#854669 - 02/18/11 04:29 PM
Re: Need some help - timing cover oil seal
[Re: BlueBoy84]
GuysMonteSS
Looks like the old one is stil in place,so first you've got to drive that one out.I have used a large socket app the same size as the seal,although a small block of wood may also work.The new one has to be driven in perfectly even,if it goes in crooked,you may as well drive it back out and get another one.Take your time doing this. Guy
#854677 - 02/18/11 04:48 PM
[Re: GuysMonteSS]
redlineSS
South Jersey
You may also want to check the condition of the snout and add a repair sleeve if there is any grooves or wear on the shaft. If not done then the new seal will leak and you will have to repeat the proceedure. I automatically do this to every SBC engine I rebuild, just as insurance!! http://www.autozone.com/autozone/parts/F...344155_59106_0_Felpro also makes a REAR sleeve repair kit for "One Piece" rear main seals!
~Dave~ Monte Carlo...."Born on the Track, Driven on the Street"
#854794 - 02/19/11 05:50 AM
[Re: redlineSS]
baaboo
Racine, WI
THERE IS A METAL LIP PROTECTING IT FROM THE BACK, SO DON'T BEAT ON THAT OR YOU'LL RUIN THE COVER. Go around/inside the lip to tap the old one out.
#854803 - 02/19/11 06:17 AM
[Re: baaboo]
SS402
Beaverton, Oregon
THERE IS A METAL LIP PROTECTING IT FROM THE BACK, SO DON'T BEAT ON THAT OR YOU'LL RUIN THE COVER. Go around/inside the lip to tap the old one out. yup, go around in a circle with a tapered punch and ball peen hammer, slowly work it out. put a very thin layer of sealant around the new seal and place a 2 x 4 over the seal when driving it back in, just keep it square and you'll be just fine.
George Monte, Gone but not forgotten The More I Learn About Dogs The Less I Like About People
by BigTony
by ray396
by 02intimidator
by JC104kx
by StripedSS
