Page 2 of 2 1 2
#841219 - 12/09/10 02:34 AM Re: Custom Gauge Cluster [Re: the_merv]
BP One Offline
BP One  Offline
Lyman, SC
Originally Posted By: the_merv
Originally Posted By: BP One
What kind of Aircraft is that from?
Ha ha... nothing quite that exotic I'm afraid. It's actually out of an 86 Pontiac Grand Prix I found through the G-Body Forum site. I found a guy parting out 12 or so.
He's primarily a Buick guy and didn't have any SS parts. Since I'm customizing my SS, a little "cross pollination" seemed like a good solution for a custom dash with a bolt-in approach.
Brian
Brian
My Homepage
1987 Monte Carlo SS
1987 Monte Carlo LS
2001 Silverado
#841223 - 12/09/10 02:41 AM Re: Custom Gauge Cluster [Re: BP One]
the_merv Offline
the_merv  Offline
Northern, Florida
Ya I hear ya. It's kinda big tho..lol..
1984 MONTE CARLO SS 6spd
#841266 - 12/09/10 01:41 PM Re: Custom Gauge Cluster [Re: BLUEKNT]
Tony_SS Offline
Tony_SS  Offline
Washington, MO
Originally Posted By: BLUEKNT
Oh yes. I told him i was using autometer gauges and which gauges(fuel,temp)were going in the shadow box. The other two gauges were going into a pillar pod. When I got the harness every gauge had the correct leads it needed. He even went as far as making long leads for the pod with disconects at the harness for easy removal.I wired the whole shadow box inside the house. I cut the stock plug off and replaced it with his. Finally plugged the showbox into into the new harness plug and bolted it into place.
It was definitely worth the money to me.
You had to cut the stock plug off though???
#841311 - 12/09/10 06:09 PM Re: Custom Gauge Cluster [Re: BP One]
Brian
Make sure you get the connectors from the GP harness as well if you want to use the GP dash's turn signals, choke light, etc.
The GP dash uses different connectors than the Monte, but it's pretty easy to repin using the Monte harness to get everything working.
I did this earlier this year, so let me know if you have any more questions and I can try to help with more details on wiring diagrams as it looks like you have an '87 Monte as well.
#841449 - 12/10/10 01:31 PM Re: Custom Gauge Cluster [Re: SS Ninja]
BP One Offline
BP One  Offline
Lyman, SC
SS Ninja:
Yes, any insight would be very helpful. You mentioned the GP harness, if you mean the part attached to the dash, yes the guy who pulled it was very thorough (hence my high rating of him as a seller) and sent me this:
I was wondering about the re-pinning method as I do want to keep the stock signal light, high beam etc. indicator lamps. Then I plan on installing some old school Stewart Warner gauges for a no-nonsense performance look.
If I can pull off what I've designed in my head in the real world, I think it'll be a great custom touch to my Monte. I'm doing the body work now, if I get her into the paint booth by spring, I should be ready to install this in the fall. I hope.
Brian
Brian
My Homepage
1987 Monte Carlo SS
1987 Monte Carlo LS
2001 Silverado
#842155 - 12/14/10 04:50 PM Re: Custom Gauge Cluster [Re: 84LS1T56SS]
Greasy Offline
Greasy  Offline
san antonio tx
Originally Posted By: 84LS1T56SS
I got one of their shadow boxes and installed all of the gauges myself. If I had to do it again, I would go with their plug and play harness.
Got Pics??
1984 Monte SS 383 stroker
World Sportsman II heads, 200cc intake 64cc chambers 2.02/1.60 valves
Comp Cams Xtreme Energy XR276HR roller cam 276/282 duration .502/.510 max lift
Weiand Street Warrior intake
Holley 750cfm vac secondaries
#844517 - 12/29/10 10:30 PM Re: Custom Gauge Cluster [Re: Monster]
JBreu Offline
JBreu  Offline
Livonia,N.Y.
Originally Posted By: 84monsterSS
i made my own, using black plexiglass and equus 8000series guages
Man that looks great......I want one just like that, however I was thinking just the speedo, oil/temp and gas guege....YOu should make some and sell them...!!
