#903591 - 11/13/11 04:43 PM Rear End Compatibility
Callie100 Offline
Callie100  Offline
Adolphus, KY
Would a pinion and ring gear from any other type of car (ie: Cutlass Supreme) be compatable in a 1987 Monte SS? We need to replace the rear end "pumpkin" in our SS because the pinion gear was broken when we bought it, and we are having trouble finding one from the parts yard on a Monte. We are able to get one for a Cutlass though, but don't want to buy one that's not going to work...
#903593 - 11/13/11 05:09 PM Re: Rear End Compatibility [Re: Callie100]
Monte84cortez Offline
dallas tx
I believe all 7.5 are the same size on ring just different ratio
84 Monte Carlo Ss
86 Monte Carlo ss
#903600 - 11/13/11 06:16 PM Re: Rear End Compatibility [Re: Monte84cortez]
84ss_stock4now Offline
indiana
what gear are you looking for i have a 373 and a 342
84ss 385 stroker aluminum heads 3000 stahl dynomax mufflers b&m shifter 2nd stage b&m shift kit msd ignition 586 hp at flywheel
#903605 - 11/13/11 07:07 PM Re: Rear End Compatibility [Re: 84ss_stock4now]
Callie100 Offline
Callie100  Offline
Adolphus, KY
We need both the ring gear and the pinion gear, 3.73 ratio, positraction. If you have one we are definately interested!
#903606 - 11/13/11 07:09 PM Re: Rear End Compatibility [Re: Callie100]
JAMZ87SS Offline
JAMZ87SS  Offline
Citrus Springs, FL
Never been a fan of running used gears... just one of the things that should be replaced new.
#903690 - 11/14/11 08:16 AM Re: Rear End Compatibility [Re: JAMZ87SS]
Retro Offline
Retro  Offline
Macon,Ga.
If they're OEM GM gears, nothing wrong with used. I don't run used Aftermarket tho'.
#903694 - 11/14/11 10:28 AM Re: Rear End Compatibility [Re: Retro]
novaderrik Offline
novaderrik  Offline
Ashby, MN
decent new aftermarket gears will be under $200 and an install/rebuild kit with all new bearings, seals, and shims for the whole rear axle will be about that much. a new posi will be the most expensive part, but you can find a good used one from another G body or 82 and newer F body for not too much.
74 Monte Carlo cruiser
#903766 - 11/14/11 10:11 PM Re: Rear End Compatibility [Re: novaderrik]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. If you actually have a removable 'pumpkin', maybe you have a Ford 9" rear end...
.. Otherwise, you're building inside a stock rear end...
.. Although rear gears and carriers from other G-bodies and some f-bodies will work if you have the stock 7 1/2" rear, the problem is 99% of them won't have 3.73 gears or posi...
.. Check Randy's Ring and Pinion for prices...
500/thumbs/stein07_01.jpg
by GregK
500/thumbs/indo_black_006.jpg
by Hailhorror77
by Monster
500/thumbs/0711111820.jpg
by tetamcssmokin
500/thumbs/DSCN3990.JPG
by Aeroaddict
