#784656 - 04/13/10 07:19 PM serpentine belt system vs V-Belt
blackpearl7051 Offline
Kailua, Hawaii
so i have a new serpentine system from GM Performance. i don't know how to connect my new harness to my old one. the new one has four wires and the old one had one that went to the fire wall and the other was a ground i think.
383 6"rods 3.75 stroke, forged -12cc pistons, 64cc heads (190 int 175 ext) thumpr 279 hyd flat tap (lift in .479 x .465), 1.6 roller rockers, true dual valv springs, HV oil pump, harden pump shaft, edlebrock performer rpm intake, thunder 750 man carb, 6grove serp belts, HEI dis, alum radiator, derale 4k cfm electric fans, 2k stall, rblt th350,
#784659 - 04/13/10 07:26 PM Re: serpentine belt system vs V-Belt [Re: blackpearl7051]
Gruvin Offline
Gruvin  Offline
Texas
http://www.montecarloss.com/community/ub...;gonew=1#UNREAD
This thread will have the answer to what you need to do to wire in the Alt(you will need to extend the wiring since the ALT moves from Pass side to Drivers), you will also need to extend the AC wiring since it moves the AC compressor from driver to pass
Summit used to have the GM instructions for installing the kit but it should have come your kit
#784855 - 04/14/10 09:53 AM Re: serpentine belt system vs V-Belt [Re: Gruvin]
Kailua, Hawaii
i can't get the pictures so i don't know what wires i still need.
#784858 - 04/14/10 10:22 AM Re: serpentine belt system vs V-Belt [Re: blackpearl7051]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
#784917 - 04/14/10 05:58 PM Re: serpentine belt system vs V-Belt [Re: BuzzLOL]
I also swapped to the GMPP serpentine kit. Mine came with the 100 amp alternator.
Splicing in the alternator pigtail reached without a problem, the A/C also reaches with some re-routing of wires. I have not connected the A/C yet, so no suggests on a pigtail.
Here is another source, although I believe the other link has this same info:
http://paceperformance.com/index.asp?PageAction=Custom&ID=650
The 'S' is the fat wire on the pigtail, looping around to the (+) terminal, just like the stock pigtail did.
#784935 - 04/14/10 06:59 PM Re: serpentine belt system vs V-Belt [Re: 84 ZZ4]
Gruvin Offline
Gruvin  Offline
Texas
good info, just remember that the 50 ohm resistor needs to be of equivalent amperage to a light bulb in the dash(3-5amp) - a dinky 1/4 amp resistor is not correct for this application
#784947 - 04/14/10 07:26 PM Re: serpentine belt system vs V-Belt [Re: Gruvin]
WaSSted Offline
WaSSted  Offline
Kennewick
Not trying to jack this thread but I have a question. I noticed that the GM bracket 10118722 required to adapt the CS-144 to the F-Body serpentine bracket is discontinued. I still have not swapped to serpentine, but I would like to. So correct me if I am wrong, but since that part is discontinued I believe my best bet is to find a b-body doner car. Right?
Kirk Herres
#785071 - 04/15/10 02:06 AM Re: serpentine belt system vs V-Belt [Re: WaSSted]
Kailua, Hawaii
so what do i do with flp wires? i don't think i just have an idiot light i have the gauge
#785143 - 04/15/10 12:15 PM Re: serpentine belt system vs V-Belt [Re: blackpearl7051]
Gruvin Offline
Gruvin  Offline
Texas
depin them or cut them off... you need to run a resistor with the gauge like the drawing shows of buy the adapter with the resistor built in( its like 20.00 plus shipping)
#785804 - 04/17/10 05:55 PM Re: serpentine belt system vs V-Belt [Re: Gruvin]
Kailua, Hawaii
okay i see the pictures now. so where does that ground hook up to on the back of the alt?
#787066 - 04/22/10 02:10 AM Re: serpentine belt system vs V-Belt [Re: blackpearl7051]
Kailua, Hawaii
okay so the s wire goes to the post on the back and the wire from the battery goes gets grounded out at the bracket then what charges the battery?
#787075 - 04/22/10 02:36 AM Re: serpentine belt system vs V-Belt [Re: blackpearl7051]
Gruvin Offline
Gruvin  Offline
Texas
you extend the red wire that comes from the battery to the stock alt to the new alt location, it and the S wire both bolt to the stud on the back, just ground the black battery wire to the bracket on the pass side... I had to egg out the hole on the end of the ground wire so one of the bolts that held the AC compressor would go thru the hole (IIRC)
#803109 - 06/17/10 02:19 AM Re: serpentine belt system vs V-Belt [Re: blackpearl7051]
galeaiii Offline
galeaiii  Offline
New Richmond, Ohio
Ok, what donor car has been used for AC hoses, or do I get custom made ones? I'm lost, its starting to get a little warm out and my pregnant wife refuses to get in my car. Is that good or bad?
86' SS, 383, Extreme Automatics 200-4R, Hotchkis TVS, 8.5 rear w/3.73 posi
#803229 - 06/17/10 06:18 PM Re: serpentine belt system vs V-Belt [Re: galeaiii]
Gruvin Offline
Gruvin  Offline
Texas
later 3rd gen V8 F-body cars will have the hoses you need, there are also some either buick or olds cars that will also have the correct hoses...
Custom made hoses are not that bad, I think the kit for the hoses is like 90.00 plus getting the connections crimped at a hydrolic shop
#803422 - 06/18/10 02:57 PM Re: serpentine belt system vs V-Belt [Re: Gruvin]
87ChooChoo Offline
87ChooChoo  Offline
las Vegas, NV
F-body hoses will work great, but only if you changed out your condensor to an F-body one as well. Also, use an F-body accumulator for a perfect fit. I found my hoses new on Ebay.
500/thumbs/IMG_1088.jpg
by Frazier85
500/thumbs/mymonte2.jpg
by 85PrimeredMCSS
500/thumbs/Photo0186.jpg
by benen
500/thumbs/Glen.jpg
by PontiCarlo468
500/thumbs/DSC01986.JPG
by msh1987