1984 Monte Carlo sbc bored/stroked to 388 c.i. 514 Dynoed HP.700r4 w/2000 stall,12 Bolt w/4:10
Old Chevy's Don't Die, They Just Get Faster
Best E.T. to date : 12.20 @ 110 MPH All Motor
#844534 - 12/29/10 11:48 PM Re: Custom Gauge Cluster [Re: BP One]
twinturboSS Offline
twinturboSS  Offline
Houma, Louisiana
Wow, some really neat ideas here. Of all of them I kind of like the Classic Dash plate the best. But for my needs (street car with full A/C etc.) I decided on a different dash all together:
No matter how I looked at things, this provided the best solution for me. Not to knock any of the other cool solutions, just thought I'd share my approach as well. The stock SS cluster was just too jammed together to suit me.
Brian
i love that dash. i like to stay close to stock. if i wanted to change my dash in my 85 this would be the route i would take.
#844945 - 12/31/10 09:07 PM Re: Custom Gauge Cluster [Re: JBreu]
Monster Offline
Monster  Offline
ArroyoLawns
thought about it a while back, but some vendors didnt like that idea, so i jus giv up......
#845031 - 01/01/11 01:27 AM Re: Custom Gauge Cluster [Re: Monster]
texlurch Offline
texlurch  Offline
Houston, TX
I just went with Dakota Digital and it matches the blue in the Pioneer stereo.
#961364 - 02/08/13 05:35 PM Re: Custom Gauge Cluster [Re: Greasy]
Zeke Offline
Zeke  Offline
Mexico City
Yeap, thats right, in Mexico all the Monte Carlo came with that dashboard panel, itīs a perfect fit, you should not have any problems.
#961381 - 02/08/13 09:49 PM Re: Custom Gauge Cluster [Re: Greasy]
Texas85SS Offline
Texas85SS  Offline
Gatesville TX
I'm awaiting this set up
http://www.dakotadigital.com/index.cfm/p...prod/prd788.htm
Only difference is I got it in carbon fiber and blue. I was debating about Auto meter and a couple others. By the time I priced everything, it came out to be just a little less than what I paid for the Dakota's.
I really wanted to keep it as factory looking as I could. Yeah I know those gauges are expensive but what isn't anymore.
Everyone's looks good.
#961384 - 02/08/13 10:37 PM Re: Custom Gauge Cluster [Re: Greasy]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Yes, imo, the GP dashes are the best all around dash upgrade. And they were and are far more resistant to cracking than the Monte dashes. I am going the GP dash route in my 80 Monte project-I have several of these dashes left and they make for a lotbof options for aftermarket gauges. I am leaning towards the Nexus Autometer gauges-they blackout when turned off-cool as heck!
gbodyparts1234@yahoo.com
HARNESSWORX
#961675 - 02/11/13 05:25 PM Re: Custom Gauge Cluster [Re: Greasy]
Zeke Offline
Zeke  Offline
Mexico City
I need the instrument panel (wood) from the GP dash, I was wondering if anybody has one for sale?
#962275 - 02/17/13 01:05 AM Re: Custom Gauge Cluster [Re: Texas85SS]
chevelle502 Offline
chevelle502  Offline
Dundalk. MD
Let us know how that install goes with the Dakota VHX system. Im really leaning towards it, but upon reading the install manual i got cold feet..lol.
Black w/T-tops
#962278 - 02/17/13 01:19 AM Re: Custom Gauge Cluster [Re: Greasy]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
I also ordered the Dakota gauges but ordered mine through Mikesmontes... I will post up my install as well in hopes that my LS swap actually runs lol
2015 GMC Sierra Denali
#962337 - 02/17/13 05:32 PM Re: Custom Gauge Cluster [Re: Greasy]
MikesMontes Offline
Authorized Vendor
MikesMontes  Offline
Authorized Vendor
west central ohio
we can get them all at better price than dakota Mike
www.mikesmontes.com
1-800-811-5851
Page 2 of 2 1 2
500/thumbs/monte52.jpg
by Spider_carb
519/thumbs/DSC00037.JPG
by Ted88SS
862/thumbs/th_P32802642.jpg
by 02intimidator
500/thumbs/MCSS6.jpg
by Wrathchild
527/thumbs/88SS_355_finished1.jpg
