#944044 - 09/01/12 07:31 PM NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
Fresh off the dyno, 980 HP, 780 Torque
Dart aluminum block, 4.600 bore, 9.780 deck, .904 lifters, .400 raised cam
Callies Magnum Plus crankshaft, 4.250 stroke
Carrillo rods, with upgraded CARR bolts, 6.385 long
CP Pro series pistons with gas ports.
CP wrist pins .180 wall
CP Pro series ring set .043 x .043 x 3.0mm
Comp Cams custom roller cam, 54mm core
Comp Cams .904 roller lifters
Trend pushrods, 3/8, .135 wall
Jesel shaft rockers 1.70 ratio
Jesel belt drive
ATI balancer with built in crank trigger
Clevite H-series rod & mail bearings
Durabond Camshaft bearings
Dart Race Series 370 heads with full port
Xceldyne Titanium intake valves 2.300
Manley Extreme duty stainless steel Exh valves 1.880
Comp Cams Titanium retainers
PAC valve springs
Comp Cams hardened locks
Isky spring locators
ARP head studs
GM aluminum Chevy logo valve covers
Edelbrock Super Victor port matched intake
Stef’s aluminum oil pan with kick out
Melling anti cavitation HV oil pump
Moroso hardened oil pump drive rod
MSD billet slip collar distributor
Holley 4500 series carburetor
HVH blended carb spacer
CSR electric water pump
CZ vacuum pump kit
Mini Alternator
All new parts, professionally engineered, machined, assembled, blueprinted, and dyno tested by a race engine shop in North West Indiana.
The engine never left the shop after the dyno, and is still in the race shop.
All top notch / top name parts here, Dart, Callies, Carrillo, CP, Jesel, ATI, MSD, Comp Cams, Melling, HVH, Exceldyne, PAC, etc.no Eagle, generic, or import parts you see in the bargain engines.
Parts, labor, and dyno testing for this engine would be over $30,000.00.
Nice bracket engine for door slammer or dragster, or nice Pro street engine for Chevelle, Camaro, or Nova if race fuel isn’t an issue. Oil pan will fit stock chassis GM cars.
Standard deck height block & conventional style exhaust ports will accept standard (non custom) headers.
How many people can say they have a 1000 HP normally aspirated Pro street car?
Nothing is on the ragged edge, will also be a great bracket engine without being hard on parts. Something you can run for a number of seasons without freshening up, or run forever in your Pro Street car.
Dyno sheets available, re-dyno possible if you need to see the numbers.
$20,000.00, that’s 2/3 of what it cost to build.
219-926-9794, Cell 219-746-0445, protouraero@comcast.net, serious inquires only please, no low ballers, this is not a desperate sale, ask for Mike.
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18° Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#944232 - 09/03/12 10:41 PM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: ProTourAero]
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
Very nice engine Mike.
Lemme check my couch cushions and I'll get back to ya!
#944261 - 09/04/12 02:34 AM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: MY FYN 79]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
This thing sounds awesome. JLP, when you want to upgrade ill take that sbc off your hands.
#944329 - 09/04/12 08:03 PM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: 200kSS]
Hi Scott,
Very impressive motor. Your PM mailbox is filled-up, and I know you wrote "serious inquiries only," but may I trouble you for one piece of information? How much does this engine weigh?
Thank you,
#944580 - 09/06/12 04:42 PM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: MAP]
ak forty seven Offline
Southampton, NJ
Sounds like a monster!!! you build small blocks?
#944741 - 09/08/12 02:49 PM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: ak forty seven]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
Sorry for the delay with replying:
Jeremy: Dig Deep.
MAP: It's Mike, not Scott, and I will check on the weight, we have a scale at work.
AK: That's what we do at work, what did you have in mind?
I am offering a Bird Dog $$$ for help with a sale, if someone here refers someone else.
I have added a few pictures.
www.protouraero.com
#944761 - 09/08/12 06:44 PM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: ProTourAero]
Hi Mike,
Apologies about getting the names crossed. Thank you about the weight measurement.
#945111 - 09/12/12 12:29 AM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: MAP]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
MAP, and other interested partys:
The engine weighs 500 LBS.
Pretty light for a big big block.
www.protouraero.com
#945174 - 09/12/12 09:11 PM Re: NEW ALL ALUMINUM 565 C.I. Big Block Chevy, 980 HP [Re: ProTourAero]
Hi Mike,
Thanks - 500lb is light indeed for any BBC! 500lb might be close to an SBC with an iron block and aluminum heads, for example. Very nice indeed.
1129/thumbs/46.JPG
by GBODY88
500/thumbs/DSC_0011.JPG
by wanadrv
500/thumbs/montewis2.jpg
by fanta
560/thumbs/MM_04_17.jpg
by NYmonteSS
612/thumbs/mon.jpg
by Mirada Mama
