#861596 - 03/21/11 12:51 AM Jeep Steering Shaft
BlueBoy84 Offline
BlueBoy84  Offline
Northern KY
Ready to replace mine with one from a Jeep. The ends slide on fine, but on the side next to the steering column (bigger side), there isn't enough room to slide the bolt through. Those that have done this swap... is there a trick to line it up? or should it slide right in and bolt up?
#861599 - 03/21/11 12:58 AM Re: Jeep Steering Shaft [Re: BlueBoy84]
Duts87SS Offline
Duts87SS  Offline
Spanish Fort, AL USA
Bit of work with a grinder on the steering column to allow room for the pinch bolt.
Dustin
87 SS
#861614 - 03/21/11 01:46 AM Re: Jeep Steering Shaft [Re: Duts87SS]
BlueBoy84 Offline
BlueBoy84  Offline
Northern KY
Thanks! That should work. I don't need much more room.
#861625 - 03/21/11 02:09 AM Re: Jeep Steering Shaft [Re: BlueBoy84]
MonteC Offline
MonteC  Offline
Summerville, SC
Look at the column shaft. It should be flat on one side. Match the open side to the flat side and the bolt will slide pretty much all the way through. Then just tighten the bolt down with a ratchet or impact gun.
I just did mine today and it required NO modifications. Mine also has the 13mm headed bolts that are threaded all the way up.
SMCC
Broken Car Disease
#861630 - 03/21/11 02:19 AM Re: Jeep Steering Shaft [Re: MonteC]
BlueBoy84 Offline
BlueBoy84  Offline
Northern KY
I tried putting it on both ways... either way, it slides over the steering colum perfectly, but just extends out enough to keep the bolt from going through. Odd.
#861636 - 03/21/11 02:35 AM Re: Jeep Steering Shaft [Re: BlueBoy84]
MonteC Offline
MonteC  Offline
Summerville, SC
It should be a tight fit. I had to tap mine into place. If its too loose the bolt wont reach. How far off is it? Shouldnt be too far off. Might try a pair of channel locks to pull the two sides of the steering shaft cup back together while you tighten the bolt.
SMCC
Broken Car Disease
#861825 - 03/21/11 10:56 PM Re: Jeep Steering Shaft [Re: MonteC]
85t5mcss Offline
85t5mcss  Offline
Indpls.,IN
I used a round bastard to clean up the side just a hair for the bolt to go through. Probably ran the file over it 6-8 times and then no more problems. It was close to fitting.
#861899 - 03/22/11 02:45 AM Re: Jeep Steering Shaft [Re: 85t5mcss]
BlueBoy84 Offline
BlueBoy84  Offline
Northern KY
Aside from making sure the wheels and steering wheel are lined up straight...any other thing I need to know?
#862095 - 03/22/11 11:06 PM Re: Jeep Steering Shaft [Re: BlueBoy84]
85t5mcss Offline
85t5mcss  Offline
Indpls.,IN
Not really. Pretty straight forward once u look at it. And u can get rid of the ugly plastic cover.
#862111 - 03/23/11 12:20 AM Re: Jeep Steering Shaft [Re: 85t5mcss]
MC87SS Offline
MC87SS  Offline
Tallahassee, Florida
Just did mine this weekend, took 15 mins including a break. LOL
I made a small notch with my cutoff wheel for the bolt.
Remove both bolts from the old shaft but before removing it lock the steering wheel. Slide the new shaft on both top & bottom. Them you can un-lock the wheel and turn it to install the new bolts. This way everything aligns just the way it did before you removed it.
Here is a video floating around on the web.
Yes its really that easy.
http://www.tuneyfish.com/video_player.php?vid=220
737/thumbs/small_DSC00316.jpg
by McNamee
500/thumbs/MCSS4.jpg
by Wrathchild
500/thumbs/SD530544.JPG
by pearl83SS
500/thumbs/87_Monte2.jpg
by mightymonte10
500/thumbs/Photo_4.JPG
by Chief Jimbo
