#553189 - 04/04/08 09:16 PM Rear end parts?
I want to make my rear end a posi and keep the gears that I have, what cars/trucks have a carrier that will bolt in without alot of hassle?
#553200 - 04/04/08 09:30 PM Re: Rear end parts? [Re: cj84ss]
bad86monte Offline
bad86monte  Offline
Middletown Pa
I know that Mid 80's S-10 pick ups and blazers have the same rear. (7.5") Some came with factory posi units. I'd check around at your local salvage yards. You can probably pick up a posi chunk pretty cheap. You might have to do bearings while you have it apart. It all depends on how many miles your rear has on it.
#553397 - 04/05/08 05:23 AM Re: Rear end parts? [Re: bad86monte]
be careful, as most s dimes have a 28 spline axle
#553591 - 04/05/08 11:44 PM Re: Rear end parts? [Re: Onebadbowtie86]
FalconLB Offline
FalconLB  Offline
new york, new york
hmm,
couldn't you also swap axles?
#553605 - 04/06/08 12:56 AM Re: Rear end parts? [Re: FalconLB]
actually i think you can, wich would be better, 28>26
#553687 - 04/06/08 05:26 AM Re: Rear end parts? [Re: Onebadbowtie86]
Sounds like a axle and carrier swap to me, if they all will fit?
#553688 - 04/06/08 05:29 AM Re: Rear end parts? [Re: cj84ss]
The axles and carrier out of an s 10 should fit no problem, but id keep the open diff before putting in an old gov-loc out of an s 10, dont swap diffs and what not unless its an actuall limited slip. we just took the gov loc out of my buddys s dime today and put an open diff in it, as this is the 3rd axle shaft hes broken in it, and it only has a carbed 2.8, wich are only like 105hp
500/thumbs/DSC02786.JPG
by Joe87monteSS
500/thumbs/moto_0058.jpg
by dw329
by 1NJIMID8TOR
500/thumbs/Mighty13w7.jpg
by bumpn1ohm
