#849805 - 01/26/11 04:01 PM Underhood Aluminum
What have you guys used to brighten aluminum? I would like to brighten up the serpentine brackets and alternator housing.
85 - ZZ383, 6-speed, 8.5"
70 - Stock, 35k miles. Scratch that, no longer stock.
#849807 - 01/26/11 04:06 PM Re: Underhood Aluminum [Re: FrankOC]
white diamond is tops
http://www.whitediamondamerica.com/
this stuff is great
#849811 - 01/26/11 04:20 PM Re: Underhood Aluminum [Re: tonys57chevy]
The alternator and serp brackets are not a smooth surface though so I don't think a polish would work.
#849814 - 01/26/11 04:45 PM Re: Underhood Aluminum [Re: FrankOC]
Know anyone with a bead blast cabinet?
#849816 - 01/26/11 04:53 PM Re: Underhood Aluminum [Re: SSLance]
Autosol metal polish is great as well. The big brands like Mothers and NEVR-DULL are garbage compared to it.
As mentioned - the brackets aren't super smooth so you'd probably want to use compounds to get those polished up nicely. Some people might not like this much black, but I painted almost everything satin black for a factory type look that blends in a bit more. I needed a new compressor after it was installed and left it alone.
Before:
After:
#849823 - 01/26/11 06:00 PM Re: Underhood Aluminum [Re: 85_SS]
it will frank if you dont do it by sea pirate i will show you
#851158 - 02/02/11 10:44 PM Re: Underhood Aluminum [Re: tonys57chevy]
Houlie Offline
Houlie  Offline
Spencer, MA
get them ceramic coated Frank....cleaning is as easy as windex and an airhose
#851646 - 02/05/11 06:03 AM Re: Underhood Aluminum [Re: Houlie]
85lolo Offline
85lolo  Offline
radiator springs
what about a stock intake manifold? hard to clean with the texture
#852182 - 02/07/11 11:30 PM Re: Underhood Aluminum [Re: 85lolo]
have it glassbeaded then clear powder coated
#853878 - 02/15/11 01:31 PM Re: Underhood Aluminum [Re: tonys57chevy]
#853903 - 02/15/11 03:55 PM Re: Underhood Aluminum [Re: FrankOC]
frank trust me on the one i posted
#853928 - 02/15/11 05:57 PM Re: Underhood Aluminum [Re: tonys57chevy]
I want to brighten the aluminum that has darkened over time. I think it will be difficult to apply a wax to the rough cast aluminum.
#853933 - 02/15/11 06:21 PM Re: Underhood Aluminum [Re: FrankOC]
i even used it on diamond plate and brought up to a high luster. i will have to get some rough cast aluminum do it and take pics for you
#853940 - 02/15/11 06:44 PM Re: Underhood Aluminum [Re: tonys57chevy]
Crusher Offline
Crusher  Offline
Jersey Shore
If you car to disassemble I would suggest painting them with a high heat aluminum color. Brand name escapes now but if your interested I'll check a can out when I get home. My aluminum intake is painted with it(5 years ago) and it looks like a new aluminum intake that never yellows. My headers and exhause is also painted with it. Gas, oil, and grease clean right off. Just a suggestion to a guy I know in Mass.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
http://SSMonteCarlo.com
#853942 - 02/15/11 06:52 PM Re: Underhood Aluminum [Re: Crusher]
I think that is what I'm going to do with my intake manifold. when it was brand new, I put high temp clear on it, which is now yellow... mad
I just need to figure out if I can get it cleaned and prepped enough for paint without removing it from the engine.
#853944 - 02/15/11 07:00 PM Re: Underhood Aluminum [Re: SSLance]
Crusher Offline
Crusher  Offline
Jersey Shore
I believe I used Krylon Brand. I'll get a part number for you. I know not everyone carries this color so I ordered a case of it once. I swear by it, has never left me disappointed.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
#853948 - 02/15/11 07:11 PM Re: Underhood Aluminum [Re: Crusher]
Yes, definately interested. I never would have guessed your intake is painted.
#853949 - 02/15/11 07:12 PM Re: Underhood Aluminum [Re: FrankOC]
Crusher Offline
Crusher  Offline
Jersey Shore
Exactly....
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
#853959 - 02/15/11 08:10 PM Re: Underhood Aluminum [Re: Crusher]
i did this quick and only had alittle left in the bottle
before
after
#853960 - 02/15/11 08:14 PM Re: Underhood Aluminum [Re: tonys57chevy]
Crusher Offline
Crusher  Offline
Jersey Shore
Not bad but I can see it anodizing all over again already...lol
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
#853961 - 02/15/11 08:17 PM Re: Underhood Aluminum [Re: Crusher]
you can clean it up the powder coat it clear also.
this stuff holds up good ad its easy on and off the blacker your cloth gets the better
#853963 - 02/15/11 08:19 PM Re: Underhood Aluminum [Re: tonys57chevy]
Crusher Offline
Crusher  Offline
Jersey Shore
Tony, where do you buy that stuff...
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
#853966 - 02/15/11 08:24 PM Re: Underhood Aluminum [Re: Crusher]
online or i think advanced has it now . i got mine at a bike shop down here. i am thinking of becoming an Affiliate to sell this stuff i like it as much as i like zaino.
i buy alot of stuff try it all and only tell people what i feel works good
#853967 - 02/15/11 08:26 PM Re: Underhood Aluminum [Re: tonys57chevy]
what i cleaned was on my 95 suburban it has never bee used on it before i did this for frank. dam you frank now i have to buy more and do it all lol
#853968 - 02/15/11 08:26 PM Re: Underhood Aluminum [Re: Crusher]
redlineSS Offline
redlineSS  Offline
South Jersey
Cast Aluminium Paint = Dupli-Color High heat ceramic engine enamel #DE 1650 (good up to 500 degrees)
That is what I use on aluminium parts under the hood!
By the CASE:
http://www.themanstoreonline.com/Dupli-Color-Engine-Enamel-with-Ceramic-p/dupli-color%20engine.htm
~Dave~
539/thumbs/Cnv0011.jpg
by Performance
500/thumbs/IMG_9648.jpg
by jnw86
536/thumbs/22.jpg
by ssmnt408
500/thumbs/20120403_201914.jpg
by valvefloat ss
500/thumbs/27.JPG
by Mark's SS
