#941733 - 08/10/12 02:17 AM FYI directionals / tail lights not working
bad88ss Offline
bad88ss  Offline
somewherein, fl
I had a problem where my directionals were not working (flashing) and tail lights wouldn't come on. I located a bad ground locally near the driver side tail light. That was the culprit. It was a little confusing because it would touch metal and the lights would be weak (that was my clue it was a ground) then lose contact and no lights. Easy to find and fix if you have the same problem.
#942040 - 08/13/12 10:10 AM Re: FYI directionals / tail lights not working [Re: bad88ss]
84supersport Offline
Louisville, KY
Haha, I had a loose ground in the Jeep, whenever I hit the brakes the enone would act like it was starving for fuel. Turned out the pump and tail lights shared a ground location and the bolt had worked it's way loose.
500/thumbs/Lamp_Bulb_Data.jpg
by Ole Blue
500/thumbs/Photo0183.jpg
by 1BadMonte
500/thumbs/IMG_1234_small.jpg
by mattvintage69
by amendez86
500/thumbs/Picture_044.JPG
by SPLATT
