#634274 - 12/31/08 01:00 PM too much cam or not enough..
SS402 Offline
SS402  Offline
Beaverton, Oregon
a simple way to tell if your camshaft is too big or too small for the installed CR is to use a compression gauge and measure cylinder pressure. if the pressure is low around 140psi then the cam is too big, if the pressure is too high around 200psi then the cam is too small...hth
George
Monte, Gone but not forgotten
The More I Learn About Dogs
The Less I Like About People
#634277 - 12/31/08 01:07 PM Re: too much cam or not enough.. [Re: SS402]
black95jimmy Offline
Waterford, MI
http://www.hcs.harvard.edu/~jus/0303/kuo.pdf
Pretty much explains it all. pullhair
82 SC, Light and Dark Redwood Metallic. 355, Vortec Heads, Roller Rockers, Pypes True Duals, 670 Street Avenger. SS Steering and Sway Bars. Enkie Wheels. Jeep Intermediate Shaft, ZQ8 Bump Stops.
#634296 - 12/31/08 02:45 PM Re: too much cam or not enough.. [Re: SS402]
onovakind67 Offline
onovakind67  Offline
Fairfield, CA
Is the cam the wrong size or are you just closing the intake valve at the wrong time?
#634304 - 12/31/08 03:13 PM Re: too much cam or not enough.. [Re: onovakind67]
juangomez22 Offline
juangomez22  Offline
houston tx
intresting thread
#634328 - 12/31/08 04:34 PM Re: too much cam or not enough.. [Re: juangomez22]
So is it good my compresion tester reads 185 psi George?
#634334 - 12/31/08 04:36 PM Re: too much cam or not enough.. [Re: Onebadbowtie86]
SS402 Offline
SS402  Offline
Beaverton, Oregon
excellent..
George
#634335 - 12/31/08 04:38 PM Re: too much cam or not enough.. [Re: SS402]
wink
#634336 - 12/31/08 04:39 PM Re: too much cam or not enough.. [Re: onovakind67]
SS402 Offline
SS402  Offline
Beaverton, Oregon
Originally Posted By: onovakind67
[quote=SS402]Is the cam the wrong size or are you just closing the intake valve at the wrong time?
I should've been more specific, what i'm referring to is the duration..
George
#634337 - 12/31/08 04:39 PM Re: too much cam or not enough.. [Re: Onebadbowtie86]
so if i went a little bigger in the cam department, like one size up in the voodoo from where im at now, would that help my detonation problem? or would my cylinder pressures be to low then?
#634347 - 12/31/08 05:07 PM Re: too much cam or not enough.. [Re: Onebadbowtie86]
jigsaw Offline
jigsaw  Offline
Laredo TX
how much psi does urs have george
#634453 - 12/31/08 09:55 PM Re: too much cam or not enough.. [Re: jigsaw]
SS402 Offline
SS402  Offline
Beaverton, Oregon
haven't thrown a gauge on it yet but i'm betting close to 195+psi..
George
#634463 - 12/31/08 10:29 PM Re: too much cam or not enough.. [Re: jigsaw]
4-speeds Offline
4-speeds  Offline
surrey, b.c.
you can go a step up i'd think.
диđяΣш
#634629 - 01/01/09 02:53 PM Re: too much cam or not enough.. [Re: Onebadbowtie86]
SS402 Offline
SS402  Offline
Beaverton, Oregon
the key is to keep the cylinder pressure up w/o detonation, other than making sure the timing curve is dialed in like we discussed earlier it comes down to the quench area, chances are your engine has more than .060" piston/head clearance and is more susceptible to detonation because of the excessive quench.. sure we could add more duration which would lower the cylinder pressures aka dynamic CR aka running compression.. everythings a compromise when the engine is not properly designed and built.. so the end result of adding a larger cam in your case is decreased performance, but before we change the cam let's do everything we can to minimize the detonation with your current combination, an excellent article discussing these techniques is outlined here: http://popularhotrodding.automotive.com/45359/0605phr-pump-gas-secrets/index.html
George
651/thumbs/C6.JPG
by 84supersport
994/thumbs/KC1210-100906_7.jpg
by Elipopotao
500/thumbs/Lomogram_2014-08-27_12-05-28-PM.jpg
by MCSSLife
671/thumbs/start_001.jpg
by woodss
500/thumbs/At_Earnhardt_Chevrolet.jpg
by Scott_86SS
