#860666 - 03/16/11 06:38 PM Indexing front coil springs
MonteC Offline
MonteC  Offline
Summerville, SC
Im running UMI upper and lower control arms and I want to know if and how to index the coil springs correctly. The springs are a 3" drop spring.
It seems like every corner of the car sits differently. Should the backs be indexed as well? They are just stock. But like I said ive got a different ride height at each wheel.
I would think the two fronts should be the same and the two backs should be the same.
SMCC
Broken Car Disease
#860771 - 03/17/11 01:52 AM Re: Indexing front coil springs [Re: MonteC]
Radar43 Offline
Radar43  Offline
Lebanon, tn
What does index the coil springs mean? Do you do this for a stock restoration?
#860775 - 03/17/11 01:56 AM Re: Indexing front coil springs [Re: Radar43]
MonteC Offline
MonteC  Offline
Summerville, SC
Putting them a certain way, and having them both the same way.
SMCC
Broken Car Disease
#860777 - 03/17/11 02:10 AM Re: Indexing front coil springs [Re: MonteC]
BBwagon Offline
BBwagon  Offline
Burke, Virginia
Have you check that they are all installed correct side up?..Sounds silly but it happened to me, my car sat all funky untile I figured it out...And also are they new springs? They usually need a day or 2 of driving to help them settle.
#860829 - 03/17/11 06:23 AM Re: Indexing front coil springs [Re: BBwagon]
71BLACKSS454 Offline
KENOSHA WI. 53140
The tops are usually marked with a white stripe, You also need to make sure the end of the bottom coil sits in the notch of the lower control arm correctly.
One owner 1983 MC 40,000 miles. Our very first new car.
Third owner 1971 SS454 Monte Carlo, one of 1919 built.
2014 Silverado High Country 6.2
2013 Equinox daily commuter
2015 Equinox wife's car
#860840 - 03/17/11 11:42 AM Re: Indexing front coil springs [Re: 71BLACKSS454]
MonteC Offline
MonteC  Offline
Summerville, SC
Used springs. I didnt notice any marks on them and my control arms dont have a notch.
SMCC
Broken Car Disease
#860854 - 03/17/11 01:39 PM Re: Indexing front coil springs [Re: MonteC]
barry4219 Offline
barry4219  Offline
fort wayne in.
when I put mine back together the lower control arm had a notch to put the end of the spring in and the upper end of spring was flatter so it would sit in the frame pocket evenly . If put in up side down it would not sit correctly . also make sure the upper spring pad is still in place .
#860877 - 03/17/11 04:30 PM Re: Indexing front coil springs [Re: barry4219]
^What he said. The top is a box end, the bottom is tangential. The bottoms fit into a notch in the stock lower control arm. If your aftermarket arms don't have a spot for the notch, I guess I'd just put the notch towards the outside of the car.
The rears shouldn't matter, but the front being off can cause the rear to be off.
#861200 - 03/19/11 04:51 AM Re: Indexing front coil springs [Re: SickSpeedMonte]
baaboo Offline
baaboo  Offline
Racine, WI
I thought that the manual said to have the spring end near one of the holes for drainage. In other words, don't cover both holes. i thought that the rears, by factory design, should have the bottom end pointing outwards too.
#861221 - 03/19/11 02:31 PM Re: Indexing front coil springs [Re: baaboo]
Hey-O Online smokin
Hey-O  Online Smokin
Ballwin, Mo
End of coil goes between the 2 holes. Cover one, leave one exposed . Thatís what it said in the instruction that came with my springs . No indexing on the rears from what I remember .
#861238 - 03/19/11 04:12 PM Re: Indexing front coil springs [Re: Hey-O]
MonteC Offline
MonteC  Offline
Summerville, SC
I dont have stock control arms.
SMCC
Broken Car Disease
#861241 - 03/19/11 04:25 PM Re: Indexing front coil springs [Re: MonteC]
Project SS Offline
Project SS  Offline
Minnesota
So if you compress the spring to remove,do they "pop" out of these notches or do you have to try turn them?
#861745 - 03/21/11 03:52 PM Re: Indexing front coil springs [Re: Project SS]
They just sit in the notches, they don't get inserted. It's really just a "spring shaped relief" more or less.
#861822 - 03/21/11 10:51 PM Re: Indexing front coil springs [Re: SickSpeedMonte]
Project SS Offline
Project SS  Offline
Minnesota
Once I got the right compressor they came right out,but the bottom coils were broke
871/thumbs/Foose_7.jpg
500/thumbs/car001-1-1.jpg
by greenmoonshine
500/thumbs/DSCF0832s.JPG
by TriumphoverU
500/thumbs/cowl_hood_003.jpg
by GearedSS
500/thumbs/photo_5_1.JPG
by 83/84/86*2/87ss
