#667016 - 04/02/09 01:12 AM 1999 Buick 3.8 supercharged swap?
Aceprowler Offline
Aceprowler  Offline
Erie, Pa
Is this possible to do with rear wheel drive 84 monte?
I have a chance to pick up a low milage 3.8 out of a 99 bonneville for $600 with original Eaton S.Charger. The motor has 240hp/280tq
I did a search on the net and found really nothing concrete. Figured someone here would know.
1984 Monte Carlo SS - "010" 4bolt 350, GN 8.5, 700R4, 3.42
#667020 - 04/02/09 01:14 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Aceprowler]
I dont think it will work being as how the engine sits in the buick, probably be hard to get it to bolt up to a 2004r or any other tranny in your car, but im not 100% either
#667024 - 04/02/09 01:20 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Aceprowler]
Brian Mc Offline
Brian Mc  Offline
Stuck in Traffic
It could be done but it's more fitting to an older FWD car. The monte can make easy use of an LS1,2,3,6,or 7. I have swapped a 99 Bonneville SSEi 'train into my 88 Lesabre T-Type, it's bolt-in. It's much more at home in a car like this, where you're sort of stuck with FWD.
It would be used with a trans from either a v6 camaro/firebird or s-10 p/u.
You'd use manifolds(or headers) from an F-body as well.
1984 SS, 24X Homebuilt EFI TPiS/AFR head 355, 5 speed Tremec TR3550, 13" C5 front, 12" LS1 rear brakes, Hotchkis springs/control arms, 17" ROH Snyper wheels, 8.5 Posi
1995 Camaro Z28 6 speed--------1988 Corvette Coupe--------1988 Lesabre T-Type Series II Supercharged--------1990 MX-5 Miata(beater)
#667027 - 04/02/09 01:24 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Aceprowler]
mikeasis Offline
mikeasis  Offline
faimont, wv
every since the supercharged bonneville came out ive dreamt of sneaking the drive train under a feiro GT....its been done now but i still say it was my idea grin
that little sucker would haul the mail!
#667050 - 04/02/09 02:15 AM Re: 1999 Buick 3.8 supercharged swap? [Re: mikeasis]
devildog214 Offline
devildog214  Offline
sewell, NJ
Hell yeah i saw one with a northstar swap, just have to remember with northstars to seal that block before swap, those leak oil like no tomorrow
white 87 SS, G80 7.5 with 3.73s. vortec 350 flowmasters, performer RPM mani, comp HE268 edelbrock TES. UMI fixed upper and boxed lower rear control arms (non adj). UMI swaybars.
#667073 - 04/02/09 03:52 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Aceprowler]
86SS86LS Offline
86SS86LS  Offline
Eastern SD
There was a guy who swapped a 3.8 supercharged motor into a 80's cutlass. He detailed his build on a website, you should be able to google it.
You can mate a 4l60e from a v6 camaro to the FWD 3.8. The air intake will face directly into the firewall - this will likely require som modification. And I'm not sure how easy it is to get the computer and harness to function in stand alone mode.
This would an interesting project, I've thought about it many times myself.
#667075 - 04/02/09 03:57 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Brian Mc]
86SS86LS Offline
86SS86LS  Offline
Eastern SD
That 3.8 S/C looks right at home in the LeSabre. Very fitting that it is a T-type with a forced induction motor.
How much work was involved with the swap?
#667085 - 04/02/09 05:03 AM Re: 1999 Buick 3.8 supercharged swap? [Re: 86SS86LS]
one clean T-type, i always liked the looks of the leSabre over the Gn's
#667091 - 04/02/09 05:20 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Travis Jones]
Aceprowler Offline
Aceprowler  Offline
Erie, Pa
Love to do an LS1, but when I could grab and 240hp v6 for $600 I had to see if it was possible. Wishfull thinking I guess. smile
Thanks guys!
#667177 - 04/02/09 03:01 PM Re: 1999 Buick 3.8 supercharged swap? [Re: Aceprowler]
But I think it will cost you alot more money to install that FWD V6 into your MC vs a RWD LSX swap.
