#941176 - 08/04/12 09:09 PM 200-4r tranny are these any good
unclejesse Offline
unclejesse  Offline
dayton, ohio
i have a 200-4r tranny i believe this may be the resoning for my problems but not sure i've done everything possible to this motor without spending 1000's on it but my question is I done alot to my car to get it to power brake but it just wont do it, it will just bog out an die but i can floor it after im rolling bout 5 to 15 mph an the back tires will light up on it. this has been a real pain in the butt for me I've done all the following this to it an have noticed no power increase, Headers, true duals, aftermarket hei dist. comp cam, gear drives, went from a 2.41 rearend to a posi 3.23 gear brnd new converter (got robbed guy told me it was 2500 stall which once installed it had no stall then when i called the company they said their converters change gears at 2500) anyways then changed the motor to a 350 bored 30 over with 2.02/1.60 heads i think they are. just cant get it to power brake for nothing im thinking its this tranny anyone agree?
#941178 - 08/04/12 09:16 PM Re: 200-4r tranny are these any good [Re: unclejesse]
84supersport Offline
Louisville, KY
Doubt it. What carb are you running? I ask because you said you installed an aftermarket HEI. You need a computer distributor if you are still using the computer controlled Q-Jet. Also the cam may be too big for use with the computer. The computer may be running in limp mode causing a full rich condition.
#941180 - 08/04/12 09:27 PM Re: 200-4r tranny are these any good [Re: 84supersport]
unclejesse Offline
unclejesse  Offline
dayton, ohio
edelbrock 600 model 1406
#941198 - 08/05/12 12:27 AM Re: 200-4r tranny are these any good [Re: unclejesse]
Gruvin Offline
Gruvin  Offline
Texas
look at extreme automatics 200-4R, it will last up to a 10.90 ET in the 1/4 mile
http://www.extremeautomatics.com/transmissions/2004r.html
They are in Cincinnati...
#941221 - 08/05/12 02:46 AM Re: 200-4r tranny are these any good [Re: Gruvin]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
What kind of cam are you running, and did you tune the carb?
#941271 - 08/05/12 09:49 PM Re: 200-4r tranny are these any good [Re: unclejesse]
84LS1T56SS Offline
84LS1T56SS  Offline
Central, Arkansas
I just have to ask, what company made the convertor and told you it "changes gears"?
#941342 - 08/06/12 04:48 PM Re: 200-4r tranny are these any good [Re: 84LS1T56SS]
unclejesse Offline
unclejesse  Offline
dayton, ohio
Can't remember the company name but he sells on eBay just type in "cheap-turbo" an u will see everything he sells the converter was supposed to be a 2300-2700 stall for a 700r4 bought it put it in an there was no stall when I contacted him he said it don't change gears til 2300-2700 rpm
#941388 - 08/07/12 12:27 AM Re: 200-4r tranny are these any good [Re: 84LS1T56SS]
L69FullRoller Offline
Rochester, NY
Originally Posted By: 84LS1T56SS
[quote=unclejesse]i have a 200-4r tranny i believe this may be the resoning for my problems but not sure i've done everything possible to this motor without spending 1000's on it but my question is I done alot to my car to get it to power brake but it just wont do it, it will just bog out an die but i can floor it after im rolling bout 5 to 15 mph an the back tires will light up on it. this has been a real pain in the butt for me I've done all the following this to it an have noticed no power increase, Headers, true duals, aftermarket hei dist. comp cam, gear drives, went from a 2.41 rearend to a posi 3.23 gear brnd new converter (got robbed guy told me it was 2500 stall which once installed it had no stall then when i called the company they said their converters change gears at 2500) anyways then changed the motor to a 350 bored 30 over with 2.02/1.60 heads i think they are. just cant get it to power brake for nothing im thinking its this tranny anyone agree?
Yes good question.
#941394 - 08/07/12 01:29 AM Re: 200-4r tranny are these any good [Re: L69FullRoller]
unclejesse Offline
unclejesse  Offline
dayton, ohio
this is what the guy replied when i email him "With our torque converter, your car will start moving as soon as you release your brake and hit gas. When you hit gas, it will shift faster at 2300-2700 stall for street performance (which is better performance than corvette converter). I believe you were looking for racing converter which delay launch at higher rpm just like in race track."
#941411 - 08/07/12 03:24 AM Re: 200-4r tranny are these any good [Re: unclejesse]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
Sounds like the guy has no idea what he's selling or talking about.
2015 GMC Sierra Denali
539/thumbs/DSC01018-1.JPG
by Performance
500/thumbs/14522757_10153679104326642_5684843565357108088_n.jpg
by WESTWOODSS
500/thumbs/86ss2.png
by sawmillman
500/thumbs/PC110332.jpg
by 02intimidator
749/thumbs/rear2.JPG
by sideways
