#639 - 07/21/04 09:58 PM A/C serp setup is complete!!!
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
I finally finished my Air conditioning swap in my 85SS. I put in the serp setup w/AC from a 90' camero. Total project cost my about $200.00.
I'm so happy
If anyone has any questions on how to get your A/C or Cruise working after tearing out all your C/C harness, let me know. I have been through both systems completely.
Chris
SOLD TO INTMDATR3 ON 03/04/06
#640 - 07/23/04 02:39 PM Re: A/C serp setup is complete!!!
Sparkee Offline
Sparkee  Offline
Central ILL
COOL!, At least I hope it is cool, or something is wrong. I have that same serpentine setup in my car, but don't have the AC hooked up yet. I have a condensor from a 307 Olds with the passenger side fittings. What hoses and other parts did you use? Thanks and have a good one!
There is no such thing as too much horsepower, as long as you can put it to the ground!!
#641 - 09/28/05 11:10 PM Re: A/C serp setup is complete!!!
85SSnftw Offline
85SSnftw  Offline
ftw tx
I'm so happy
Chris
can you please share the info ?
#642 - 09/29/05 12:04 AM Re: A/C serp setup is complete!!!
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
I got mine working also but my only problem is wiring in the electric fan for AC.
Randy
#643 - 09/29/05 12:49 AM Re: A/C serp setup is complete!!!
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
I'm so happy
Chris
I used a serp setup from a 88 Camaro. I used the F-body AC lines along with a 87 v-6 cuttlas condenser and the high pressure line from it. You can also use the AC lines from a 307 equiped cuttlas and they will fit much better, I had to bend up the F-body lines a little to get them to fit correctly.
Randy
#644 - 09/29/05 03:11 AM Re: A/C serp setup is complete!!!
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
I used the A/C system from the Camero that I got the serp setup from. I used the condenser which is exactly the same size as the Monte, but the lines are on the passenger side, then the A/C lines from the Camero bolt right into place, wham bam, charge it up and go. If you need info for your cruise search the forum for "Cruise without ecm". If this doesnt help, be more specific and we will help you out.
Chris
#645 - 09/29/05 05:26 AM Re: A/C serp setup is complete!!!
SSScottSS Offline
SSScottSS  Offline
S/E Wisconsin
CAMARO had to make that little correction :p
#646 - 09/29/05 08:35 PM Re: A/C serp setup is complete!!!
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
Thanks, I suck at spelling, but usually my wife corrects me.
500/thumbs/IMG_0543.JPG
by 565bbchevy
500/thumbs/ticket_041.jpg
by BHP
500/thumbs/resize3.JPG
by dandantlm
921/thumbs/P1010032.jpg
by BigTony
500/thumbs/3-3.jpg
by dh85ss
