#919024 - 02/18/12 03:56 PM Degree cam?
ChrisSS Offline
ChrisSS  Offline
RoseHill, Kansas
to do or not to do. have lt1 with cam part# 07-468-8 xfi.
what am i building? i dont know anymore but im sure ill figure it out.
Can u handle it?
#919030 - 02/18/12 05:16 PM Re: Degree cam? [Re: ChrisSS]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
I would, just to be sure all the components are made correctly.
Just as you should do with every aspect of assemblying the engine.
Don't assume anything.
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18 Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#919091 - 02/18/12 11:53 PM Re: Degree cam? [Re: ProTourAero]
Joe87monteSS Offline
Memphis,TN
I've installed new cams that are a couple degrees off. And i've noticed that factory timing tabs can be 4 degrees off. Thats why you should mar true TDC on your balancer and go from there.
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#919134 - 02/19/12 04:36 AM Re: Degree cam? [Re: Joe87monteSS]
ChrisSS Offline
ChrisSS  Offline
RoseHill, Kansas
yeah i guess thats what i will do. i know ive never done it b4 and never had problems but with this motor i dont want to screw up there is alot of money wrapped up in this one compared to my last few.
Can u handle it?
#919155 - 02/19/12 02:27 PM Re: Degree cam? [Re: ChrisSS]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
What other components are you replacing during your rebuild?
www.protouraero.com
#919532 - 02/21/12 05:39 PM Re: Degree cam? [Re: ProTourAero]
ChrisSS Offline
ChrisSS  Offline
RoseHill, Kansas
pretty much everything will be new except the opti spark cause its only got 10000 miles on it roughly or so.
Can u handle it?
#919609 - 02/22/12 12:48 AM Re: Degree cam? [Re: ChrisSS]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Most of the time you are safe just installing the cam without degreeing it in a street engine... but, as others mentioned, for the last ounce of performance, checking everything (balancer timing markings, timing tab position, cam centerlines, etc.) works best... and occassionally it prevents a headache later...
500/thumbs/06.JPG
by Ole Blue
500/thumbs/interior_12.jpg
by djones27
500/thumbs/yhyhy.JPG
by juangomez22
1103/thumbs/11174_10200670096943276_1970586525_n.jpg
500/thumbs/bluerim.jpg
by Mr-SShadow
