#1073355 - 03/03/22 05:21 PM
Re: SSLance's Build thread
[Re: SSLance]
Ron, you had me giggling, checkbook car. A friend has a 67 Dart, 440, pulled the dual quads and went to a single Holley. Currently swapping the mufflers for hoping quieter at highway speeds. A year ago sold his 69 AMX because he got tired of the fixing the gremlins (not as in AMC). Bought a sweet 100 year anniversary 2014 Challenger with a 6 spd about two years ago. What does he like to drive, the Challenger because it easy, gets good mileage, and comfortable. He's always talking about doing ProCharger on that car and selling the Dart. The Challenger is a checkbook car, the procharger is a large checkbook item that someone else would install and tune. He's old like me, and tired of playing with cars. They advantage to the new stuff is you can just pay someone to tune your stuff, you don't need to struggle with carbs and the rest of the fun stuff we struggled with. It comes in a can now called a laptop. Bob
#1073356 - 03/03/22 06:59 PM
[Re: SSLance]
SSLance
The best part is taking that floppy granny car that you built with your own hands and using it to whup up on the check book hot rod cars on a regular basis. I REALLY enjoy that part of my hobby... Beating the LS swap guys with my SBC is secondary in my enjoyment factor, but still very prominent.
#1073359 - 03/04/22 01:45 AM
[Re: SSLance]
Buick Runner
The best part is taking that floppy granny car that you built with your own hands and using it to whup up on the check book hot rod cars on a regular basis. I REALLY enjoy that part of my hobby... Beating the LS swap guys with my SBC is secondary in my enjoyment factor, but still very prominent.  It seems people put way too much emphasis on modernizing everything when being old gen powered is the least of the issues in G bodies. Cars are much more complicated than just the engine or its power output. I installed several braces and poly body mounts and I am still getting stress cracks from just a 305 and some cracks came from the old 231!. Personally I would never install a DBW engine in a car that predates it. Throttle response is akin to the trigger pull on a firearm, with both the feel can highly affect performance even with skilled users. Only analog controls for me when I can help it.
#1073363 - 03/04/22 02:56 AM
[Re: SSLance]
SSLance
The tuners will tell you they can tune the DBW setups to be however you like. I've yet to experience that in person though... I've hated every one that I've ever raced. Even the one with a bungee cord hooked to the throttle pedal and the bottom of the dash trying to stiffen the throw up to make it less touchy...
#1073365 - 03/04/22 03:55 AM
[Re: SSLance]
1 Slow SS
I never was a fan of the drive by wire either, I prefer 24x.
As a car builder I always target a good foundation. Starting with a car too fare gone because it's cheap isn't cost and quality effective. Scrap the old cracked Buick and find a new car your happy with for safety reasons.
#1073367 - 03/04/22 06:03 PM
[Re: SSLance]
Buick Runner
DBW can't fully replicate the feel of drive by cable even if they tried due to physics. Most DBW includes a self learning feature to learn your driving styles. That means over time it learns to ignore small changes in pedal position and becomes lazier over time. Not sure if tuners can tune out the self learning feature.m
My Regal is pretty rust free with mint floors and body mount bolts and was driven by my grandparents, a real creampuff. Even then it still developed roof stress cracks. Its not uncommon at all for G bodies to have roof stress cracks and body warpage issues. Seen plenty of it on other G bodies. In the 80's GM really downsized the body structure, deleting many of the braces 70's G bodies had to save costs.
Its a very well known issue that the pillars on stock G bodies are poorly attached to the roof and crack the body lead from flex. On my Regal the factory used a single spotweld on the driver side B pillar, and a single spot braze on the passenger side. Still not sure why they used two different methods on each side. Typical GM body build quality back then.
#1073368 - 03/04/22 06:22 PM
[Re: SSLance]
BadSS
I think Runner just got a lemon of a Buick. Should have gotten an SS. I was yanking the tires and running LOW 10s on the spray with no additional bracing other than the upper to lower control arm brace and just got one small stress fracture near the roof line on the driver’s side front pillar after 7 years of abuse and hundreds of races. Added an 8 point cage not long afterward purely for my safety but it apparently prevented any other stress fractures that MIGHT have happened during another 4 years of daily driving and another 100 or so races and countless test and tunes. I think for a wet noodle of a granny car it’s held up fairly well. 😃
#1073373 - 03/04/22 08:33 PM
[Re: SSLance]
Buick Runner
Regals, including TRs and GNs lack 4 to 6 ĺower mounting bushings, the #5 bushings, and the F41 front frame braces. Even then there are still plenty of SSs with stress cracks too.Roll cages do improve the rigidity of autobody structures and reduce stress cracks.
#1073376 - 03/05/22 12:18 AM
[Re: 1 Slow SS]
Buick Runner
Buick,
I'm not sure you understand the LSx platforms options. A 24x is a reluctor wheel uses a throttle body driven by a cable verses electric actuator. Mast motorsport sells most of their engines in this configuration. I'm sure, but by now you could even run 58x with a cable drive throttle body I believe. The early LS1 cars were 24x and all were cable driven from GM as the rest of the fleet in those years.
I don't know... I have frame offed several G body cars. My last pro street Monte I made a hard top out a T top car and it was loaded with welds at the B pillars on each side. I do have tons of experience that makes me drag you down to my level. So I do apologize for sharing my observations.
