#897833 - 10/02/11 03:19 PM Front spring isolators???
Bartenfeld Offline
Bartenfeld  Offline
Cumming Georgia
Does anyone know where I can get a set of front spring isolators for an 85 ss?
#897838 - 10/02/11 03:37 PM Re: Front spring isolators??? [Re: Bartenfeld]
Is this what you are looking for ???
http://www.summitracing.com/parts/MOG-K160044/
#897853 - 10/02/11 06:21 PM Re: Front spring isolators??? [Re: GuysMonteSS]
Bad Co Offline
Bad Co  Offline
Earth
If you do get the moog ones, they only come one per box despite what the picture shows...so order two.
#897892 - 10/02/11 09:59 PM Re: Front spring isolators??? [Re: Bad Co]
15597425 is the GM part number, these are fiber, not rubber.
#898113 - 10/04/11 01:27 AM Re: Front spring isolators??? [Re: mmc427ss]
wanadrv Offline
wanadrv  Offline
Wentzville, MO
Io didn't think the front needed isolators, just the back...am I wrong? I have a set of duralast springs and auto zone website doesn't list front isolators/insulators
'82 Monte - sold
'87 SS Frame of Resto for my Son
#898136 - 10/04/11 03:49 AM Re: Front spring isolators??? [Re: wanadrv]
Front insulators came stock in my 86SS, the Helm's Service manual shows them, would think most all GM's come with them on top. They are a fiber construction, about 3/16" think, and could be stacked to adjust side to side ride height/corner weights. I've always had them installed, also installed them in a 67 Camaro to raise the front end a little. I'm not a urethane proponent, only a few places I would install it. I believe the urethane front insulators are thicker, 3/8", which would raise the ride height about 1/2" compared to having no insualtors.
The rear G's used a rubber pigtail insulator on the top. I run one top and bottom, this raises the rear about 1/8", and isolates the rear from the chassis a little better. You could effectively change the preload on the right rear tire, something like an air bag would do, by installing thicker/firmer insulators at the top and bottom of the right rear spring and running no insulators on the left rear. Just another tuning trick for the track time.
#898246 - 10/05/11 12:09 AM Re: Front spring isolators??? [Re: mmc427ss]
wanadrv Offline
wanadrv  Offline
Wentzville, MO
Thanks Bob. I just can't find the right part at my local auto zone. Where do you all get these as
'82 Monte - sold
#898252 - 10/05/11 12:41 AM Re: Front spring isolators??? [Re: wanadrv]
ShadowRuleZ Offline
ShadowRuleZ  Offline
Grand Rapids, MI
I just installed the Moog ones with my new springs, I got them from Rock Auto.
-Jerry
http://garage.twelve22.net
85 SC (body off) / 83 SC V6 (parts car)
11 Flex / 05 Vibe
#898259 - 10/05/11 01:40 AM Re: Front spring isolators??? [Re: ShadowRuleZ]
wanadrv Offline
wanadrv  Offline
Wentzville, MO
Did you install them on the upper and lower position?
'82 Monte - sold
#898262 - 10/05/11 02:07 AM Re: Front spring isolators??? [Re: wanadrv]
ShadowRuleZ Offline
ShadowRuleZ  Offline
Grand Rapids, MI
Just the upper.
-Jerry
11 Flex / 05 Vibe
#900600 - 10/23/11 10:05 PM Re: Front spring isolators??? [Re: ShadowRuleZ]
pennsman Offline
pennsman  Offline
millmont pa
Just put some in mine. Got them at napa. Had some trouble getting them to stay in place up top. I tried some rubber contact cement to try to hold them in place. It was tough but I prevailed. Motor was out so it was a real battle to compress the new global west big block springs and fight with the isolators.
85 ss 489 big block, Pro Comp Alum. heads, Scat rotating assembly, forged srp 10.1 pistons cast 9000 series cast crank. Turbo 400 trans. Currie ford 9" housing. Global west suspension. Motor dyno,d at 601.5 h.p @ 6,000 rpm. 593 ftlbs of tourque @ 4500 rpm at crank. On pump gas.
#900703 - 10/24/11 06:59 PM Re: Front spring isolators??? [Re: pennsman]
delreyss Offline
delreyss  Offline
del rey,CA
Any body have any part numbers for the poly ones
#900708 - 10/24/11 07:41 PM Re: Front spring isolators??? [Re: pennsman]
delreyss Offline
delreyss  Offline
del rey,CA
#991879 - 01/04/14 09:28 PM Re: Front spring isolators??? [Re: Bartenfeld]
SSeabee Offline
SSeabee  Offline
Wilmington, DE
What's the latest on this? I just got a new set of SPC lowering springs and was just going to put new isolators up top front and back. I was planning on getting them from either rockauto.com or SS396.com. Any current experiences or recommendations is greatly appreciated thanks. Car is used for street and strip and has a new set of Bilsteins on it now. No plans for drop spindles just wanted higher rate springs and the car lower.
Dave
#991884 - 01/04/14 10:38 PM Re: Front spring isolators??? [Re: Bartenfeld]
Silver8M86 Offline
Silver8M86  Offline
Suffolk, VA
isolator
Thie is the one you want they come 1 to a pack order 2 for the front. They are rubber they go on top of the spring. Zip tie them to the spring with 3 or 4 ties. My thread here goes through my install of moog 5664s Spring Install the stock ones i pulled off were rubber as well
#991888 - 01/04/14 11:04 PM Re: Front spring isolators??? [Re: Bartenfeld]
SSeabee Offline
SSeabee  Offline
Wilmington, DE
OK, so do I only really need to do the front ones than (I am replacing all of the springs)? Thanks for the link and info., I appreciate it.
#991891 - 01/04/14 11:16 PM Re: Front spring isolators??? [Re: Bartenfeld]
Silver8M86 Offline
Silver8M86  Offline
Suffolk, VA
I havnt done the back sorry, the tops of the rear do have a rubber piece at the top, I dont have the part number but I would definetly put a new one on
#991892 - 01/04/14 11:35 PM Re: Front spring isolators??? [Re: Bartenfeld]
Silver8M86 Offline
Silver8M86  Offline
Suffolk, VA
thats the top rear on my car
#991900 - 01/05/14 12:39 AM Re: Front spring isolators??? [Re: Bartenfeld]
GM part #15597425 for the front spring insulator, about $9 list.
GM part #10247105 for the rear spring insulator, about $16 list.
I run one on the top of the front spring, you can use electrical tape to secure it to the spring.
In the rear I run a rear insulator on the top and the bottom of the spring, two reasons, raise the rear about 3/16", also reduces noise transmited through the springs.
#991949 - 01/05/14 07:06 PM Re: Front spring isolators??? [Re: Bartenfeld]
SSeabee Offline
SSeabee  Offline
Wilmington, DE
OK got it! Thanks a lot for taking the time to take and share that pic Adam, I really appreciate it. As usual Bob your help is invaluable as well. I appreciate your help once again. Hope you guys have a great 2014!!
Dave
#991952 - 01/05/14 07:18 PM Re: Front spring isolators??? [Re: SSeabee]
gmguy3car Offline
Authorized Vendor
gmguy3car  Offline
Authorized Vendor
Silverdale,Wa
508/thumbs/291978_73_full.jpg
by 85_SS
500/thumbs/54.JPG
by Mark's SS
500/thumbs/M51.jpg
by devider440
500/thumbs/moto_0061.jpg
by dw329
500/thumbs/IMG_0009.JPG
by andiegal
