Page 2 of 2 1 2
#940745 - 07/31/12 08:58 PM Re: Best Radiator/Fan combo for the $ [Re: MAP]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
I had a radiator company build me a 3-row heavy duty one and used a twin electric fan setup from a Ford Explorer. I programed my '830 computer chip to turn them on at 160 deg F.
#940807 - 08/01/12 02:21 PM Re: Best Radiator/Fan combo for the $ [Re: Phil87SS]
DiamondSnake Offline
Québec, QC
Thanks for all the information people! smile
It is very helpful smile
@gmachinz, i'm not sure if you answered that question earlier, just wanted to know where you mount your relay setups?
#940836 - 08/01/12 09:55 PM Re: Best Radiator/Fan combo for the $ [Re: DiamondSnake]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Well, I like to mount them directly on the fan shroud down low just for easy access and to keep the power lead runs as close to a 12V source as possible to minimize voltage drop-but, I can build them to suit a customers needs based on where he/she wants to put them. Once I know what kind of relay kit you would need, then the decision on you rpart needs to be where do you want to put it? I don't charge extra for the service unless you are wanting an extremely long set of leads and even then it'd be a small increase in the cost of the kit but I don't charge more to custome build a harness to meet your criteria-I like to think people appreciate that service more than an online speed shop generic offering of a relay fan kit for xyz dollars then you figure out how to route it and make it work-that may be ok for some people but I also deal with people who want a stealth look or have extra needs that must be met.
gbodyparts1234@yahoo.com
HARNESSWORX
#940853 - 08/02/12 12:23 AM Re: Best Radiator/Fan combo for the $ [Re: gmachinz]
84supersport Offline
Louisville, KY
If you don't have the computer in the car anymore the passenger fender well is an excellent place. Room could possibly be made by moving things around even if you do. Buy a relay box from another car at the junk yard and mount it to the inner fender. You can use it as-is or gut it and mount your own relays inside. Hides most of the mess and gives a factory install look. I'm one of those 'stealth look' people. I want it to appear as if it came from the factory with electric fans.
#941056 - 08/03/12 06:30 PM Re: Best Radiator/Fan combo for the $ [Re: 84supersport]
Not trying to hi-jack, but does anyone have a good control method for running two fans (or a two speed fan) with only one temp sensor/switch? I've got the ECM controlling mine, but I was looking at that for another project, and thought it might be helpful to other guys running non-computerized that don't want 2 or 3 temp switches all over the place.
Page 2 of 2 1 2
500/thumbs/IMG_0697.JPG
by 565bbchevy
1083/thumbs/0221111610.jpg
by PIMPC3692
500/thumbs/seat_001.JPG
by montec_ss85
650/thumbs/DSC01290.JPG
by monte_kev
