#939934 - 07/22/12 04:29 PM Power steering return line
ShadowRuleZ Offline
ShadowRuleZ  Offline
Grand Rapids, MI
The hard return line that comes out of the steering box isn't good anymore. I pulled the fitting out and looked at it and it has a rubber o-ring after the fitting and a fairly complicated flare to it so I don't think I can just make a new one for it. Any ideas on where to source a piece like this or is a junkyard piece? I think the outside of the fitting was 18mm.
-Jerry
http://garage.twelve22.net
85 SC (body off) / 83 SC V6 (parts car)
11 Flex / 05 Vibe
#939937 - 07/22/12 04:58 PM Re: Power steering return line [Re: ShadowRuleZ]
Most parts stores carry the hard line, it's just straight and you need to bend it. Comes with all you need. Just remember to put the fitting on the line before you bend up the like.
#939939 - 07/22/12 05:03 PM Re: Power steering return line [Re: ShadowRuleZ]
84supersport Offline
Louisville, KY
When I replaced mine I bought the high pressure line new at NAPA and replaced the rubber hose part of the return line. My return is just a metal elbow on the pump and the box with a rubber hose and hose clamps in between. I did buy new o-rings for the metal ends on the return hose. The high pressure line also came with new o-rings.
#939941 - 07/22/12 05:09 PM Re: Power steering return line [Re: ShadowRuleZ]
carloss Offline
carloss  Offline
Burnaby, BC
#939942 - 07/22/12 05:35 PM Re: Power steering return line [Re: carloss]
ShadowRuleZ Offline
ShadowRuleZ  Offline
Grand Rapids, MI
Exactly what I was looking for, thank you!
-Jerry
11 Flex / 05 Vibe
#939943 - 07/22/12 05:46 PM Re: Power steering return line [Re: ShadowRuleZ]
TPI Monte SS Offline
North Jersey
Get this one - built in power steering cooler, and it's only an extra $5. You can get a few rubber insulated clamps and mount it to the lower radiator support.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_power-steering-return-hose-powercraft_18070996-p?navigationPath=L1*14921%7CL2*15009%7CL3*15710&zoneAssigned=1
SSeeya,
Steve Ragusa - North Jersey
#939946 - 07/22/12 05:59 PM Re: Power steering return line [Re: TPI Monte SS]
ShadowRuleZ Offline
ShadowRuleZ  Offline
Grand Rapids, MI
10.97 from Amazon, so I went ahead and ordered it. I'm running an f-body steering box so the application sounds right, but this and the other fitting mentioned above both say they are 16mm. I'm assuming that's the internal dimension then since the outside fitting size is 18mm.
Also, for anyone else looking at this thread, the other 90 degree fitting is only $4 from O'Reillys.
-Jerry
11 Flex / 05 Vibe
#939954 - 07/22/12 08:38 PM Re: Power steering return line [Re: ShadowRuleZ]
84LS1T56SS Offline
84LS1T56SS  Offline
Central, Arkansas
16MM will be the thread size.
#939962 - 07/22/12 10:38 PM Re: Power steering return line [Re: 84LS1T56SS]
rons87mcss Offline
rons87mcss  Offline
PA
The f body serp setup's power steering pump uses a pressure hose that shares the same fittings although the 'bends' are a little different. I found this out a year or so ago when the pressure line on my 87 sprung a leak and I had to get it fixed asap. I had the f body serp setup in the shed and used that line. I've since ordered new lines (the pressure line and the little "U" line) from rockauto, but never bothered installing them yet.
Looking at my new line for the MCSS, it appears to have both the 16mm fitting on one end(goes in pump), and the 18mm one on the other(where it goes in the pressure switch block 'thingy').
500/thumbs/306537_10151142014953465_994827867_n.jpg
by adi
500/thumbs/CH220175compressed.JPG
by John S
500/thumbs/SS_on_22_inch.jpg
by G-bodySS
1130/thumbs/ResizedImage_1390834191345.jpg
by O.G.
500/thumbs/IMG_0552.JPG
by montesleeper83
