#916045 - 01/31/12 11:09 PM Catalytic Converter?
Ryan Bequette Offline
Happy Birthday Ryan Bequette  Offline
Twinsburg, OH
So i received my new magnaflow cat today for my 87 and I didn't receive any sort of bolts or gaskets. I know walker wont include it with the new y pipes im getting also. Does anyone know if autozone or advanceauto would carry the gaskets and bolts?
#916055 - 01/31/12 11:34 PM Re: Catalytic Converter? [Re: Ryan Bequette]
Why wouldn't they? Google your application and see.
#916061 - 02/01/12 12:06 AM Re: Catalytic Converter? [Re: Richie Cat]
Furgie Offline
Furgie  Offline
Rustbeltville,MA
depends is the cat. a replacement part.. direct fit..
or just a cat with the right pipe size?
advance has a ton of gaskets/ect..
Oh when your body starts to shake,It's time to loosen off the brake ,and slam the hammer down
#916071 - 02/01/12 12:43 AM Re: Catalytic Converter? [Re: Furgie]
Twinsburg, OH
Its magnaflows exact fit cat with the four bolt flange. It should bolt right up i mean it looks exactly like the original but it didn't come with any hardware.
#916076 - 02/01/12 12:54 AM Re: Catalytic Converter? [Re: Ryan Bequette]
rons87mcss Offline
rons87mcss  Offline
PA
Get 4-8(?) nuts/bolts from the local hardware store(?) Even if it's a threaded flange (IDK, I've never looked that closely at mine) w/metric bolts, you can still buy them easy enough.
EDIT:
I have a new 93441 Magnaflow converter in a box, and it has a ball type end towards the motor. The other end is set up for a muffle clamp on the intermediate pipe(s).
No gasket needed for a ball type fit.
HTH
#916084 - 02/01/12 01:09 AM Re: Catalytic Converter? [Re: rons87mcss]
axisg Offline
axisg  Offline
Toronto, Ontario
I replaced the exhaust on my car in pieces. Headers then car then cat-abck. Each time the cat was unbolted I noticed there was no gasket between the cat and exhaust. I put mine back together each time with hi-temp copper silicone and 8x bolts I had in the toolbox. I have had it back off again a half dozen times and each time I grind off the the surface with a wire wheel and re-seal with no issues. Don't worry about a gasket
TES Headers - done !
new cat-back exhaust - done !
5.7 swap - done !
3.73 posi rear - done !
blazer front brakes - done !
LS1 Rear Brakes - done!
transmission - rebuilt !
#916098 - 02/01/12 01:37 AM Re: Catalytic Converter? [Re: axisg]
RegalGP Offline
RegalGP  Offline
Warwick, RI
Bought a magnaflow, no bolts or gaskets. Just buy some new ones. X2 on the hi-temp copper.
CRUISER 87 SS. 350 swap, rebuilt trans, front sus/str & dropped w/ZQ8's. Working out the bugs. DAILY/PARTS GETTER 02 GMC 1500HD 294k and counting
#916111 - 02/01/12 02:14 AM Re: Catalytic Converter? [Re: RegalGP]
the cat has no gaskets, they came that way from the factory. Hi temp silicone if you insist. Just buy hardware as suggested.
#916121 - 02/01/12 02:22 AM Re: Catalytic Converter? [Re: 86ttop]
honkymonte Offline
honkymonte  Offline
newville, pa
yea when i took mine off to "examine" it, there are no gaskets or anything, just the flange that seals when you bolt it up again
#916125 - 02/01/12 02:27 AM Re: Catalytic Converter? [Re: honkymonte]
Twinsburg, OH
Okay so i will just get the bolts. Ill let you guys know how this setup works Its a magnaflow high flow cat with complete stock exhaust up to some thrush turbos that i picked up today. Should have the pipes in tomorrow.
#916143 - 02/01/12 03:14 AM Re: Catalytic Converter? [Re: Ryan Bequette]
MoreHPplease Offline
New Jersey
Spend the extra money and get some SS bolts and nuts.
You will appreciate when ever the next time comes around and you need to remove the nuts & bolts.
#916161 - 02/01/12 04:11 AM Re: Catalytic Converter? [Re: MoreHPplease]
MADMIKE Offline
MADMIKE  Offline
C.V. CA
I would not use stainless steel nuts and bolts. The stainless on stainless, if not carefully installed, can cause galling, stripping, or shearing of the bolt. If you must use stainless steel nuts on the bolts make sure to lubricate and thread the fasteners together slowly. Materials that readily self-oxidize (SS, AL,etc) have a rough surface.
