#626089 - 11/28/08 01:38 PM Wax in the crax?
kpetry Offline
kpetry  Offline
Bloomington, Indiana
What's the best way to remove wax and/or rubbing compound buildup from between your body panels without scratching? Anybody got a solution more trick than a toothpick and a rag?
Bought my Monte new in '87, 220,000 miles ago. Now undergoing a complete restoration with a mild LT1 and T56 6 speed.
#626097 - 11/28/08 02:16 PM Re: Wax in the crax? [Re: kpetry]
Glenn Tjapkes Offline
Grand Rapids, MI
For really tough spots that involve painted surfaces, I highly recommend an Automotive Claybar. It can be formed to the contours of trim and edges. The only risk is if you allow the surface of the clay to collect too much debris and dirt. You must check it regularly and fold the clay into itself to get a new, clean, working surface on the clay. I would do the entire vehicle though, if you haven't done it before. You'd be surprised what it'll pick up and amazed at the smooth finish it leaves behind. It does, however, remove virtually anything on or in the surface of the clear coat, including the wax, so you must reapply a coat of wax.
#626125 - 11/28/08 04:16 PM Re: Wax in the crax? [Re: Glenn Tjapkes]
Do that with the clay bar, get some painters tape and tape over the cracks, and then wax it again.
#626161 - 11/28/08 08:21 PM Re: Wax in the crax? [Re: SickSpeedMonte]
Pipe cleaner, old toothbrush, a gun cleaning kit or a long, wooden stem Q-tip.
#626222 - 11/28/08 11:27 PM Re: Wax in the crax? [Re: upflying]
85lolo Offline
85lolo  Offline
radiator springs
towel over a wood shim
#626274 - 11/29/08 02:35 AM Re: Wax in the crax? [Re: 85lolo]
monte7852 Offline
monte7852  Offline
Colorado Springs
Paint brush with the metal part taped up, you may have to let the wax dry for a few hours
or if you have the time, wash car again w/ power hose to get the excess out
Craig
2003 Chevy Avalanche Z71
#626329 - 11/29/08 12:52 PM Re: Wax in the crax? [Re: monte7852]
kpetry Offline
kpetry  Offline
Thanks guys! All great ideas!
#626379 - 11/29/08 06:25 PM Re: Wax in the crax? [Re: kpetry]
Soft toothbrush or makeup brush (steal the Girlfriends) and some armor all or WD-40. Either one will take it out fast.
I prefer to spray often to keep the brush from grinding any grit into the paint.
#627006 - 12/01/08 11:01 PM Re: Wax in the crax? [Re: 84 ZZ4]
Jr Mint Offline
Jr Mint  Offline
E. Brunswick ,NJ
I just use a toothbrush
87 Monte, 355 SBC, WP Sportsman II heads, 700 R-4, 2800 stall converter, Custom shift kit, GN 8.5 rear 3.73 Posi, Full Exhaust, Street Avenger 670 and some other goodies.
Feedback: http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=508486#Post508486
#627460 - 12/03/08 11:58 AM Re: Wax in the crax? [Re: Jr Mint]
ThePilot Offline
ThePilot  Offline
Louisville, KY
im a fan of the long handle q-tip for this.
#627751 - 12/04/08 02:03 PM Re: Wax in the crax? [Re: ThePilot]
bradleyls103 Offline
Imlay City, MI
Toothbrush and q-tips work for me
Bradley
#627949 - 12/05/08 11:25 AM Re: Wax in the crax? [Re: ThePilot]
m.smithII Offline
m.smithII  Offline
indianapolis,in
Tooth brush and Simple green
500/thumbs/thmb_mikesss3.jpg
by BadAssSS
981/thumbs/monte01.jpg
by Robs86MCLS
500/thumbs/DSC04211.JPG
by bullet187
571/thumbs/Right_Front.jpg
by wifes'86ss_Mechanic
665/thumbs/breannas_1st_b-day_137.jpg
by MARIO87SS
