#653550 - 02/26/09 10:42 PM Charcoal canister
kingkreeton Offline
kingkreeton  Offline
Wilmington, NC
I have an emissions delete car and was wondering if I still need to have the charcoal canister and associated hoses for my car to run correctly?
Custom 85 Regal w/ L69 and 200-4R. Smog delete !!!
#653561 - 02/26/09 11:14 PM Re: Charcoal canister [Re: kingkreeton]
Dalt10 Online grandpa
Dalt10  Online Grandpa
Orlando,FL
My 84 SS had all of the emissions off the car but kept the canister. I could smell gas all of the time because it was clogged up. I put a new one in and it was fine after that.
#653601 - 02/27/09 01:13 AM Re: Charcoal canister [Re: Dalt10]
supernova455 Offline
tampa, fl usa
Keep the cannister, you will be doing yourself good, and every one else too for that matter. If you remove it and vent the float bowl to the atmosphere, you will end up smelling fuel vapors often.
Supernova455
#653709 - 02/27/09 05:41 AM Re: Charcoal canister [Re: supernova455]
06mcss Offline
06mcss  Offline
Killeen, TX
where can you get the charcoal canister? at advance or autozone?...tia..Bill
#653711 - 02/27/09 06:07 AM Re: Charcoal canister [Re: 06mcss]
Bad Co Offline
Bad Co  Offline
Earth
I think you can get them at autozone. Most places have them listed as "vapor canister".
#653721 - 02/27/09 07:27 AM Re: Charcoal canister [Re: Bad Co]
They are a good thing to have, why vent gas vapors that you paid for when you can use them.
#653770 - 02/27/09 02:37 PM Re: Charcoal canister [Re: Buick Runner]
cwest01 Offline
cwest01  Offline
Livonia, Mi
How does the canister get plumbed if everything else is missing? Without the appropriate vacuum lines and valve, how does it work?
#653807 - 02/27/09 05:18 PM Re: Charcoal canister [Re: cwest01]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
Here is an older post:
http://www.montecarloss.com/community/ub...4058#Post614058
I have heard of people getting a tank vent cap, venting with a filter just above the tank, venting at the charcoal canister, and plumbing to the carb without the ECM (older style?). I am not sure how to plumb to the carb without the ECM.
It would be helpful if someone has an older system that is not controlled by the ECM and could comment on that setup.
Larry
#653812 - 02/27/09 05:40 PM Re: Charcoal canister [Re: MattsMonte]
Only 87 and up MCs have a ECM controlled canister, pre 87s the ECM does not control the canister but they use a TVS to keep it off untill the engine is warm.
#653886 - 02/27/09 09:08 PM Re: Charcoal canister [Re: Buick Runner]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
Can you describe the TVS system in detail? Does anyone have a schematic of it?
#653983 - 02/28/09 03:23 AM Re: Charcoal canister [Re: MattsMonte]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
perhaps a different question. Is the TVS system essentially the same as the ECM system, except that the thermal switch replaces the ECM switch? If so, I would expect the amount of tubes and entanglements to be similar to those on the '87 and '88...True?
#653996 - 02/28/09 04:29 AM Re: Charcoal canister [Re: MattsMonte]
Instead of a purge solenoid there is a TVS but the hose routing is different.
1986 MCSS
1987 MCSS
#654000 - 02/28/09 04:42 AM Re: Charcoal canister [Re: Buick Runner]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
Thanks Will,
You are the man in the know about the pollution control stuff.
Essentially, it looks about as complicated as the 87/88 set-up.
Did the TVS hook into a radiator hose or the block somehow?
#654193 - 02/28/09 08:19 PM Re: Charcoal canister [Re: MattsMonte]
The TVS screws into the the intake manifold on the water passage. The 87 setup seems to use a lot more check valves than the pre 87s.
#654206 - 02/28/09 08:49 PM Re: Charcoal canister [Re: Buick Runner]
JMO Offline
JMO  Offline
Mechanicville, Virginia
i took mine off i got rid of all the emissions stuff. i dropped a 350 in it.
84' SS,350,700r4 w/ shift kit, mild cam, l/t headers, true duals to 40's
Sweetness!
#654230 - 02/28/09 10:08 PM Re: Charcoal canister [Re: JMO]
tampa, fl usa
Buickrunner,
Check out the diagram I made many years ago, I copied my badly worn one from my car, I used the "PAINT" program found on my computer. I printed it out on sticky back paper and put it on my fan shroud. The only thing I don't have on it is the bar code.
If any one want's it, save it, and print in landscape, it's very close to the origanal in size, enjoy!
Supernova455
#654303 - 03/01/09 01:26 AM Re: Charcoal canister [Re: supernova455]
kingkreeton Offline
kingkreeton  Offline
Wilmington, NC
Very cool, great idea.
#654380 - 03/01/09 04:10 AM Re: Charcoal canister [Re: kingkreeton]
Thanks supernova.
#654387 - 03/01/09 04:24 AM Re: Charcoal canister [Re: supernova455]
juangomez22 Offline
juangomez22  Offline
houston tx
Originally Posted By: supernova455
Buickrunner,
Supernova455
thanks supernova455, this will help down the road
#654439 - 03/01/09 12:43 PM Re: Charcoal canister [Re: juangomez22]
tampa, fl usa
Thank You all,
lets all have clean running cars out there, clean does not mean slow!
Supernova455
#654461 - 03/01/09 03:02 PM Re: Charcoal canister [Re: supernova455]
Sixtoes1313 Offline
Sixtoes1313  Offline
Abingdon, Maryland
For my LS1 swap I plan on running a vented cap and breather above the tank. Thats what a few of the malibu guys have done. Dont know if you'll still smell vapors though
LsX: DO IT~ 11.32 @120mph
#654495 - 03/01/09 03:57 PM Re: Charcoal canister [Re: Sixtoes1313]
kevins88ss Offline
kevins88ss  Offline
Southern Maine
FWIW, on mine I ran the vent hose to a cone-type valve cover filter and ran it into the left front fender area. I can't smell any fumes at all.
500/thumbs/20121008_160846.jpg
by ray396
500/thumbs/The_Kids14.jpg
546/thumbs/MVC-015S_1.JPG
by 86AeroDave
500/thumbs/IMG_0009.JPG
by andiegal
1098/thumbs/VETTE_RALLY_2.JPG
by ham
