Page 1 of 3 1 2 3
#55571 - 10/15/06 11:58 PM The Official Desktop Dyno Thread
rmodys Offline
rmodys  Offline
Ft. Myers, Florida
This is the thread where everyone can share their desktop dyno information, people without the program can request dynos of their engine and people can post their dyno results.
Note: I put it in the General area so it's not deleted in a month.
1986 Monte Carlo SS. Family owned 1987-1999; 2004-present, rust-free Florida car, L69 with TPI, B&M shift kit, 3.73 posi, new PUI interior, t-tops, lowered 2", refinished stock rims, Goodmark cowl hood, and amber DRL's.
#55572 - 10/16/06 12:01 AM Re: The Official Desktop Dyno Thread
realsurfer88 Offline
Tallahassee
heh wana do mine?? what information do you need...and i havent gotten my hands on my ss yet, its still my bmw
Super....scr3wduh at the moment..gah
#55573 - 10/16/06 12:02 AM Re: The Official Desktop Dyno Thread
rmodys Offline
rmodys  Offline
Ft. Myers, Florida
Just need all of the blue info on that chart that you can fill out.
#55574 - 10/16/06 12:17 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
willing to help
Didn't ask for a dime, $2
#55575 - 10/16/06 12:37 AM Re: The Official Desktop Dyno Thread
PontiCarlo468 Offline
Arcadia, Florida
I have Desktop Dyno and would be willing to help also... My 350 for my Regal Desktop Dynoed at 274hp and 376 lb. ft. of Torque \:D I know its not exact but its close \:D \:D
1987 Monte Carlo SS- Off The Road For Restoration... Then Street/Strip action when done!!!
1987 Chevy Caprice Wagon- New Daily Driver. Olds 307/TH-2004R/2.73s
Sargent Of Arms Of Maniacs Minions.
Glen502@hotmail.com
#55576 - 10/16/06 12:43 AM Re: The Official Desktop Dyno Thread
rmodys Offline
rmodys  Offline
Ft. Myers, Florida
My dad's LT-1 Camaro Z28 came out at 437 HP @ 6500 RPM and 368 ft-lb of torque at 6000 RPM.
#55577 - 10/16/06 12:59 AM Re: The Official Desktop Dyno Thread
Capitalsfan Offline
Capitalsfan  Offline
Fredericksburg, VA
Would like to know my setup if possible please. Here is the info
bore 4.040 by 3.48 stroke
Edelbrock 60899 heads 2.02 1.60
670 street avenger carb on an RPM air gap manifold
Hooker full length headers
Crane 113801 cam 224/234 @.050 .467in/.494ex
Thanks guys
1985 SS white, 357 CI, Crane Cam, Edelbrock alum heads and intake, Holley Street Avenger 670, MSD billet dist, MSD 6a, MSD 8975 box, Hooker Ceramic Coated full length headers, Flex-a-lite fans, March Serpentine pulleys and mounts, Flomaster 50's, TCI TC and Street-fighter trans kit, Quick Performance 9" 4.10 Tru-Trac, Edelbrock plate system
#55578 - 10/16/06 01:22 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
Thanks guys
PM Sent
#55579 - 10/16/06 01:45 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
any one have desktop drag-strip?
#55580 - 10/16/06 02:06 AM Re: The Official Desktop Dyno Thread
ssmnt408 Offline
ssmnt408  Offline
Michigan
I would like to see what it says about mine.
Bore 4.165
Stroke 3.75
11.6:1 compression
heads world sportsman II with 2.02 1.96 64 cc
solid roller 251i 261e @.050 .598i .625e 106 lsa
edelbrock super victor intake
holley 750hp carb
3 inch dual exhaust
need anything else?
88 turbo'd ss
#55581 - 10/16/06 02:19 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
Bore 4.165
Stroke 3.75
11.6:1 compression
holley 750hp carb
3 inch dual exhaust
need anything else?
PM Sent
#55582 - 10/16/06 02:51 PM Re: The Official Desktop Dyno Thread
whitess Offline
whitess  Offline
Frederick, CO
How about stock '85 L69 motor. 9.5:1 CR with:
Cam - Gross valve lift (I/E): 0.447 / 0.454
Duration @ 0.05 (I/E): 212 / 218
Lobe separation: 110.0
This is the Comp Cams XE256 w/their stamped rockers (1.5:1) and stock replacement pushrods.
Exhaust - 2.25" duals w/flowmasters
Let me know if you need anything else.
Larry.
85 SS
#55583 - 10/16/06 04:20 PM Re: The Official Desktop Dyno Thread
502SS Offline
502SS  Offline
Carson City, Michigan
Yes.
