#735924 - 10/31/09 02:32 PM
Re: Intermediate shaft upgrade on flea bay
[Re: PB86SS/87LS]
Gruvin
Moderator 15+ Year
Moderator 15+ Year
Texas
At least half of the ones in the yard I came across were the kind with the smaller shaft opening, I would just move along to find one that has the correct opening size for our cars but I suppose grinding it larger can work too. yea, it is nice to know that we could use either of the shafts with some mods...
My first SS! Sold Jan 2004 ![[Linked Image]](http://www.MonteCarloSS.com/images/Gruvin_84SS_sig.jpg) 87 SS bought 9-5-04: Sold 6-18-2010 - project 87 finds a new home with another undisclosed MonteCarloSS.com member!
#735985 - 10/31/09 06:40 PM
[Re: Z65_Paul]
Duts87SS
Spanish Fort, AL USA
Paul, an honest man like you, I'm sure next time you make sure they look it up correctly.  LSJM1, there is quite a bit of difference in the size of the openings; had to remove about 1/2" total from side-side and top-bottom. If you have a vice, grinder/drill, and bits it's no big deal at all. I would have gotten the correct shaft to begin with, but didn't do enough research before I placed my bid on Ebay (advertised as 93-98 Grand Cherokee shaft). I paid ~$30 TTD, and now believe it was completely worth it. The shaft fits nice and snug now, and it's amazing how much different the car is to drive with it.
Dustin 87 SS
#736016 - 10/31/09 08:16 PM
[Re: PB86SS/87LS]
87ChooChoo
las Vegas, NV
Picked one up at the Pick and Pull off a '96 Cherokee. Walked over to the area where the G-body's sit, and found one that had the shaft removed, so I could do a trial fit. $10 was a good deal.
85 El Camino Choo Choo with L31 350 Crate, TPI, Serp, TES Headers, GN 200-4r, 3.73 8.5 GN Posi, Acura Buckets, '04 GP Console, Electric Mirrors, Electronic HVAC, ZQ8 wheels, Blazer front brakes, LS1 rear brakes, and more.... https://sites.google.com/site/darbyselky/home
#737550 - 11/06/09 01:50 PM
[Re: grwhite038]
Stg1Regal
Milton,IN
First off wanted to say thanks to FiveToDrive, for getting one to me.
I wanted to put my input in after the install of one of those Jeep steering shafts and driving with one for a while.
I put one in my 82 Buick Regal, on my YA GN steering box, I also have headers on my Buick 455 thats under the hood.
Awesome, lots of clearance!
Driving? well let me say I took my Regal down to TN back in Sept, to hang with the Guys from PRO-TOURING.COM and their anual "RUN THRU the HILLS" event.
Didn't do in any auto-crossing in it, but did do the TAIL of the Dragon, a 11 mile road with 318 turns, It performed flawlessly, nice n tight , no slop, and more road feel.
I really enjoyed actually driving my car for the first time, down and back, 6 hrs each way, and during the event.
Now I will point out I had to change steering boxes, before the event, my orginal GN box had a dead spot at center that I couldn't adjust out, so a low milage used one went in, thanks to the host of the event, BILL HOWELL from MUSCLERIDES.COM and the use of his awesome garage called the "TOY BOX".
So for those of you still sitting on the fence about it, go ahead and do it.
Later Chris Reed R.I.P >>>>82 Buick Regal w/ 455 Buick Big Block (Lost in my garage fire 1/9/14)
#737886 - 11/07/09 08:40 PM
[Re: LSJM1]
BladeOfAnduril27
Doylestown, PA
I found one of these in the yard last week, and its frozen. I've been spraying it with PB blaster and beating it with a hammer and it's not coming loose. Any suggestions?
~ Matt H.
#737890 - 11/07/09 08:51 PM
[Re: BladeOfAnduril27]
87ChooChoo
las Vegas, NV
I heated the outside of the larger of the two pipe sections with a propane tourch, about 60-90 seconds. That started it sliding, and a little lithium grease finished the job.