Steel bolts usually have the threads rolled to produce the screw, this has a smooth surface. Nuts are usually machined/drilled, this produces a rough surface. The two combined will usually assemble with no problems.
With stainless the bolt threads will not have a smooth surface from the oxidizing. The two rough surfaces can bind, galling, and if forced strip or shear the bolt.
-Michael
Where the hell is JMD?!
#916162 - 02/01/12 04:16 AM Re: Catalytic Converter? [Re: MADMIKE]
Twinsburg, OH
I would hate to have that happen. What if I used a slightly smaller bolt and put a nut on the end and tightened it that way?
#916171 - 02/01/12 05:43 AM Re: Catalytic Converter? [Re: Ryan Bequette]
Just use anti-seize on the steel bolts.
#916174 - 02/01/12 08:05 AM Re: Catalytic Converter? [Re: Buick Runner]
New Jersey
Interesting, but my experience has been the exact opposite.
I have found that once alloy steel bolts (i.e. Grade 5,8 or metric 8.8,10.9) have gotten hot enough in an exhaust system they will often seize in their holes, and they end up having about as much strength as a Grade 2 bolt (if that) so they will twist off with very little effort.
Anti-seize helps with later removal, but they still rust badly and have a tendency to lose their threads because they get so soft.
Stainless pretty much maintains it's strength, and I haven't seen it have any tendency to gall. Then again, I always use anti-seize on exhaust bolts.
#916194 - 02/01/12 02:21 PM Re: Catalytic Converter? [Re: MoreHPplease]
Barry 85 SS Offline
Barry 85 SS  Offline
Newport News, Va.
Stainless is definately prone to galling, but some anti sieze should prevent it from happening.
#916213 - 02/01/12 04:43 PM Re: Catalytic Converter? [Re: Barry 85 SS]
MADMIKE Offline
MADMIKE  Offline
C.V. CA
It can also be prevented if the nut and bolt are each a different hardness.
The tensile strength of stainless steel bolts may not be identified using familiar SAE head markings. They may have '307', '325', or '490' stamped into the head. These are the equivalent of Grade 1, Grade 5, and Grade 8.
-Michael
#916294 - 02/02/12 02:43 AM Re: Catalytic Converter? [Re: MADMIKE]
New Jersey
Absolutely right, stainless steel only galls with stainless steel of the same grade and most high quality aftermarket exhaust systems (to include turbo manufacturers) usually provide the end user with different grade hardness SS nuts in-conjunction with their supplied bolts.
Putting stainless bolts into a cast iron head will not be a problem and of course just make sure to use a high temp copper based anti-seize compound.
Also from my experience the most common grades of SS used for bolts are 304 and 316.
These are both austenitic grades, which means they have enough nickel to prevent the formation of martensite (which is what makes steels, stainless or otherwise, hardenable).
304 is also commonly known as 18-8 or A2, and is the most common and least expensive. 316 costs more, but has better corrosion resistance against acids and harsh marine environments.
You don't need 316 for exhausts, but it might be better if you live in some rust belt state where they salt the roads in the winter months.
Just a side note... These stainless steels will not become hard or brittle through heat cycling nor will they become much softer or weaker after years of use.
They aren't as strong as a regular grade 8 bolt so don't try to over tighten them as you don't need to anyway.
Another positive about using SS nuts and bolts for exhaust systems is they are quite a bit stronger than grade 8 bolts that have been repeatedly heat cycled besides the fact that they won't turn into a rusty pile of crap after being exposed to the elements.
#916361 - 02/02/12 03:34 PM Re: Catalytic Converter? [Re: MoreHPplease]
Twinsburg, OH
Well unfortunately I live in Ohio actually a couple miles from lake erie so we always have salt on the roads in the winter. Where can i pick up a set of SS bolts?
#916428 - 02/02/12 11:53 PM Re: Catalytic Converter? [Re: Ryan Bequette]
New Jersey
If you have a local hardware store I would try there first.
Also places like Home Depot and ACE usually have a variety of SS nuts and bolts too.
995/thumbs/44.jpg
by knight77
500/thumbs/monte_engine1.jpg
by 85lolo
1126/thumbs/1986_2.jpg
by Rich S
500/thumbs/009.jpg
by mdecker211
