fuel tank with electric pump, new fuel lines, electric fans, and whatever other accessories are on the LT1 (AC, alternator, power steering pump) would need to be adapted to fit the Monte. I think the motor mounts are in the same place on the LT1 but am not positive.
#944616 - 09/06/12 09:34 PM Re: LT1 [Re: daveSS1987]
dyrt Offline
dyrt  Offline
yardville nj
If you are planning on running a/c you might have to come up with a solution. If you have the vette accessories you might be better off than i was. I used b-body accessories and due to the location of the a/c pump, i had to drill new motor mount holes in the cross member almost exactly an inch back on the passenger side and the mount on that side had to be moved back. if i recall correctly, there are extra mount holes in the block or a special mount from the b-body to do this but i can't remember which. Other than that, everything listed above it needed. If your engine has provisions for a tv cable you can just use a 200r4 or 700r4 which will let you use your mechanical speedo.
1986 regal limited, '95 lt1, lt4 cam,1.6:1 rockers, t-56, ram hdx clutch kit, hurst billet plus, '96 TA buckets, canteen metallic paint, ls1 front brakes, 3.73 posi gn rear.
#944637 - 09/07/12 01:58 AM Re: LT1 [Re: dyrt]
brokenmonte1987 Offline
Chicago, IL
I'm just finishing up this swap now, dyrt and Dave are right on. Motor mounts are the same, just use the stock mounts and clamshells. The Vette accessories and brackets are all centrally located on the block, so frame issues with the ac compressor should be no problem. I uses a b body setup and the compressor hit the frame, used a 1le ac delete pulley and gave the frame the slightest bit of love just for extra piece of mind. 92 would be an early LT1 so not too sure about the tv cable setup. Look up spudman mike's lt1 swap guide, I used it as my main reference and it's great. Good luck!
1987 Monte SS, LT1/4l60e swap (done-ish). 12 bolt, SSM upper and lower control arms, 3.73 posi. G-Force crossmember, bilstein/ KYB shocks, Eibach front springs. 3" Harwood Cowl, headers, dual exhaust, custom cold air intake, bolt ons....
1988 Monte SS- stripped bare and dumped.
1992 Camaro rs, 305 tbi mostly stock ish. Pokey but fun to drive!
#944668 - 09/07/12 01:15 PM Re: LT1 [Re: brokenmonte1987]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
Thanks guys! the 92 vette's didn't have the 4l60e, they had a 4l60 (i'm guessing a variant of the 700r4) so i hope i'm able to use my 2004r. Brokenmonte, is the swap guide here on the site or is can i do a search for google?
#944712 - 09/07/12 11:36 PM Re: LT1 [Re: 305hoSS]
Chicago, IL
There should be a link here on the site someplace if you do a search, thats where I found it (then printed it out at work!). Google probably works too if all else fails. Not mentioned earlier but you'll also need shop manuals for your Monte and the Vette to help with the wiring, which is the biggest pain in the xxxx of the swap.
Are you reworking a stock harness or getting an aftermarket one? Either way you'll need to wire gagues in your dash to lt1 sensors and computer and you'll need the books and whatever other diagrams you can pull off the web to help ya along.
#944733 - 09/08/12 10:35 AM Re: LT1 [Re: brokenmonte1987]
JAWSS Offline
JAWSS  Offline
Ft. Hood, TX
I tried finding Spudman Mikes PDF. It seems to have been removed.
86 Monte Carlo SS T-top
69 Cutlass S Convertible
12 Cadillac CTS-V Wagon
#944734 - 09/08/12 10:49 AM Re: LT1 [Re: JAWSS]
dyrt Offline
dyrt  Offline
yardville nj
i searched the url and clicked quick view in google and it can still be accessed. try this link and see if it work. mind you you might need a gmail account for it to work. if you can't access it let me know, pm me an email address and i will email it to you in pdf form. warning, it is 8.5 megs so if you don't have broadband...........
https://docs.google.com/viewer?a=v&q=cache:CWeGcY2zPt8J:home.comcast.net/~spudmanmike/scrapbook.pdf+&hl=en&gl=us&pid=bl&srcid=ADGEESh2Oo3H2WdNCwHPPXNgPWGQQxbuVEWWu-FhOo0ytoVrArpuV5o-qlZSNRm3K70fZtcMhTtxKwc6B1mV3T1bn7aP-pj3Jp4WfmgLpG0XcGsPMjhrjGBDZocRtUAK7o30DbTdDwAr&sig=AHIEtbRlDNu1olKsTdeO4gvNg_6VT-pJ1w
#944978 - 09/10/12 03:21 PM Re: LT1 [Re: dyrt]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
Thanks dyrt it works
#965653 - 03/19/13 03:52 PM Re: LT1 [Re: 305hoSS]
87SS-ZZ3 Offline
87SS-ZZ3  Offline
Pantego,NC
So how is this going? I'm trying the same swap and I"m keeping AC.
78 Malibu LT1/T56 build thread
96 Impala SS
#965673 - 03/19/13 10:17 PM Re: LT1 [Re: 305hoSS]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
87ss-zz3 this was an idea for an lt1 that was available but the deal fell through so I never proceeded.
#965817 - 03/21/13 12:50 AM Re: LT1 [Re: 305hoSS]
jmireles Offline
jmireles  Offline
El Paso, Tx
Are you still looking for an LT1 or might you go with the LS route?
in '08. 3K
#966288 - 03/24/13 04:46 PM Re: LT1 [Re: 305hoSS]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
Not quite sure to tell you the truth. I've been looking at pretty much everything from LS, LT, BBC, to even just rebuilding the L69.
by Monster
523/thumbs/DSC_0656.jpg
by Dad's SS
1164/thumbs/IMGP6649small.jpg
by Witman69
523/thumbs/DSC_0633.jpg
