Page 4 of 4 1 2 3 4
#1039073 - 05/13/16 05:41 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
How is your door to qtr gap?
It seems like both of mine the qtr side of the seam is not straight, or in other words it doesn't follow the the door evenly. The gap is even from the bottom up past the side stripes a few inches then it gets wider on up to the door top.
I'll get some pics neither qtr on mine is welded yet as I wanted to fit the trunk and tail lights.
#1039313 - 05/18/16 01:19 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Let me know how your measurements compare, from the top of the roof down to the the flange on the qtr it's an inch
As far as the measurements to the qtr window it's hard cause the aftermarket panel doesn't have too many sharp edges most are rounded but the front edge is right near an inch and a quarter
And the rear edge about an inch and a half
#1039484 - 05/21/16 07:27 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
84ss355*4spd Offline
Edmonton,AB,Canada
I posted a pic of my roof seam so far .still some small trimming to do wondering if the repro doors will fit the repro quarters better as far as body gaps go
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1039493 - 05/22/16 02:46 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Whoops I forgot to post that pic of the rear qtr seam I'll get it shortly
I'm thinking a little scrap filler welded in on the rear finished with lead.
#1041051 - 07/04/16 04:15 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Well I was able to make some progress over the last couple of days got the door/ qtr gaps cleaned and adjusted, and got the rear gaps straightened.
The welded on studs for the rear bumper were in bad shape so for now I took them off and put stainless bolts in place, might leave it that way.
But the rear came together which is a good feeling after all the metal that has been replaced on the car.
#1041261 - 07/08/16 08:00 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Well took the front window out and cleaned up the last bits of the wiper assembly in preparation for getting the car blasted and primed.
This morning I found this which I'd have to believe contributed to the rust on the passenger side...
You can see daylight through it so you know water flowed through on down the inside of the door jamb, good to find now.
#1042099 - 08/05/16 03:48 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Well got some good help the other day...
#1042830 - 08/26/16 03:01 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
Edmonton,AB,Canada
Hey my friend . I have been busy with other life things lately. Monte is still waiting for me to do more work. Still waiting on my trunk parts. Looks like you have made some good progress ! Any pics of the trunk pan
86 ss gone
85 ss new
85 z28 tpi
#1042864 - 08/28/16 04:19 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Hey Matt, kinda in the same boat but the last thing accomplished is the drivers qtr is all welded in cept the roof seam, and ready to do the same to the pass one.
What area of the trunk do you want pics of?
#1043629 - 09/17/16 09:50 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Thanks Mick for the patch panel!
This is one of the last few PCs I had to repair.
What I did get taken care of was the rear studs for the bumper cover. I bought some metric bolts an inch long and cut off the damaged studs, stuck the new bolts through a hole in the same position and welded them in worked out great.
#1044692 - 10/25/16 09:31 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
Edmonton,AB,Canada
Nice patch . I'm back working on the car again. Replacing the inner and outer rocker on the passenger side right now . Almost have the outer off. The trunk pan u said fit ba where the filler knock goes I was wondering how it looks . Also the quarter to door gap how did u fix the gap on it any pics of that . Car looks great all back together . Can wait till I'm there . In still a bit behind you . Going to post some pics of the passenger rocker work . I also need to replace my windshield pillars at the bottom . The water didnt go inside the door posts thankfully. I have been looking at the t top pillars and Im pretty sure they can be used on a hard top. just modified to weld to the roof
86 ss gone
85 ss new
85 z28 tpi
#1048683 - 03/06/17 01:30 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Hey 84ss been awhile! Hope things are going well your way.
As far as the door to quarter gap it seemed all the bends on the aftermarket quarter were soft, basically not sharp 90 deg. bends or whatever they are, so what I did was lightly hammer, on the qtr edge, about half way down to the bottom on the door jamb face and it seemed to get me what I needed and really did not distort the face of the quarter either.
I don't have any pics of the filler neck I'll see if I can get some.