'83 Cutlass...project cheap...11.40's so far on a budget
'76 Jeep CJ5...430 SBC on spray
#55584 - 10/16/06 05:01 PM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
how well does it work?
#55585 - 10/16/06 09:27 PM Re: The Official Desktop Dyno Thread
How about doing my Big Block?
Bore-4.280
Stroke-4 inch
Displacement-461 CI
Heads-# 14096188 rectangular port open chamber
Chamber volume-119 cc
Compression ratio-10.5:1
Intake valve-2.19
Exhaust valve-1.88
Factory dual plane high rise intake manifold
Headers w/1 7/8 primary and dual exhaust
Mighty Demon 800 Dbl Pmp
Comp Solid Roller XR280R
.646 intake lift
.653 exhaust lift
242 intake duration @ .050
248 exhaust duration @ .050
110.0 degree lobe seperation
Intake valve open @34 deg btdc,close @ 66 abdc
Exhaust valve open @ 77 deg bbdc,close@ 29 atdc
#55586 - 10/16/06 10:30 PM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
PM Sent
#55587 - 10/17/06 01:39 AM Re: The Official Desktop Dyno Thread
Bear88SS Offline
Bear88SS  Offline
Yukon, Oklahoma
How about a 406 SBC?
Stroke- 3.75
Bore- 4.155
Heads- Dart
Intake Runners- 200cc
Comp. Ratio- 11.3:1
Int. Valve- 2.02
Exh. Valve- 1.6
Int. Manifold- Eddy RPM Air Gap
Headers- 1 5/8" primaries 31" long, 3" collector 9" long
Carb- Eddy 800cfm vac. secondary
Cam- Eddy RPM
Adv. Duration- 308*/318*
Duration at .050"- 234*/244*
Lift- .488"/.510"
LSA- 112*
Thanks.
1988 MCSS 427 SBC and changing all the time
please use chyaitsbear@yahoo.com for email thanks
#55588 - 10/17/06 01:52 AM Re: The Official Desktop Dyno Thread
502SS Offline
502SS  Offline
Probably about as well as Desktop Dyno does. Seems to be fairly close, but who knows. Send me your engine files along with the rest of the combo (trans,rear gear, stall speed, etc.), and I can try them out. There is an '82 Monte Carlo on there, so it at least has a pretty close setup.
#55589 - 10/17/06 02:05 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
info sent, let me know if you need anything more TIA
#55590 - 10/17/06 02:23 AM Re: The Official Desktop Dyno Thread
1984 MonteManiac Offline
tax york
I have a 5 speed manual TKO-600, can I play desktop drags and dyno too? I can't see the blue too good...I guess I can copy everone elses specs and sub with my own....
I hate know it alls and doubting toms.
#55591 - 10/17/06 02:24 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
Stroke- 3.75
Bore- 4.155
Heads- Dart
Comp. Ratio- 11.3:1
Int. Valve- 2.02
Exh. Valve- 1.6
Cam- Eddy RPM
Lift- .488"/.510"
LSA- 112*
Thanks.
PM Sent
#55592 - 10/17/06 02:26 AM Re: The Official Desktop Dyno Thread
MichiganBoy Offline
MichiganBoy  Offline
Ft Dix NJ
just sub your info with what bear listed and I'll run it
#55593 - 10/17/06 02:55 AM Re: The Official Desktop Dyno Thread
Bear88SS Offline
Bear88SS  Offline
Yukon, Oklahoma
Stroke- 3.75
Bore- 4.155
Heads- Dart
Comp. Ratio- 11.3:1
Int. Valve- 2.02
Exh. Valve- 1.6
Cam- Eddy RPM
Lift- .488"/.510"
LSA- 112*
Thanks.
PM Sent
Thanks man!
#55594 - 10/17/06 04:23 AM Re: The Official Desktop Dyno Thread
ssmnt408 Offline
ssmnt408  Offline
Michigan
Bore 4.165
Stroke 3.75
11.6:1 compression
holley 750hp carb
3 inch dual exhaust
4.56 gears
3800 stall
200-4r trans
275/60/15 dr's(28x9)
can you do mine in the virtual drag thing? if you need more just let me know.
Thanks, this is pretty neat!
88 turbo'd ss
#55595 - 10/17/06 10:46 AM Re: The Official Desktop Dyno Thread
tax york
ok I will do this tonight...thank you
Page 1 of 3 1 2 3
500/thumbs/Scott_s_88_SS_86_SS.jpg
by Scott_86SS
1166/thumbs/106681_0fe3b610bb_low_res.jpg
by lonk
500/thumbs/DSC03108-jpg.jpg
by f14dmechanic
500/thumbs/07-06-14_1759.jpg
by RoadWarrior
500/thumbs/IMG_1458.jpg
by Billdo38