I was going by the Erod crates that only come with DBW and really the only LS option with all the proper legality paperwork for strict enforcement areas. Cobbled together aftermarket or non stock configuration OEM computer control systems run into legality issues. But that is a whole other topic I really don't want to dive into. I removed the body filler on my roof seams down to bare steel and pulled out the quarter windows. Only saw a few spot welds or spot blazing depending on the side of the car. G bodies are well known and documented for having minimum weld joining at the pillar tops. Here are a few images of other people's cars from the net. ![[Linked Image]](https://i46.photobucket.com/albums/f117/853csb/bodywork20d.jpg) ![[Linked Image]](https://i46.photobucket.com/albums/f117/853csb/crack.jpg) As you can see, the problem is GM only attached the roof to the B pillar with a spot weld or spot blaze in the middle of the pillar with no support at the door opening or quarter window corners. On my car there were large gaps in the quarter window corners GM just applied body filler over, a rookie mistake that even halfbutt bodymen will tell you to avoid. On my car I added more spot welds to the seams to reduce flexing and welded the corner gaps closed. Along with a full sell of poly body bushings including the #5s, Tinman rear seat brace that I welded in, homemade rear frame Jeff bar, front GP bar, etc. This was after lifting the body off the frame to weld a repair washer to the passenger side #2 frame mount hole, a common trouble spot on G bodies caused by the poorly designed HVAC drain. That was besides finding GM sealed two holes in the firewall with foam that I had to clean up and reseal with 2K epoxy sealer. To put it simply: "Wow, body flex for ride comfort? That's not a cool tradeoff." "Yeah, but it was late seventies Detroit. Cocaine is a hell of a drug."
#1073472 - 03/17/22 01:34 PM
[Re: SSLance]
SSLance
Good Guys registration today, racing starts tomorrow.
As I continue to tweak and fine tune the new rear suspension I continue to learn more about how the changes affect the handling. This weekend will be interesting as we because totally different kind of course.
Wish me luck!!
#1073497 - 03/24/22 02:49 AM
[Re: Buick Runner]
Travis Jones
DBW can't fully replicate the feel of drive by cable even if they tried due to physics. Most DBW includes a self learning feature to learn your driving styles. That means over time it learns to ignore small changes in pedal position and becomes lazier over time. Not sure if tuners can tune out the self learning feature.m Sorry to go back to the future... but I wanted to touch on a few things here. I'm running a DBW throttle and its 1:1 in relation to the pedal. There's no delay or or self learning. It is almost too touchy when you're in a parking lot, but that can be tuned out easily, depending on the ECU. For the record GM 24x engines came with DBW (corvettes, some later trucks) and mechanical cable operated throttle bodies (trucks and camaros). 58x is all DBW from the factory, unless you run an aftermarket ECU, then you can use a cable TB. DBW can do a lot of stuff that you cant do with a cable TB like throttle controlled soft rev limits, (spark cut limiters sound cool but are rough on engines) traction control, stability control, and it is also virtually impossible to stall my car because of the way the ECU is tuned. The other advantage of the 58x engine is cam phasing, but it can be costly to implement in a performance application. Then again, the guy who tunes my stuff does nothing but tune LS/LT motors on a dyno all day for an OEM, so maybe I'm spoiled.
#1073503 - 03/25/22 09:21 AM
[Re: SSLance]
BadSS
Good Guys courses are a blast, don't let anyone ever tell you otherwise. This one was a bit challenging and took me all day Friday to finally figure out. Raising the Rev Limiter 250 RPM, raising the PHB, rotating the tires, adding compression up front and adding rebound in the rear all helped...but pulling my head out of my arse on my tenth run seemed to make the largest difference in my times. https://youtu.be/SVJwjo-QciY Man, that thing is moving on. Could your clutch be slipping a little, or maybe getting into some timing retard? Maybe it's just not being in the car (camera/sound effect). If you need a couple hundred extra RPM, you could get rid of those 2.5" FlowBastards - lol.
#1073507 - 03/25/22 06:17 PM
[Re: BadSS]
SSLance
Naw, it was just an extra long front straight...longer and straighter than usual. I was in the limiter at 6350 halfway down it and just rode the limiter til the end in this video. I had the limiter set at 6600 and according to the dash tach and the data log, it never got over 6350. I raised it to 6850 and it would rev to 6750 and hit the limiter. That meant I could stay in first gear and only ride the limiter the last 100' or so of the front straight. The Flowbastards certainly weren't what was holding me back on this track, if anything...them choking the horsepower down most likely helped me vs hurt me. Once I figured out how to make this thing turn, I was back to the same old problem, not enough forward bite to get off the corners as fast as needed. At least it was spinning the tires going straight forward instead of hanging the back end out while roasting them... This thing ran on Saturday, talk about forward bite!! ![[Linked Image]](https://photos.smugmug.com/Other/i-sjccZPH/0/2f7f239c/X2/276202315_1643858752633012_7715008580186236393_n-X2.jpg) While he had heaps of forward bite, he was lacking in lateral roll resistance... ![[Linked Image]](https://photos.smugmug.com/Other/i-RQwLPNR/0/9449be59/X2/277104378_1643858759299678_8779443002420650638_n-X2.jpg) This incident on his second run got him a "please don't return" reward... The crowd LOVED it though...
Moderated by 345HP87SSAC, 85_SS, Dalt10, Gruvin, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, Z65_Paul
by Ted88SS
by ProTourAero
by vino2216
by 84supersport
by Greg Talbott
