#637529 - 01/12/09 04:41 AM manual trans floor boot?
whatare you guys using for a boot to cover the hole cut for the shifter? also what about shifter boots for the actual shifter and stock center console?
#637530 - 01/12/09 04:46 AM Re: manual trans floor boot? [Re: Onebadbowtie86]
Monte_ExpreSS Offline
Oshawa, Ont. Canada
Bill, zz430t56 was making & selling some nice looking shifter boots that fit in the stock shifter plate just for the manual swap a little while back. Might want to contact him.
#637531 - 01/12/09 04:48 AM Re: manual trans floor boot? [Re: Monte_ExpreSS]
ya, ive seen his, and its nice, its an option, but i would like to do a c5 boot like tpi montess's
#637533 - 01/12/09 04:51 AM Re: manual trans floor boot? [Re: Onebadbowtie86]
Oshawa, Ont. Canada
Can't help you there, but is this the one you're referring to?
#637534 - 01/12/09 04:54 AM Re: manual trans floor boot? [Re: Monte_ExpreSS]
YES, can i have it?
#637540 - 01/12/09 05:00 AM Re: manual trans floor boot? [Re: Onebadbowtie86]
whos is that one? it looks like what i want...
#637570 - 01/12/09 12:31 PM Re: manual trans floor boot? [Re: Onebadbowtie86]
That's Steve's boot - should be able to pick one up on ebay. As for the floor boot - guys have used both 3rd gen and 4th gen F-body parts.
#637667 - 01/12/09 08:03 PM Re: manual trans floor boot? [Re: 85_SS]
Brian Mc Offline
Brian Mc  Offline
Stuck in Traffic
It's hard to see from this pic but it's a 91 Trans am boot, 98 Cobra Knob and 93-02 F body floor boot.
1984 SS, 24X Homebuilt EFI TPiS/AFR head 355, 5 speed Tremec TR3550, 13" C5 front, 12" LS1 rear brakes, Hotchkis springs/control arms, 17" ROH Snyper wheels, 8.5 Posi
1995 Camaro Z28 6 speed--------1988 Corvette Coupe--------1988 Lesabre T-Type Series II Supercharged--------1990 MX-5 Miata(beater)
#637669 - 01/12/09 08:06 PM Re: manual trans floor boot? [Re: 85_SS]
Most of us use two boots, the lower seals the shifter to the floor sheetmetal and the upper is for appearance to finish off the hole cut in the console. Lower used is the 93-02 F body boot #10267518 which has a nice area to attach it to the floor. Just don't make the hole in the floor to big, seal it with RTV when you screw it fast. I'm using the C5 upper leather boot, which I think Steve may also be using, #10326158. PM me if you want pics.
#637713 - 01/12/09 09:55 PM Re: manual trans floor boot? [Re: mmc427ss]
juangomez22 Offline
juangomez22  Offline
houston tx
mmc427ss could you send me some pictures to my email or pm thank you ... is anyone else using diffrent part numbers from what mmc427ss posted or is everyone using the same part numbers?
#637728 - 01/12/09 10:48 PM Re: manual trans floor boot? [Re: juangomez22]
My lower boot is GM #140694408. Both will work fine - there is a metal ring inside of it that you can bend/mold to perfectly fit the floor.
I preferred the old school look with the sunken-in boot and visible shifter arm, so I went with the upper boot Bill was selling.
#637750 - 01/12/09 11:49 PM Re: manual trans floor boot? [Re: Onebadbowtie86]
Clutch_Grabwell Offline
Millbury, MA
Best pic I could come up with quickly. Please ignore the mirror switch...
This is a generic one-size-fits-all boot trimmed around a home made ring on the inside attaching it to the plate.
1986 MCSS, T-tops, TPI 350, T56, 8.5" 3.42:1 Posi, cruise, A/C, ZQ8 brakes
All power: Windows, locks, mirrors, 8-way GTO seats
Concert Sound II, seven speakers, two amps
As seen in Hemmings Muscle Machines Aug. 2010
http://www.hemmings.com/mus/stories/2010/08/01/hmn_feature6.html
#637763 - 01/13/09 12:16 AM Re: manual trans floor boot? [Re: juangomez22]
Just sent Jason some info and pics, I'll send you some later this evening.
