#928823 - 04/20/12 06:38 AM
FI fuel tank/non-FI fuel sender wire?
86_SS
League City, TX
getting ready to install the fuel tank in my 86. I noticed both tanks I have are for the fuel injected G-bodies. Both tanks have the baffels and both sending units are for the electric fuel pumps.
The sending unit has a 3-wire weather pack (pump +, ground, fuel gauge) <--i assume
My wiring harness is a single pink wire.
Will it work correctly if I just connect the pink wire to the fuel gauge wire on the sending unit? TIA
86 Monte SS -  - sbc350, 700-R4, 7.5" open dif - blazer spindle/brake upgrade w/ stainless braided lines, tubular upper a-arms, 1" front lowering springs, jeep steering shaft, electric fans, serpentine swap, 4" fiberglass hood
#929454 - 04/25/12 02:01 AM
Re: FI fuel tank/non-FI fuel sender wire?
[Re: 86_SS]
LM7monteSS
Kingston Springs TN
getting ready to install the fuel tank in my 86. I noticed both tanks I have are for the fuel injected G-bodies. Both tanks have the baffels and both sending units are for the electric fuel pump Would you like to sell the other tank and sending unit you are not using?
86 SS t-top 5.3 4L60E
#929535 - 04/25/12 03:57 PM
[Re: LM7monteSS]
86_SS
League City, TX
I can't right now.. my brother is looking at putting FI in his Cutlass and might be needing it
by eric305TPI
by LT1SSJC
by ProchargedMonteSS
by jenifuriouSS
by jenifuriouSS