Here's what I was working on tonight, the RR weather strip channel. You can see the aftermarket one on the right it didn't have the back edge to it so if there is a leak somewhere it would dump back into the roof structure, I just didn't care for that so I bought some 16 ga and bent my own.
#1049150 - 03/22/17 06:35 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
Edmonton,AB,Canada
Good to know any pics of install
86 ss gone
85 ss new
85 z28 tpi
#1050239 - 04/23/17 01:29 AM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Here is what the channel was like before....
During......
After....
#1050248 - 04/23/17 04:10 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
Edmonton,AB,Canada
Thats great ! See you have the roof seam on the quarter welded up . Lookin good . Was waiting for an update lol. I cant wait till i can get the 84 going forward again . See you have wheel houses are you replacing them as well. Your quarters are on just wondering how your going to do that . Roof seam looks good , good work . Can u post a pic of that and the back window quarter area thanks
86 ss gone
85 ss new
85 z28 tpi
#1050257 - 04/23/17 07:33 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Those wheel houses are extras I bought before I found the complete ones, inner and outer, I swapped in as a whole.
#1050275 - 04/24/17 02:36 PM Re: 87 SS Monte restoration - RUST removal [Re: ls1_monte]
Edmonton,AB,Canada
Ah cool . Ya i have driver side complete wheel house . I still need the passenger side . What you going to do with them .
86 ss gone
85 ss new
85 z28 tpi
#1065442 - 03/15/20 02:41 AM Re: 87 SS Monte restoration [Re: ls1_monte]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
Been awhile for sure but the body is in primer on the rotisserie. Really hoping to see some paint on it this year.
Stopped by to say hi to anyone hanging around, glad to see the board still kickin.
#1066128 - 04/23/20 03:44 AM Re: 87 SS Monte restoration [Re: ls1_monte]
Edmonton,AB,Canada
Hell ya buddy ! Been creeping .my ss is almost ready to come off the frame .last side to finish welding on tje quarter .good job stay safe ,mat
86 ss gone
85 ss new
85 z28 tpi
#1066129 - 04/23/20 03:47 AM Re: 87 SS Monte restoration [Re: ls1_monte]
Edmonton,AB,Canada
Hell ya buddy ! Been creeping .my ss is almost ready to come off the frame .last side to finish welding on tje quarter .good job stay safe ,mat.camt believe its been 3 yrs since i posted last on your thread
86 ss gone
85 ss new
85 z28 tpi
#1066162 - 04/24/20 06:46 PM Re: 87 SS Monte restoration [Re: ls1_monte]
Congrats man! That was a mountain of work!
#1067200 - 07/07/20 07:37 PM Re: 87 SS Monte restoration [Re: ls1_monte]
Edmonton,AB,Canada
How were you able to post a direct picture ? Check my post out. Take it easy keep coming keep this awesome site booming
86 ss gone
85 ss new
85 z28 tpi
#1067210 - 07/08/20 03:06 PM Re: 87 SS Monte restoration [Re: ls1_monte]
Edmonton,AB,Canada
What body bushings did you use .i seeu said energy suspension .have q part number ? Complete kit with bolts? Take it easy i will be welding my quarters on in the next few days .
86 ss gone
85 ss new
85 z28 tpi
#1067545 - 08/07/20 01:43 AM Re: 87 SS Monte restoration [Re: 84ss355*4spd]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
I bought energy suspension ones, black poly, but i had to buy bolts separately. I cant recall but i think i bought them from fastenal.
On that pic above i used [img]picturelink[/img] pretty sure i just got lucky
#1068417 - 11/02/20 12:08 AM Re: 87 SS Monte restoration [Re: ls1_monte]
Edmonton,AB,Canada
Good to know about the bushings .you got a part number by chance for the set you have .keep the pics and updates coming !
86 ss gone
85 ss new
85 z28 tpi
Page 4 of 4 1 2 3 4
523/thumbs/DSC_0670.jpg
500/thumbs/mc10.jpg
by javi05
669/thumbs/P1010330.JPG
by Matt?
500/thumbs/core_support.jpg
by dw329
944/thumbs/Img_00002_copy1.jpg
by zz485ss