#637880 - 01/13/09 05:16 AM Re: manual trans floor boot? [Re: mmc427ss]
Minotaur15 Offline
Minotaur15  Offline
Manahawkin NJ
Clutch,
Can you explain how you attached the boot to the ring and the ring to the console? Screwed from bottom?
Dan - minotaur15@hotmail.com
Used to have: '86 MMC Road Course Ready
2020 Kia Forte GT Manual - Daily Driver
#637883 - 01/13/09 05:20 AM Re: manual trans floor boot? [Re: Minotaur15]
Same here clutch, incase icant get ahold of a c5 boot...
#637935 - 01/13/09 01:29 PM Re: manual trans floor boot? [Re: Onebadbowtie86]
I'm using a universial Lokar boot. I like it.
#638037 - 01/13/09 09:11 PM Re: manual trans floor boot? [Re: SickSpeedMonte]
Courage68 Offline
Courage68  Offline
Northern, NJ
heres what i did
Tom.D
81 MC /w WC T-5 Conversion & 5.7L
#638165 - 01/14/09 03:18 AM Re: manual trans floor boot? [Re: Minotaur15]
Millbury, MA
Originally Posted By: Minotaur15
Clutch,
Actually, it's screwed from the top. With the holes pre-drilled, I went through the stick opening and secured it after stretching the leather around the ring.
#638211 - 01/14/09 06:41 AM Re: manual trans floor boot? [Re: mmc427ss]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
That is the lower boot I used, it is nice and big and you can form it to the shape of the floor. Mine says 6-Speed right on the top!
Right now that is the only one I am using but I am going to put the console back in so I will go with a leather one like my BMW has.
#638223 - 01/14/09 07:53 AM Re: manual trans floor boot? [Re: Phil87SS]
Minotaur15 Offline
Minotaur15  Offline
Manahawkin NJ
Clutch,
Ahh, looks like thats what I need to do after I fab up a ring. The s10 console has an asymetrical opening so I have to do some putzing around with it.
#640610 - 01/21/09 08:35 PM Re: manual trans floor boot? [Re: Minotaur15]
ordered the boots from the dealer today. the lower boot im getting for $35 and the c5 shifter boot im getting for $60. i know a guy at the dealer and he told me that these were "dealler cost". they sound pretty fair, but are they?
#640634 - 01/21/09 09:28 PM Re: manual trans floor boot? [Re: Onebadbowtie86]
What PN's did you use Jason? My parts guy told me these were discontinued IIRC:
1983-1985 F body lower  GM 140694408
C5 Corvette upper GM 10326158 (10340226)
#640662 - 01/21/09 10:40 PM Re: manual trans floor boot? [Re: 85_SS]
thats the number i gave my parts guy on the c5 shift boot, but i think he said the number might have changed or something, he prety much lost me after he said he can get me one. for the lower shift boot i used the number 10267518 and he said he can order it for like 30-35 bucks. hope this helps. the lower floor boot is for an actual 6 speed f body.
#640663 - 01/21/09 10:41 PM Re: manual trans floor boot? [Re: Onebadbowtie86]
the c5 shift boot comes with the plastic ring attatched right?
#640665 - 01/21/09 10:49 PM Re: manual trans floor boot? [Re: Onebadbowtie86]
Thanks Jason - I had "1993-2002 F body lower GM 10267518" on my list, but don't think I inquired about that one (either than and I did but the price was insane or something). Next time I have things apart I may pick one up as the used one I found wasn't in as good of shape as I'd like.
I'm not sure, but I believe the plastic ring is part of the boot IIRC.
737/thumbs/small_DSC00316.jpg
by McNamee
500/thumbs/MCSS4.jpg
by Wrathchild
500/thumbs/SD530544.JPG
by pearl83SS
500/thumbs/87_Monte2.jpg
by mightymonte10
500/thumbs/Photo_4.JPG
by Chief Jimbo
