#944536 - 09/06/12 03:07 AM Floor shifter plastic cover?
ham Offline
ham  Offline
bristol,va
Were can you get a replacement for the black plastic cover that is under the console that hides the shifter bracket?
#944540 - 09/06/12 03:40 AM Re: Floor shifter plastic cover? [Re: ham]
Mike's Monte's has them.
#944565 - 09/06/12 01:26 PM Re: Floor shifter plastic cover? [Re: 86ttop]
ham Offline
ham  Offline
bristol,va
Thanks.
#944575 - 09/06/12 04:04 PM Re: Floor shifter plastic cover? [Re: ham]
gmguy3car Offline
Authorized Vendor
gmguy3car  Offline
Authorized Vendor
Silverdale,Wa
#944596 - 09/06/12 07:12 PM Re: Floor shifter plastic cover? [Re: gmguy3car]
ham Offline
ham  Offline
bristol,va
Just ordered it thanks.When I go to redo my interior I will be giving you a call on some door panels.
#944683 - 09/07/12 05:24 PM Re: Floor shifter plastic cover? [Re: ham]
gmguy3car Offline
Authorized Vendor
gmguy3car  Offline
Authorized Vendor
Silverdale,Wa
Sweet, thank you, dropped it in the mail yesterday.
#945065 - 09/11/12 02:05 PM Re: Floor shifter plastic cover? [Re: gmguy3car]
ham Offline
ham  Offline
bristol,va
I got the part thanks. How does it go in I never had one in a monte carlo before. I took off the console cover but it has no were for it to slide into or attach? Maybe I am missing something?
#945079 - 09/11/12 04:24 PM Re: Floor shifter plastic cover? [Re: ham]
JMonte7892 Offline
JMonte7892  Offline
Baltimore, MD
you have to take the handle off. If you put the car in 1st gear (with e-brake on) you can see that there is a pin in the front of the shifter, pull the pin out with a flat head screw driver and the handle will slide right off, and you can drop the cover right on.
#945103 - 09/11/12 11:50 PM Re: Floor shifter plastic cover? [Re: JMonte7892]
Aeroaddict Offline
Aeroaddict  Offline
Fairfield County ,CT
If you took off the cover, then you already removed the handle. The insert just slides down the shifter arm and rests on top of the shifter itself. It just lays under the cover, and moves with the shift arm.
#945105 - 09/12/12 12:08 AM Re: Floor shifter plastic cover? [Re: Aeroaddict]
ham Offline
ham  Offline
bristol,va
It seems to be too long. Should I trim it?
#945206 - 09/13/12 02:07 AM Re: Floor shifter plastic cover? [Re: ham]
Aeroaddict Offline
Aeroaddict  Offline
No, it should'nt need triming, how is it to long?
#945532 - 09/16/12 12:11 AM Re: Floor shifter plastic cover? [Re: Aeroaddict]
ham Offline
ham  Offline
bristol,va
After taking another look I have figured it out. You have to bend it under the shifter bracket.
995/thumbs/44.jpg
by knight77
500/thumbs/monte_engine1.jpg
by 85lolo
1126/thumbs/1986_2.jpg
by Rich S
500/thumbs/009.jpg
by mdecker211
