#923400 - 03/16/12 12:20 PM refinishing stock wheels
chazoz86SS Offline
chazoz86SS  Offline
bridgeton nj
has any one stripped the clear coat off of their factory aluminum rims? my clear is starting to check and flake of in a few spots. so I was thinking of stripping the clear and repainting, polishing the machined lips and reclearing my rims. Im afraid to put aircraft stripper or any stripper for that matter onto the aluminum. was wondering if anyone has attempted this and if so what did you use to strip them? and how did they come out?
thanks in advance
#923438 - 03/16/12 06:37 PM Re: refinishing stock wheels [Re: chazoz86SS]
Yes, didn't use stripper but used media blast and then polished the machined surfaces and the painted silver and then cleared used duplicolor wheel paint and they look real good. Takes some time to do the polishing FYI.
#923506 - 03/17/12 06:05 AM Re: refinishing stock wheels [Re: cj84ss]
Kyp Offline
Kyp  Offline
Wayne, NJ
Chuck, I refinished my 4 aluminum rims last summer by using aircraft stripper. It did not harm the rim and was a nice (but messy!) way to strip all the clear and gray paint. I then polished the non painted areas by starting with 220 grit sand paper and worked my way up to 2000 grit. The final grit paper really gets the aluminum to shine. Finish with an aluminum polish like Mothers mag polish. I chose not to clear the rim only repaint the gray areas. Since there's no OEM paint code for the gray color, I took 1 of my original rims to a local auto body supply store here in Northern NJ to match the color. They mixed up a custom batch of urethane enamel that is a close match, but not perfect. Here's how mine came out. Since the photo, I did polish the aluminum to a higher shine.
Hope this helps
Family first, car hobby second makes for slow progress but memorable experiences.
HAVE: 1987 MCSS Aerocoupe, 1975 Pontiac Grandville Conv.
#923510 - 03/17/12 10:31 AM Re: refinishing stock wheels [Re: Kyp]
Kyp What brand lug nut are those? I have a style of Dorman products like that and some are starting to rust.
#923515 - 03/17/12 11:52 AM Re: refinishing stock wheels [Re: Richie Cat]
chazoz86SS Offline
chazoz86SS  Offline
bridgeton nj
Kyp those look great. exactly what im looking for. how often do you have to stay after the polish and how quick do they try to corrode if you dont clear them? How did you address the back side of the rim?
#923624 - 03/18/12 12:34 AM Re: refinishing stock wheels [Re: chazoz86SS]
Kyp Offline
Kyp  Offline
Wayne, NJ
Richie Cat, the lug nuts are original GM. They look decent in person and better in pictures.
Chazoz86SS, my car is always in the garage so it doesn't experience the corrosion factor but it's done well during washings. The Mother's aluminum polish makes the water bead off. I didn't strip or refinish the backside just cleaned it using soft scrub and fine steel wool. Looks a lot better. the whole process is very time consuming but if you do 1 wheel per weekend it's not as overwhelming. Hope this helps.
#923626 - 03/18/12 12:38 AM Re: refinishing stock wheels [Re: Richie Cat]
joeg86ss Offline
joeg86ss  Offline
Carroll, Iowa
You can buy the stainless lugnuts at orielly's but I found that rockauto.com has them cheaper if you are going to buy all 20.
Started my restoration in May 2010
#923627 - 03/18/12 12:39 AM Re: refinishing stock wheels [Re: Kyp]
joeg86ss Offline
joeg86ss  Offline
Carroll, Iowa
Nice job Kyp.
#923637 - 03/18/12 01:16 AM Re: refinishing stock wheels [Re: joeg86ss]
Those look great Kyp! I followed the same basic process several years ago and also only painted the non-polished areas (left the polished areas bare). I went with a darker grey for some contrast with the polished aluminum and white paint on my SS:
Only one question for ya: didn't it kill you to have wheel weights installed on the outside of the rim after all that work?
#923690 - 03/18/12 04:14 PM Re: refinishing stock wheels [Re: 85_SS]
Kyp Offline
Kyp  Offline
Wayne, NJ
Joeg86ss, thanks!
85 SS, Thanks, yours look great too! The darker gray doess look good on a white SS. I got the idea from this forum and I remember seeing your write up which gave the the courage to do it...thanks for sharing. I was getting progressively better at doing each wheel that I had to go back to the first one and wet sand it with 2000 grit one more time. Yes, it does stink to pt the weights back on...Ha
#923728 - 03/18/12 09:14 PM Re: refinishing stock wheels [Re: 85_SS]
joeg86ss Offline
joeg86ss  Offline
Carroll, Iowa
85ss where did you get your lug nuts? They don't have the stupid "metric" stamped on them. I like!!
#923757 - 03/19/12 12:47 AM Re: refinishing stock wheels [Re: joeg86ss]
Jimmy - I think I may have done the same with regards to having to go back and redo wheels or sanding stages I'd done already. It's a real pain to refinish these wheels by hand, but if it's not driven in the winter, they'll look great forever and all you need to do is polish the bare areas once every season or two. FWIW, you can have the wheels balanced on the inside only - this is what I have done with all my wheels to avoid the weights on the outside and the corrosion that later comes along with that. Not as much of a worry on a car that doesn't see a lot of weather, but something to think about smile
Joe - they are just cheapo $1/ea lug nuts from local sellers. I really like the flat top on them and use these on most of my cars. I hate the more common extended round tops that come on most aftermarket lug nuts.
#1060657 - 02/06/19 01:52 AM Re: refinishing stock wheels [Re: 85_SS]
88Z65 Offline
88Z65  Offline
NJ
Thanks to those above I got the nerve to try and recondition my SS wheels.
The clear coat was in real bad shape and there was corrosion by the wheel weights. It took about 4 hrs per wheel. Putting the wheel on a swivel shop stool made work a lot easier. See pictures for results.
I started with a Black and Decker Mouse sander with 120 grit to get the clear off and any corrosion. The mouse works great on the rim area because its curved and fits against the rim curve fairly close. I followed that by hand with 220 grit, then 400 and finally 1200, all dry sanded. You can go on to 2000 grit and a metal polish but that ends up looking like chrome. I prefer the satin aluminum look. It looks more original. The silver paint is original. The spokes didn't need much work at all.
After the 1200 I just clear coated it with VHT high temp wheel paint. It's a polyurethane clear coat and takes 7 days for full cure.
stock, 276K, no end in sight
#1060662 - 02/06/19 05:36 PM Re: refinishing stock wheels [Re: chazoz86SS]
#1060986 - 03/05/19 03:24 AM Re: refinishing stock wheels [Re: chazoz86SS]
Kyp Offline
Kyp  Offline
Wayne, NJ
88Z65 - Looks great!! It does take hours to complete but well worth the sweat equity.
#1061004 - 03/06/19 01:04 AM Re: refinishing stock wheels [Re: Kyp]
88Z65 Offline
88Z65  Offline
NJ
Thanks Kyp. I was going to go all the way to 2000 grit and metal polish like you did, but I liked the look I got with the 1200 without the polishing.
You did an outstanding job on your wheels. Congrats.
500/thumbs/Jaymans84SSsig.jpg
by GearedSS
500/thumbs/frame_notch.jpg
by jnw86
500/thumbs/100_0550s.JPG
by Duts87SS
809/thumbs/montejim3.jpg
by jenifuriouSS
989/thumbs/my_monte_161.jpg
by 85montanezcarloss
