#606178 - 09/16/08 06:03 PM REAR DISC BRAKES FROM 1988 FIRE BIRD
T-Top Tony Offline
T-Top Tony  Offline
Rialto, CA
Hey guys my friend is selling me a rear disc brake setup from a 1988 fire bird will this fit the monte he said it would but i just want to make sure?
1987 Monte Carlo SS with T-Tops, lowered with Belltech drop spindles and lowering springs. LS1 brakes up front and LT1 brakes in the rear. Trying to make a comeback!
whiteside whitefront
#606234 - 09/16/08 08:55 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: T-Top Tony]
Aceprowler Offline
Aceprowler  Offline
Erie, Pa
Let me buy them from your friend and I'll see if they fit. smile
They will fit.
Getting them at a good price?
1984 Monte Carlo SS - "010" 4bolt 350, GN 8.5, 700R4, 3.42
#606239 - 09/16/08 09:11 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Aceprowler]
T-Top Tony Offline
T-Top Tony  Offline
Rialto, CA
lol! yeah hes asking 100 bucks is that good?
#606248 - 09/16/08 09:30 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: T-Top Tony]
Easily Offline
Easily  Offline
Elma New York
ya
1986 Monte Carlo SS. 305 L69/turbo 350 Black
1985 Monte Carlo SS. 305 L69/200 r4 White
Buffalo NY
#608490 - 09/24/08 01:09 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Easily]
Train Driver Offline
Dover, NJ
Any progress with the brakes? I am looking at doing a similar project on my Monte.
scott
"All I wanted was a Pepsi"
#608621 - 09/24/08 08:11 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Train Driver]
Is this a bolt-on mod or do you have to weld brackets to the axle tube?
Whats the story with (very) lowered cars? Will they still fit?
Do they have a drum brake style E brake in the rotor?
#608744 - 09/25/08 02:27 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: SickSpeedMonte]
elcam84 Offline
elcam84  Offline
Fort Worth,tx,usa
You have to cut the axle flange. The late F-body disk brake rear used a square flange like older cars did and many newer ones too. The G-bod had a tall rectangular one.
Basically you chop the top half of the flange off and drill two more holes in it. Then you enlarge the lower two holes. The problem you have is the lower holes have so little meat around them that they don't have much strength.
Lowered cars might run into frame clearance probs. The late ones have the little drum inside the rotor for the E-brake while the third gens have a caliper with a P brake. (88 is a third gen)
Gm has had allot of problems with the mechanism for the drum parking brakes. The trucks are the most notable. Often they would have to be replaced within a year or two to pass inspection because they would bend and not work anymore.
My neignbor ran into this the first time his had to be inspected. Doesn't matter if you use the brake or not was just a design issue and no salt or gunk here, looked like brand new still.
The F-bods didn't seem to have the same issue though, at least nowhere near as bad.
Robert Adams
#608791 - 09/25/08 06:25 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: elcam84]
Frenzy Offline
Frenzy  Offline
Vanc, WA.
At least search to find my progress thread on disc brakes.
Hardly worth it, honestly.
I feel zero difference and it was a headache getting the right stuff and it cost me nearly $500.
#608794 - 09/25/08 07:25 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Frenzy]
Dover, NJ
Oddly enough, a search is how I found this thread and posted to it. Go figure!
#608827 - 09/25/08 01:47 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Frenzy]
elcam84 Offline
elcam84  Offline
Fort Worth,tx,usa
No they aren't worth it in most cases. If you haven't upgraded to 12" or larger fronts and then you need an adjustable prop valve to really see any benefit from it. Rear disks are more for show and ease of repair as the stock drums with s-10 wheel cylinders will do all the braking that 90% of the modified G-bodys need.
Robert Adams
#608880 - 09/25/08 07:27 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: elcam84]
84supersport Offline
Louisville, KY
I've also heard front pads will last longer with rear disc because they dont have to do as much of the work. Drums are supposed to be better if you're foot-braking it at the track though for holding power. What all years did the factory bolt-on rear discs run? Were they on Camaros too, I would suppose so?
#609145 - 09/26/08 04:58 PM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: 84supersport]
Frenzy Offline
Frenzy  Offline
Vanc, WA.
Camaro stuff DOES NOT WORK period!!!!!
NONE of it works.
Camaro is so screwed up, they use 2 right side calipers and are staggered.
edit - I relived the nightmare by reviewing my own thread frown
http://www.montecarloss.com/community/ub...4180#Post584180
#609466 - 09/28/08 01:14 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Frenzy]
elcam84 Offline
elcam84  Offline
Fort Worth,tx,usa
The Camaro stuff does work though not optimal. We are talking about using the third gen set up including the third gen bracket not an aftermarket bracket.
Robert Adams
#609495 - 09/28/08 03:23 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: elcam84]
Frenzy Offline
Frenzy  Offline
Vanc, WA.
Like this one, right?
I tried. Its flanges aren't the same. Carlos uses 2 small bolts on bottom and one large bolt on top while these camaros use a square pattern 4 bolt style flange with the same size bolts.
Show me it works.
#609497 - 09/28/08 03:34 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Frenzy]
pazzo1969 Offline
pazzo1969  Offline
Mableton, GA
like elcam said
#609520 - 09/28/08 05:59 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: pazzo1969]
Frenzy Offline
Frenzy  Offline
Vanc, WA.
I thought you guys knew about another setup I didn't!
I also missed eclam's first response completely.
Otherwise it would'nt have gone this far hahah! smile
#609704 - 09/29/08 12:14 AM Re: REAR DISC BRAKES FROM 1988 FIRE BIRD [Re: Frenzy]
DOLLAR BILL Offline
DOLLAR BILL  Offline
columbus ohio
i was looking my buddy could not get it to work i was looking thinking he might have missed something i guess he was right 2
85an86 MONTE CARLO.SS- JIM
995/thumbs/44.jpg
by knight77
500/thumbs/monte_engine1.jpg
by 85lolo
1126/thumbs/1986_2.jpg
by Rich S
500/thumbs/009.jpg
by mdecker211
