#911925 - 01/08/12 07:30 AM 383????
thess Offline
thess  Offline
antioch tn
Anyone have a similar setup or can give ma a guesstamite of what it'll make?
Eagle rotating assembly 12.00cc pistons
Vortex heads upgraded for higher lift.
Rpm airgap intake
Vodoo 268 partnumber 60103lk.
Th350 3.73
750cfm Holley carb.
#911928 - 01/08/12 08:21 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
#911984 - 01/08/12 05:38 PM Re: 383???? [Re: thess]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
Roughly around 425 HP.
There are a lot of variables there.
The non OD transmission and the 3:73 gears will have a lot of RPS at highway speeds.
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18 Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#912013 - 01/08/12 08:04 PM Re: 383???? [Re: ProTourAero]
thess Offline
thess  Offline
antioch tn
What kinda variables?
Yea I know its right at 3200 on the interstate
I've had em for a year an a half
#912055 - 01/09/12 12:14 AM Re: 383???? [Re: thess]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
How much work was done to the heads.
Valve size.
Intake runner volume.
Blending of the valve job.
Back cutting the valves.
Quench.
Port match.
Cam degree.
In any case were still probably not too far away from 425HP.
Maybe a little more if all above is good!
www.protouraero.com
#912056 - 01/09/12 12:16 AM Re: 383???? [Re: thess]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. X 2... Should be around 425 - 450 HP... Was your rear end changed since '84 SS came with 3.42 rear end? Got Posi?
.. Variables would be: were the valves upgrade in size also? What's the quench distance? Compression ratio? 1.5, 1.6, 1.7 rocker arms? Got headers and freeflowing true dual exhaust system?
.. You can compare your 383 to the one in this article also with Vortec heads:
http://www.hotrod.com/techarticles/engine/gm_ht383_crate_small_block_tune_up/viewall.html
#912061 - 01/09/12 01:07 AM Re: 383???? [Re: BuzzLOL]
thess Offline
thess  Offline
antioch tn
1.94 1.60
3angle valve job
Cam 4 begrees advance
Gasket matched
170cc
.045
10.1 static
8.4 dynamic
Headers and a true dual exhaust
1.5 rockers
I blew the 342s apart in the stock one it had posi. Now iv got 373 posi rear.
#912266 - 01/10/12 03:36 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
#912302 - 01/10/12 12:23 PM Re: 383???? [Re: thess]
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
I would still guess 425HP.
The head intake runners are too small, so maybe less.
www.protouraero.com
#912307 - 01/10/12 03:35 PM Re: 383???? [Re: ProTourAero]
Gruvin Offline
Gruvin  Offline
Texas
most of the things you have listed will basically optimize that setup... Should be around a real world 425HP (not west-tec dyno la la land numbers)
#912474 - 01/11/12 09:00 AM Re: 383???? [Re: Gruvin]
thess Offline
thess  Offline
antioch tn
That's great that's what I was shooting for and to put atleast 400lbstq
#916166 - 02/01/12 04:47 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
Ok so I have ever thing put together motors goin in tomorrow any one have any break in tips?
#916182 - 02/01/12 11:31 AM Re: 383???? [Re: thess]
Duts87SS Offline
Duts87SS  Offline
Spanish Fort, AL USA
I'm gonna say ~400hp. I'd probably step back to a 600-650cfm carb, though.
Make sure you use some quality "break-in" oil with plenty of ZDDP.
Dustin
87 SS
#916208 - 02/01/12 04:12 PM Re: 383???? [Re: Duts87SS]
get it completely bolted in, all accessories installed and tight, add oil and coolant(some prefer water at first,your call)prelube engine, install dist and get timing as close as possible, prime carb by pouring some gasoline down the vent tube, pump accel to get gas into engine, crank engine and when it fires get RPM to 2000 for at least 20 minutes all the time watching the oil pressure and coolant level in Rad. Set timing to desired degrees and after 20 minutes, take vehicle for about a 20 mile drive. Some recommend changing the oil after the breakin, I did not on my engine,your call if you decide to do that, Good luck.
#916228 - 02/01/12 07:38 PM Re: 383???? [Re: 86ttop]
Ninja85SS Offline
Ninja85SS  Offline
California, MD
x2 what Leo says, but would reccomend reving engine between 2k and 2.5k during breaking at sya for example 30 second intervals. This helps cam break in process.
1985 Monte Carlo SS 383MT Forced Induction
http://www.cardomain.com/ride/2228046
2004 Dale Earnhardt Jr. Supercharged Monte Carlo SS
#916474 - 02/03/12 04:27 AM Re: 383???? [Re: Ninja85SS]
thess Offline
thess  Offline
antioch tn
Thank you guys. For all your help ill post a couple pic up when its done hopefully the break in goes good!
#918575 - 02/16/12 01:39 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
Ok I ran into a problem during break in.
Motor started smoking then flames came out by the pass header
Spark plug bot caught fire changed it out it wasnt touching the header.
Caught fire again. What would cause the car to over heat like this
#918576 - 02/16/12 01:42 AM Re: 383???? [Re: thess]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
You mean glowing hot? Thay would be a very lean condition
#918584 - 02/16/12 02:26 AM Re: 383???? [Re: pazzo1969]
Barry 85 SS Offline
Barry 85 SS  Offline
Newport News, Va.
Did you have the timing set correctly? The exhaust will get very hot with the motor reved up during break in if the timing is retarded. Also make sure all vacuum ports are plugged or hooked up properly.
#918602 - 02/16/12 04:05 AM Re: 383???? [Re: Barry 85 SS]
thess Offline
thess  Offline
antioch tn
Ok I didn't get to see the header while it was running my dad was the one who was watch under the hood they weren't red as of my knowledge.
I had to bearly turn the dizzy to get it to start. And also I just realize my vacuum advance wasn't hooked up
#918605 - 02/16/12 05:17 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
Also its the number six spark plug wire
#918779 - 02/17/12 01:25 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
Timing was way retarded advanced it didn't burst into flames ran smooth just gotta get this thing tuned right
#918891 - 02/17/12 04:34 PM Re: 383???? [Re: thess]
Mnt86ss Offline
Mnt86ss  Offline
Newburyport , MA
383's are a great monster mouse platform!
My Dads Camaro has a 383 in it and its a monster! It dynoed in @461Hp and 445Tq. They build bigblock power with smallblock RPMs.
Sounds like you have a stout build, and the Monte should really fly with the TH350 and 3:73's!
America, Love it or leave it
#919141 - 02/19/12 06:46 AM Re: 383???? [Re: Mnt86ss]
thess Offline
thess  Offline
antioch tn
Thanks I'm hoping it will! But having a problem with one header tube glowing red. Eventually I wanna drift this car in the very near future!
#919463 - 02/21/12 03:29 AM Re: 383???? [Re: thess]
thess Offline
thess  Offline
antioch tn
Any ideas why one header would turn red while idling
651/thumbs/C6.JPG
by 84supersport
994/thumbs/KC1210-100906_7.jpg
by Elipopotao
500/thumbs/Lomogram_2014-08-27_12-05-28-PM.jpg
by MCSSLife
671/thumbs/start_001.jpg
by woodss
500/thumbs/At_Earnhardt_Chevrolet.jpg
by Scott_86SS
