#767077 - 02/19/10 02:44 PM lifter tap 305?
javi05 Offline
javi05  Offline
houston, tx
i have a 305 in my 79.. runs good, no bucking, or back firing, when the engine comes down to idle i can here maybe one lifter tapping on the pass side rear.. i havent adjusted it yet-- dead batt. lol.. i think since the engine runs so good and no back firing it just needs a lil tighting. has anyone had this problem and by adjusting the rocker fixed the prob. or do yall think the lifter is just bad? thanks
http://www.youtube.com/watch?v=kEMXAg9hlNE&feature=related
7th monte- 79 burgandy t-tops 305 4bbl. current project. (coolest one)
#767080 - 02/19/10 02:51 PM Re: lifter tap 305? [Re: javi05]
MC 502 Offline
MC 502  Offline
Wilmington,De
Sounds like it just needs a little valve adjustment.
1987 SS/502
#767089 - 02/19/10 03:22 PM Re: lifter tap 305? [Re: MC 502]
supernova455 Offline
tampa, fl usa
If it's valve adjustment, then somthing is wrong, because they should not need periodic adjustment (hyd lifters), make sure your not hearing an exhaust leak.
How is the oil pressure? Can you see oil moving on the floor of the cyl. head when it is running and you remove the filler cap? You should see a flowing river there when it is warmed up.
How many miles are on the engine? If it is indeed a lifter that has lost pre-load, you will need to figure out why that has happend.
Supernova455
#767093 - 02/19/10 03:34 PM Re: lifter tap 305? [Re: supernova455]
MC 502 Offline
MC 502  Offline
Wilmington,De
Thats not always true. They do need adjusting as the lifter spring wears.They require lash to be put on them as the oil will only make up so much space,that is why they require an inital setting of 1/2 -3/4 turn of prelaod when new.
1987 SS/502
#767094 - 02/19/10 03:34 PM Re: lifter tap 305? [Re: supernova455]
javi05 Offline
javi05  Offline
houston, tx
well the previous owner said the car sat for some 10+ years.. maybe a dry start or something caused this. idk.. i do see oil everywhere.. i havent started the car with valve covers off yet. i have the covers off now and the valves look "pretty clean" for a 79.. and yes its a lifter or valve making the noise. (broomstick) trick. lol.. but it idles so good and under load no bacj firing..
#767134 - 02/19/10 05:15 PM Re: lifter tap 305? [Re: javi05]
jigsaw Offline
jigsaw  Offline
Laredo TX
get one of those stethoscopes to make sure its a lifter, had the same thing happen and the noise would go away when adjusting the lifter and made me believe it was a bad lifter so i changed it out and noise was still there, turned out to be an exhaust leak due to the header bolts loosening blush
#767694 - 02/21/10 10:40 AM Re: lifter tap 305? [Re: jigsaw]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. I would drive it till it's warmed up good and hot and then let it cool enough to change the oil and filter... and then drive it for a month or so and see if it frees up and goes away on it's own... after getting a good warm up several times... and engine heat driving the moisture and condensation out of the engine and melting the sludge...
.. If not, then adjust it...
.. If after adjusting it, it soon starts ticking again after a few days, then prolly either you need a new lifter and/or the cam lobe is going bad ("wiping out") and you need a new cam and lifters...
.. The bottom of the lifter should appear flat... actually slightly bowed out, but that is hard to see... if the bottom of the lifter is dished in, then the cam/cam lobe is also damaged... you could put a new lifter in and get some more use out of the car, but you really need a new cam and lifters as soon as practical...
.. A Summit mild performance cam and lifters may cost less or the same as a stock cam and lifters from GM...
#767719 - 02/21/10 03:38 PM Re: lifter tap 305? [Re: BuzzLOL]
My guess is you have a flat cam. GM had a lot of trouble with soft metal in camshafts from that era.
#768001 - 02/22/10 02:13 PM Re: lifter tap 305? [Re: upflying]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. LOL! Over the past 50 years I've heard that comment about every era... so I'm thinking mosttimes you get a good cam... sometimes you don't... of course, the advent of all new cars having roller cams and the removal of high pressure lubricants for flat tappet cams from modern engine oils has caused a whole new set of concerns... plus, if an engine ever runs low on oil, is overrevved extensively, has too weak valve springs, has other parts of the engine disintegrate into the oil, or is abused before it comes up to proper operating temperature, that can also damage cams... another problem is some aftermarket performance cam companies were selling imported cams and lifters made of inferior materials for a while... I hope that has stopped...
#768005 - 02/22/10 02:22 PM Re: lifter tap 305? [Re: BuzzLOL]
javi05 Offline
javi05  Offline
houston, tx
thanks guys.. gonna try and adjust it and see. engine runs very smooth almost seems likes it not even running if it wasnt for the tapping sound. i am gonna try and make this 305 run until she cant no more.. then im thinking a 454.. but very later on..
#768321 - 02/23/10 02:30 PM Re: lifter tap 305? [Re: javi05]
BuzzLOL Offline
BuzzLOL  Offline
Toledo, Ohio
.. Check that the distributor cap is fully down and seated properly and the hold down 'screws' are in the proper lock down position... I've seen that make a rotor tapping sound...
.. Maybe you'll luck out and the rocker arm nut just came loose a little bit... hope so...
#769202 - 02/26/10 12:16 AM Re: lifter tap 305? [Re: BuzzLOL]
javi05 Offline
javi05  Offline
houston, tx
well finally got it started. starting adjusting the rockers and it purrrrrrs like a kitten. no more lifter tap. lol.. still hear exhaust leaks.. drove it around i am suprized its runs so smooth. it smokes a lil but a good oil change and some good gas should help that. now time to sand this thang down.. thanks
#769210 - 02/26/10 12:38 AM Re: lifter tap 305? [Re: javi05]
BigTony Offline
BigTony  Offline
Ftmyers Florida
Really? adjusting the rockers can quiet up a lifter tap!?I installed a new cam and lifters in my car, broke it in,then had the valve adjustment done,the next day i hear a very subtle tapping,thats for sure not the rockers.What did you do?tighten them up a bit or loosen them.
#769233 - 02/26/10 01:54 AM Re: lifter tap 305? [Re: BigTony]
javi05 Offline
javi05  Offline
houston, tx
first i found the ones making the noise and just a lil turn on a couple and it stopped. not sure if the tap is gonna come back or not. but its quite for now.
#769247 - 02/26/10 02:38 AM Re: lifter tap 305? [Re: javi05]
AndreB Offline
AndreB  Offline
Milwaukee, Wi
this is how it was done on my car, kinda messy. i was told later they make something to block the oil. But you can clearly hear the difference in the noise the tapping makes when u adjust it.
dreday1062000@yahoo.com
#769344 - 02/26/10 01:32 PM Re: lifter tap 305? [Re: AndreB]
javi05 Offline
javi05  Offline
houston, tx
^^^ cool vid. i did mine just like that..
852/thumbs/1981_mont_carlo.jpg
by PoorBoysRacing
500/thumbs/Monte2_mid.JPG
by woolf
500/thumbs/06-08-07_1245.jpg
by ETHIOSLS
500/thumbs/parts2.jpg
by go3and8
500/thumbs/RR.jpg
by Greg Talbott