#667231 - 04/02/09 06:21 PM Re: 1999 Buick 3.8 supercharged swap? [Re: Buick Runner]
88ss408 Offline
88ss408  Offline
miramichi, NB
it can be done with alot of fbody parts as they all use the same block. there is a guy on the gbody forum that did it he should not be hard to find.
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#667232 - 04/02/09 06:31 PM Re: 1999 Buick 3.8 supercharged swap? [Re: 88ss408]
Antler Offline
Antler  Offline
NFLD
It can be done. I've seen guys take LS1's and put them in Late model Grand Prix's and still retain stock tranny and Front Wheel Drive, so putting the Grand Prix or Bonneville engine into the monte should be a big deal, just take your time, and do lots of research.
"You win some, you lose some, you wreck some" -Dale Earnhardt Sr.
#667239 - 04/02/09 07:05 PM Re: 1999 Buick 3.8 supercharged swap? [Re: Antler]
88ss408 Offline
88ss408  Offline
miramichi, NB
http://www.tripleedgeperformance.com/New_Home_Page.php
talk to this guy he's the one who did the swap.
he posted about it in a couple of forums too but cant dig them up right now
#667270 - 04/02/09 08:37 PM Re: 1999 Buick 3.8 supercharged swap? [Re: 88ss408]
Chevrolord Offline
Chevrolord  Offline
West Virginia
Can the supercharged 3.8 be de-tuned to run on regular gas?
I know a guy that is putting one in a T-Bucket.
Always thought it would be wicked in something like a Vega, 64 Chevy II, or even a Pinto SS.
Saw a 3.8 on a rail buggy. They grafted the engine cradle onto the rear of the rail buggy chassis.
#667384 - 04/03/09 12:41 AM Re: 1999 Buick 3.8 supercharged swap? [Re: Chevrolord]
blubaldmontess Offline
Clarksville, TN
You can get the engine, and run it with your trans or a newer trans, and you can get the 5.3 (I believe rated at 300hp or something close to that0 Ok sorry found it on wikipedia, 285-295 hp and 325 tq. They are the Gen III engines out of the 99 and up pickup trucks. They can be found, engine alone, for less than 1k, or with trans for somewhere around 1400, or less if you check around the internet. If you really want to know a list of parts and the costs, let me know, and I'll sit down and write them up to show the total price.
#667568 - 04/03/09 01:36 PM Re: 1999 Buick 3.8 supercharged swap? [Re: Chevrolord]
Brian Mc Offline
Brian Mc  Offline
Stuck in Traffic
You can run a Series 2 motor on 87 w/o any problems, the timing retard system is sophisticated enough to handle it, as long as it doesn't have a smaller blower pulley.
#667991 - 04/04/09 04:58 PM Re: 1999 Buick 3.8 supercharged swap? [Re: Buick Runner]
Vern Offline
Vern  Offline
Dayton, OH
There is a guy who detailed this swap on gbodyforum. In fact he fabbed some parts and will do this swap for others. I remember he was from Indiana and that he turned up the wick. The thing was very fast as in low 11s and got mid to high 20s for mileage. Come to think of it by trade he does transmissions and has a website and there was a seperate page on his website about this. Sorry can't remember more than that.
87 Grand National Buick 3.8, TE-60 turbo, Stretch Intrcoolr, 42.5 injectors, 3000 stall lockup converter, Meth/water injection, 22mpg
87 OLDS 442 509ci Cadillac, Street portd heads, 230@50 528 lift cam, Headrs, Billet drum 200-4R, 2800 stall lockup convertr, Electric fans/intank fuel pump, 17mpg hwy, Both 2 run 11.8ish 113+ on pumpgas
508/thumbs/291978_73_full.jpg
by 85_SS
500/thumbs/54.JPG
by Mark's SS
500/thumbs/M51.jpg
by devider440
500/thumbs/moto_0061.jpg
by dw329
500/thumbs/IMG_0009.JPG
by andiegal
