#639 - 07/21/04 09:58 PM
A/C serp setup is complete!!!
85SSMan
Wichita, Kansas
I finally finished my Air conditioning swap in my 85SS. I put in the serp setup w/AC from a 90' camero. Total project cost my about $200.00. I'm so happy If anyone has any questions on how to get your A/C or Cruise working after tearing out all your C/C harness, let me know. I have been through both systems completely. Chris
 1985 Monte SS, Rebuilt L69 with TPI. 200-4R Tranny. 951 Modine with TPI duel fans. True 2 1/4 Flowmaster Duals. B.F.H. made dual hump crossmember. Stock Suspension, interior, and body. SOLD TO INTMDATR3 ON 03/04/06
#640 - 07/23/04 02:39 PM
Re: A/C serp setup is complete!!!
Sparkee
Central ILL
COOL!, At least I hope it is cool, or something is wrong. I have that same serpentine setup in my car, but don't have the AC hooked up yet. I have a condensor from a 307 Olds with the passenger side fittings. What hoses and other parts did you use? Thanks and have a good one!
There is no such thing as too much horsepower, as long as you can put it to the ground!!
#643 - 09/29/05 12:49 AM
ss4ever
Moderator 15+ Year
Moderator 15+ Year
Shelbina, Missouri
Originally posted by 85SSnftw: Originally posted by 85SSMan: I finally finished my Air conditioning swap in my 85SS. I put in the serp setup w/AC from a 90' camero. Total project cost my about $200.00.
I'm so happy
Chris can you please share the info ?I used a serp setup from a 88 Camaro. I used the F-body AC lines along with a 87 v-6 cuttlas condenser and the high pressure line from it. You can also use the AC lines from a 307 equiped cuttlas and they will fit much better, I had to bend up the F-body lines a little to get them to fit correctly. Randy
by monte_ss_freak
by Matt?
by Chief Jimbo
by cs85ss
by blkcharlotteman
