#605772 - 09/15/08 01:04 AM Dual snorkel finally finished it.
Look what I did this week! Finally finished up my dual snorkel. Used spot welds and all. Looks very factory, just need the new black paint to faid a little and it will look just like it has been there forever and that new hose.
#605851 - 09/15/08 09:47 AM Re: Dual snorkel finally finished it. [Re: cj84ss]
TURBO Offline
TURBO  Offline
TN Smoky Mtns
Just keep an eye on your a/c lines. The new flange seems to rub the line.
87 SS White/ Saddle,t-top,350/330 hp
#605872 - 09/15/08 01:48 PM Re: Dual snorkel finally finished it. [Re: TURBO]
Monte_ExpreSS Offline
Oshawa, Ont. Canada
Looks factory. Good work! thumbs
#605876 - 09/15/08 02:14 PM Re: Dual snorkel finally finished it. [Re: Monte_ExpreSS]
Nice work - I've always liked factory appearing mods smile
#605879 - 09/15/08 02:19 PM Re: Dual snorkel finally finished it. [Re: 85_SS]
Thanks, It is clear of the a/c lines, it does look close in the pic. The only thing it is really close to is the vac ball.
#605901 - 09/15/08 04:01 PM Re: Dual snorkel finally finished it. [Re: cj84ss]
It appears like you had to angle the added snorkel down a bit to get it to clear the master cylinder. What did you have to do (if anything) to get the plastic part to fit the core support? Move or remove any thing there?
And is that a stock piece of ducting?
I like this mod and want to try to do it myself this coming winter, especially after I discovered the factory air cleaner was restrictive enough to eat up 15 hp and 15 ft lbs....
#605919 - 09/15/08 04:48 PM Re: Dual snorkel finally finished it. [Re: SSLance]
305ho Offline
305ho  Offline
stoney creek Ontario
That looks great, the way it should have been from the factory.
#605930 - 09/15/08 05:52 PM Re: Dual snorkel finally finished it. [Re: 305ho]
88ss408 Offline
88ss408  Offline
miramichi, NB
yeah look's real good ! where did you get the parts to make the other side ? is that off a 307 sbo powered car ?
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#606075 - 09/16/08 03:12 AM Re: Dual snorkel finally finished it. [Re: 88ss408]
The parts came from another factory air cleaner. It is basically a copy from the 84 Z28 setup. You do have to angle the drivers side down to clear everything on that side. Just like the z28 one was. Yes,it is a stock duct from the other side and bracket also. Did not have to move anything, got it to fit even with the grand prix bars in the front. Also on the pre heater on the drivers side, I did remove that and did a small blockoff plate so only hot air from the drivers side. If you want some more detailed pics, I can get them, just let me know.
500/thumbs/DSC02786.JPG
by Joe87monteSS
500/thumbs/moto_0058.jpg
by dw329
by 1NJIMID8TOR
500/thumbs/Mighty13w7.jpg
by bumpn1ohm
