#917932 - 02/12/12 12:13 AM Bilsteins on a Lowered Monte?
cwest01 Offline
cwest01  Offline
Livonia, Mi
I am contemplating installing some Bilsteins on my Monte but it is dropped 2" all the way around via Belltech lowering springs. As I know it, Bilstein does not make shocks "officially" for lowered cars with a reduced travel. That is why when I did the height adjustment I used Nitro 2 drop shocks. Any opnions on this??
#917938 - 02/12/12 12:29 AM Re: Bilsteins on a Lowered Monte? [Re: cwest01]
Performance Offline
Performance  Offline
East Tennessee
I have always used the Belltech shocks on lowered cars or trucks. Best shocks, hands down, that I ever used with something lowered. I don't think much of anything else will give you the amount of travel you need in a shock with it lowered 2" or more.
1986 Monte Carlo SS
#917943 - 02/12/12 12:39 AM Re: Bilsteins on a Lowered Monte? [Re: Performance]
PB86SS/87LS Online beer
PB86SS/87LS  Online Beer
I've used Bilsteins with my Montes, both lowered, and have been very happy as well as many other owners. But neither car is drastically lowered, the LS only about 1" all around due to Eibach springs and the SS about 1.5" in front, 1" in back with Eibachs and the old "1LE" brake swap using b-body spindles in front.
I believe there is a Bilstein application for S10's that works well for lowered g-bodies, not sure at what point one is preferred over the other (1", 2", etc.) but if you do a search I'm sure it will come up.
#917964 - 02/12/12 03:19 AM Re: Bilsteins on a Lowered Monte? [Re: PB86SS/87LS]
Do_M_Drty Offline
Do_M_Drty  Offline
Georgia
I used them with drop spindles with no issues.
79Monte Carlo, 34,XXX original miles
09Silverado Ext Cab, 5.3 with 3.73 gears, 4/7 drop with assist bags, and tucking 24s
"Outside a dog, a book is man's best friend. Inside a dog, it's too dark to read." Groucho Marx
#917965 - 02/12/12 03:21 AM Re: Bilsteins on a Lowered Monte? [Re: Do_M_Drty]
lmao
#917969 - 02/12/12 03:36 AM Re: Bilsteins on a Lowered Monte? [Re: 1 Slow SS]
cwest01 Offline
cwest01  Offline
Livonia, Mi
I understand using them with drop spindles as the geometry stays the same. But with lowering springs only, the effective range of the shocks will be much less than the original design intended. I am concerned that this will put the working range of the Bilsteins in a less than optimal position yielding them less effective than the Nitro 2's I have now.
#917972 - 02/12/12 03:42 AM Re: Bilsteins on a Lowered Monte? [Re: cwest01]
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
I don't know about the Bilsteins compared to the Nitro IIs but I did install the Bisteins on my SS after I had lowered it(yes drop spindles on the front but I also cut the front coils a half coil lowering the car another inch, Hotchkiss 1" drop springs on the rear) I had been running Monroe Sensa-Tracs before the Bilsteins and the car did MUCH better after the Bilsteins, I had a lot less tie rub issues after the shock swap. I won't anything else on my toys from now on.
#917989 - 02/12/12 10:05 AM Re: Bilsteins on a Lowered Monte? [Re: ss4ever]
MADMIKE Offline
MADMIKE  Offline
C.V. CA
They will work with lowered cars, but if the springs up front are shorter they also tend to be a higher spring rate. For that I would use the S-10 2wd front shock from Bilstein. It is actually an inch shorter with a larger piston to better dampen the stiffer spring.
-Michael
Where the hell is JMD?!
#917996 - 02/12/12 01:35 PM Re: Bilsteins on a Lowered Monte? [Re: MADMIKE]
cwest01 Offline
cwest01  Offline
Livonia, Mi
Anyone have part numbers for the two options? Also, anyone out there with the S10 springs mentioned above running?
#918299 - 02/14/12 11:54 AM Re: Bilsteins on a Lowered Monte? [Re: cwest01]
MADMIKE Offline
MADMIKE  Offline
C.V. CA
B39-0949 (G-body) 13.48" 8.60"
B46-1307 (S-10) 11.93" 7.95"
The shock body of the 1307 is about an inch shorter, but the diameter is about 30%, with a larger upper bushings and it requires use of the double D tool to hold the shaft. The 0949 unit requires a 6mm allen to hold the shaft as you tighten the shaft nut.
Last time I checked Bilstein changed the part numbering. Don't know why but they did. Keep in mind to order the correct shock it must be a 2wd. 4WD and AWD use a different shock.
I run the 5660(s series) front spring with the 1307 shock. Ride is firm but not harsh. Still allows for a supple ride and eliminates the boat feel.
5600 347 lb/in 1600lbs @ 11" ('78-'88 A/G)
5608 424 lb/in 1640lbs @ 11" ('78-'88 A/G)
5658 530 lb/in 1405lbs @ 10.75" ('82-'95 S-10 PU)
5660 598 lb/in 1538lbs @ 10.75" ('82-'95 S Blazer)
5664 707 lb/in 1863lbs @ 10.75" ('86-'88 'IROC')
5662 748 lb/in 1690lbs @ 10.75" ('92 GTA)
-Michael
#923219 - 03/15/12 04:30 AM Re: Bilsteins on a Lowered Monte? [Re: MADMIKE]
79T-Tops Offline
79T-Tops  Offline
Minneapolis, Minnesota
It appears the 2WD S10 Part number for the front shocks are 24-187428
Would these be the proper ones?
http://www.summitracing.com/parts/BSN-24-187428
500/thumbs/dual_a1.jpg
by Tony K.
by Sherdep
835/thumbs/DSCF00251.JPG
by timw
500/thumbs/sig2.jpg
by 1984Monte
651/thumbs/C6.JPG
by 84supersport