HTH
#741693 - 11/19/09 05:32 AM
[Re: Stg1Regal]
fivetodrive
Denver, Colorado
No problem! Sorry I was gone for so long. Life got in the way but I now have a few of these if you guys want them... I found one of these in the yard last week, and its frozen. I've been spraying it with PB blaster and beating it with a hammer and it's not coming loose. Any suggestions? Heat it up with a propane torch like said above then turn the upper part of the shaft 90 degrees and take a piece of 2x4 and hit it with the hammer. It will loosen up and you will then be able to compress it. While it is still hot move it in and out about 20 or 30 times and lube it up with grease. Then you will be set! Thanks and remember to call me if you want one. Aaron 720-933-7635
#742387 - 11/21/09 06:18 PM
[Re: LSJM1]
whitess
Frederick, CO
I just picked mine up from Aaron / fivetodrive. Very cool can't wait to put it in.  Larry.
85 SS
#766831 - 02/18/10 09:32 PM
[Re: grwhite038]
Stg1Regal
Milton,IN
With these steering shafts, I heard it's best to notch our steering coloumn shafts so the clamp bolt fits better?
Noticed when mine is being tightened down it wants to slip down the coloumn shaft abit, little to close to the edge for my tastes. ( but seems to hold well?)
#766844 - 02/18/10 09:54 PM
[Re: grwhite038]
Stg1Regal
Milton,IN
The reason for the above question is this from TurboBuick.com The shaft is a direct fit the only grinding is for the top bolt which slightly touches the steering column shaft most peeps tap the bolt in with a hammer and get it started with no grinding I found it easier to slide tha shaft up and mark it where the bolt hits slide it back off and grind-it takes about 30 seconds of grinding with a die grinder then you can put the top bolt in and get it threaded by hand not a big deal either way 84-96 shafts on regular cherokee all work early ones have 7/16 bolts later ones have 1/2 bolts Grand cherokee most of them have smaller opening for the upper shaft and will not fit without a lot of grinding.This is a cheap mod that you can feel the difference even if the jeep shaft has a small amount of play in the joints or shaft where they slide together
at this thread http://www.turbobuick.com/forums/brakes-...ring-shaft.htmlthanks
#767084 - 02/19/10 03:08 PM
[Re: Stg1Regal]
Gruvin
Moderator 15+ Year
Moderator 15+ Year
Texas
Noticed when mine is being tightened down it wants to slip down the coloumn shaft abit, little to close to the edge for my tastes. ( but seems to hold well?) make sure your shaft is extended all the way up, may need to smooth the inside of the connector a bit so it stays fully extended while tightening
#779588 - 03/30/10 03:56 PM
[Re: Duts87SS]
jeff83sssc
Ocala FL
Paul, an honest man like you, I'm sure next time you make sure they look it up correctly.  LSJM1, there is quite a bit of difference in the size of the openings; had to remove about 1/2" total from side-side and top-bottom. If you have a vice, grinder/drill, and bits it's no big deal at all. I would have gotten the correct shaft to begin with, but didn't do enough research before I placed my bid on Ebay (advertised as 93-98 Grand Cherokee shaft). I paid ~$30 TTD, and now believe it was completely worth it. The shaft fits nice and snug now, and it's amazing how much different the car is to drive with it. This same thing happened before to me, I've got the same shaft and gonna finish opening it up tonight.
#958506 - 01/14/13 05:23 PM
[Re: grwhite038]
84ss355*4spd
Edmonton,AB,Canada
I picked one up from my local yard. it was from the box style jeep grand cherokee limited. the column end fits snug. have not tried to hook to splines yet but im sure it will bolt right up. man those jeeps are tight to work on glad i have my ss. the shaft has a 4889 stamped on it if tjat helps anyone.
84ss current restoration 86 ss gone 85 ss new 85 z28 tpi ![[Linked Image]](http://i447.photobucket.com/albums/qq200/_monte_man_/mathewscarpics024-1.jpg) ![[Linked Image]](http://i19.photobucket.com/albums/b164/majestic_11/meandthemonte-2.jpg)
by 85 rider
by buffalo86montess
by Tony K.
by T-TopGene
by ray396
