#933524 - 05/26/12 03:39 PM Which PCV on performance engines?
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
Has any one done research and found something conclusive about the letter coding and applications for PCV valves on performance engines?
I looked around a lot online and couldnt find anything concrete about the letter coding on PCV valves. The PCV valve I have in the Monte is 90 degrees and labeled 2072 Made in USA and the letter code on the piston is F.
People seem to recommend the AC CV774C for performance engines (application example 75 Blazer 4 barrel), and the AC CV789C for very radical engines (application example people claim 3rd Gen F-cars but I dont see it). Where it gets muddy is that people claim the letter code on the CV774C is E, but I have also seen people claim the direct cross for it is an F.. like I have. No one stocks these AC PCV valves either so looking at them is out of the question.
I have a hard time believing that AC still makes their own PCV valves and are a superior quality, but I could believe they are still more application specific/less universal as far as performance goes.
So am I crazy or has someone else dug into this also? stupid2
#933534 - 05/26/12 05:06 PM Re: Which PCV on performance engines? [Re: MY FYN 79]
Buick Runner Online content
Buick Runner  Online Content
I bought an new AC Delco PCV valve from Rockauto which has a E. Even with my hotter cam and headers the E valve performed better than the F type most aftermarket brands offer. Seems like most chain and local auto stores no longer stock OEM brands probably due to cost. You either need to go to a dealership or mailorder like Rockauto.
PCV valves come with different flow rates, too much flow and your a/f mixture will be lean. Too little flow and you will get oil leaks and high crankcase pressure. From what I have seen, E valves have a lower flow rate than F valves. F valves seem to flow to much for 305s, even with mode and lean out the idle mixtures causing idle problems. Even then we really don't know how good the quality the aftermarket valves are either. From my experience, aftermarket is almost always much lower quality than OEM parts. Plus the aftermarket often consolidate the same part to many different models regardless if the specs are right or incorrect for individual appreciations, this is one reason it's hard to get a proper rebuild. We just have to accept the days of being able to pick up the correct parts at a local auto store for our cars are long over.
#933965 - 05/31/12 02:00 AM Re: Which PCV on performance engines? [Re: Buick Runner]
baaboo Offline
baaboo  Offline
Racine, WI
Wow, I'm glad that I read this. I need a new one and usually get one from a parts store w/o a clue. thanks.
#933977 - 05/31/12 03:30 AM Re: Which PCV on performance engines? [Re: baaboo]
JAWSS Offline
JAWSS  Offline
Ft. Hood, TX
Do you have the part number for the correct pcv valve?
I found this and wondered if it is correct.
http://www.jegs.com/i/ACDelco-Motorcraft/037/CV774C/10002/-1
86 Monte Carlo SS T-top
69 Cutlass S Convertible
12 Cadillac CTS-V Wagon
#933983 - 05/31/12 03:59 AM Re: Which PCV on performance engines? [Re: JAWSS]
the_merv Offline
the_merv  Offline
Northern, Florida
I don't run any pcv on my setup, constant vent.
1984 MONTE CARLO SS 6spd
#934156 - 06/01/12 04:49 AM Re: Which PCV on performance engines? [Re: JAWSS]
That is the right AC Delco part number but I would still check to make sure it has an E and not an F.
BTW, did you know the PCV system was invented during WW2 for tanks?
500/thumbs/IMG_0398s.jpg
by Turbo5
500/thumbs/0051.JPG
by SSPARKY
by Duster
500/thumbs/door_panel_1_.jpg
by Rodney
500/thumbs/th_ss004-1.jpg
by sstwotimer
